[PATCH] m32r: Partially remove m32rsim reference
Gedare Bloom
gedare at rtems.org
Mon Dec 14 16:27:51 UTC 2015
Please ask Joel Sherrill about those two issues.
On Sun, Dec 13, 2015 at 10:22 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
> The reason its "partially" since there are references of m32rsim in the
> files 'gcc/test_driver' and 'gcc/do_one' that I really don't know what
> to substitute in place of the m32rsim.
> Aun-Ali
> On 12/13/15 9:11 PM, Gedare Bloom wrote:
>> Aun-Ali,
>> Can you address Sebastian's question why "partially" removing m2rsim?
>> Also, can you regenerate a clean patch for this change?
>> On Thu, Dec 10, 2015 at 3:30 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> I am not sure about this one. What does "partially" mean? What is left?
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
