On 12/15/15 00:11, Pavel Pisa wrote: > > If the -maxdepth is accepted by your/others BSD, OS X, Cygwin > finds flavors then next change would make script to run on Linux. > Thank you for this and the patch. I will update the rtems-bsps script on 4.11 and master. It will be in 4.11.0-rc2. Chris
