Waf branch - Overview [2/6]
Amar Takhar amar at rtems.org
Sun Feb 8 13:57:09 UTC 2015
On 2015-02-08 09:40 +0100, Sebastian Huber wrote:
> Thanks for your great work in the background.
Thanks and you're welcome!
> I tested it on a five year old low budget laptop with an up to date
> openSUSE and it worked out of the box.
> I updated the timing page (2m with waf and 14m with the current build
> system):
Awesome!
> One issue I found is that the test are not re-built in case the
> librtemscpu.a changes, e.g.
Because librtemscpu.a didn't change.  The timestamp is not enoguh to force waf
to rebuild.
Make an actual change to a source C file for librtemscpu.a forces all the tests
to be rebuilt I just tried it to verify.
Amar.
