BBB GPIO disable interrupt bug
Federico Garcia Cruz federico.garciacruz at tallertechnologies.com
Thu Dec 10 19:15:10 UTC 2015
No problem Gedare. I would do it ASAP.
2015-12-10 16:06 GMT-03:00 Gedare Bloom <gedare at rtems.org>:
> This sounds like something else that was fixed about a month ago.. anyway,
> can you open a ticket and then #close it with the commit message for this
> change and submit it as a patch please?
> On Thu, Dec 10, 2015 at 10:29 AM, Federico Garcia Cruz <
> federico.garciacruz at tallertechnologies.com> wrote:
>> Hi,
>> I'm still working with the latest version of RTEMS in a BBB. I was
>> testing gpio interrupts and I found that "rtems_gpio_bsp_disable_interrupt"
>> is not working fine. When this function is called, disables not just the
>> specific pin interrupt but all the pins interrupts. The problem is that
>> this function uses mmio_set which does something like:
>> AM335X_GPIO_IRQSTATUS_CLR_0 = AM335X_GPIO_IRQSTATUS | BIT(pin)
>> so that it is clearing all the enalbed bank interrupts.
>> I've changed mmio_set for mmio_write and it's working fine. Here's the
>> patch:
>> diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> index bd26051..5990211 100644
>> --- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> +++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>> @@ -360,7 +369,7 @@ rtems_status_code rtems_gpio_bsp_disable_interrupt(
>>    rtems_gpio_interrupt interrupt
>>    /* Clear IRQ generation for the specific pin */
>> -  mmio_set(bbb_reg(bank, AM335X_GPIO_IRQSTATUS_CLR_0), BIT(pin));
>> +  mmio_write(bbb_reg(bank, AM335X_GPIO_IRQSTATUS_CLR_0), BIT(pin));
>>    switch ( interrupt ) {
>>      case FALLING_EDGE:
>> <http://www.tallertechnologies.com>
>> Software Engineer
>> San Lorenzo 47, 3rd Floor, Office 5
>> Córdoba, Argentina
>> Phone: +54 351 4217888 / +54 351 4218211
>> <http://www.linkedin.com/company/taller-technologies>
>> <https://www.facebook.com/tallertechnologies>
>> devel mailing list
>> devel at rtems.org
Software Engineer
Córdoba, Argentina
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151210/980aa6bf/attachment-0002.html>
