[PATCH] api: Remove deprecated Notepads
Wed Dec 23 18:56:00 UTC 2015
On Dec 23, 2015 12:06 PM, "Aun-Ali Zaidi" <admin at kodeit.net> wrote:
> On 12/23/15 10:51 AM, Joel Sherrill wrote:
> > Here are some notes which might help on the tests:
> > + tm08 - remove specific uses of notepads
> > + tmoverhd - same
> > + mp02 - remove test. Functionality of polling for something to happen
> > is covered
> >    in at least mp04
> > + spnotepad01 - remove test
> > + spnotepad02 - remove test
> > + sptask_err04 - remove specific uses of notepads
> > + sp07 - remove specific uses of notepads
> Do I also apply the same changes to the Ada testsuite as I applied to
> the C/C++ testsuites?
Most likely. The Ada tests dont try everything the C ones do so read the
code and compare but I am pretty sure it applies.
> Aun-Ali
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151223/e75ab14b/attachment-0002.html>
