[PATCH 1/4] Filesystem: Make rtems_libio_number_iops const
Mon Feb 2 14:25:23 UTC 2015
 cpukit/libcsupport/include/rtems/libio_.h | 2 +-
 cpukit/sapi/include/confdefs.h            | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index e204508..8703e09 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -64,7 +64,7 @@ extern rtems_id                          rtems_libio_semaphore;
  *  File descriptor Table Information
-extern uint32_t        rtems_libio_number_iops;
+extern const uint32_t rtems_libio_number_iops;
 extern rtems_libio_t  *rtems_libio_iops;
 extern rtems_libio_t  *rtems_libio_last_iop;
 extern rtems_libio_t *rtems_libio_iop_freelist;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 595dac5..569f136 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -157,7 +157,7 @@ const rtems_libio_helper rtems_fs_init_helper =
    * When instantiating the configuration tables, this variable is
    * initialized to specify the maximum number of file descriptors.
-  uint32_t rtems_libio_number_iops = CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS;
+  const uint32_t rtems_libio_number_iops = CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS;
 #endif
1.8.4.5
