[PATCH] api: Remove deprecated Notepads
Joel Sherrill
joel at rtems.org
Wed Dec 23 19:00:11 UTC 2015
On Dec 23, 2015 12:37 PM, "Aun-Ali Zaidi" <admin at kodeit.net> wrote:
> The MVME5500 BSP uses Notepads in its exception handler function
> 'BSP_exceptionHandler'.
> Do I leave it as is or try to strip the functionality all together?
I don't see this with a grep in my source. Where is it?
If there....
Just my opinion but file another ticket specific to this. I do not have a
clue where this is used but it can't be portable. As soon as your patch is
applied, the code won't compile. Wrap the call if an #if 0 block and add a
comment referencing the new ticket.
> Aun-Ali
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151223/7679ee51/attachment-0002.html>
