ubuntu 15.04 build fail
    Chris Johns
    chrisj at rtems.org
    Mon Dec 21 00:03:28 UTC 2015
On 18/12/2015 5:49 PM, punit vara wrote:
> checking for python... /usr/local/bin/python
> checking for python2.7... no
> configure: error: python is missing or unusable
> Makefile:8643: recipe for target 'configure-gdb' failed
> make[1]: *** [configure-gdb] Error 1
> make[1]: Leaving directory
> '/home/punit/development/rtems/rsb/rtems-source-builder/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/build'
> make: *** [all] Error 2
> Makefile:836: recipe for target 'all' failed
> shell cmd failed: /bin/sh -ex
> /home/punit/development/rtems/rsb/rtems-source-builder/rtems/build/arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1/doit
> error: building arm-rtems4.11-gdb-7.9-x86_64-linux-gnu-1
> I do not know why I am facing this build error.
> I have checked $python --version
> it is Python 2.7.10
> I have also installed $sudo apt-get install python-all-dev
Did you install the packages are listed in the doco:
 https://docs.rtems.org/rsb/#_ubuntu
