[rtems commit] smpcapture02: Add test of functionality to add custom entries to capture trace
Daniel Cederman cederman at gaisler.com
Fri Feb 13 07:56:01 UTC 2015
 > Daniel(s), could enlighten me why this is needed ? Is this a arch
 > constraint or something else ?
 > Chris
It is an arch constraint. On SPARC, for example, all memory accesses
needs to a be aligned. From the SPARC V8 manual:
"Halfword accesses must be aligned on 2-byte boundaries, word accesses
must be aligned on 4-byte boundaries, and doubleword accesses must be
aligned on 8-byte boundaries. An improperly aligned address in a load or
store instruction causes a trap to occur."
Since the capture engine does a 64-bit write when it writes the time,
the entries needs to be aligned on 8-byte boundaries.
Daniel C
On 2015-02-12 08:29, Chris Johns wrote:
> On 12/02/2015 2:34 am, Daniel Hellstrom wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    8d8573acc8f620c93afa8dd30ea8418d25ad2d21
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=8d8573acc8f620c93afa8dd30ea8418d25ad2d21
>> Author:    Daniel Cederman <cederman at gaisler.com>
>> Date:      Wed Feb  4 10:04:05 2015 +0100
>> capture trace
>>   testsuites/smptests/Makefile.am                   |   1 +
>>   testsuites/smptests/configure.ac                  |   1 +
>>   testsuites/smptests/smpcapture02/Makefile.am      |  19 +
>>   testsuites/smptests/smpcapture02/init.c           | 425
>>   testsuites/smptests/smpcapture02/smpcapture02.doc |  30 ++
>>   testsuites/smptests/smpcapture02/smpcapture02.scn |   2 +
>>   6 files changed, 478 insertions(+)
>> diff --git a/testsuites/smptests/Makefile.am
>> b/testsuites/smptests/Makefile.am
>> index 87c3d7f..4b81a20 100644
>> --- a/testsuites/smptests/Makefile.am
>> +++ b/testsuites/smptests/Makefile.am
>> @@ -13,6 +13,7 @@ SUBDIRS += smpaffinity01
>>   SUBDIRS += smpatomic01
>>   SUBDIRS += smpcache01
>>   SUBDIRS += smpcapture01
>> +SUBDIRS += smpcapture02
>>   SUBDIRS += smpfatal01
>>   SUBDIRS += smpfatal02
>>   SUBDIRS += smpfatal03
>> diff --git a/testsuites/smptests/configure.ac
>> b/testsuites/smptests/configure.ac
>> index f25c9d7..5aee6ec 100644
>> --- a/testsuites/smptests/configure.ac
>> +++ b/testsuites/smptests/configure.ac
>> @@ -68,6 +68,7 @@ smpaffinity01/Makefile
>>   smpatomic01/Makefile
>>   smpcache01/Makefile
>>   smpcapture01/Makefile
>> +smpcapture02/Makefile
>>   smpfatal01/Makefile
>>   smpfatal02/Makefile
>>   smpfatal03/Makefile
>> diff --git a/testsuites/smptests/smpcapture02/Makefile.am
>> b/testsuites/smptests/smpcapture02/Makefile.am
>> new file mode 100644
>> index 0000000..d7a172c
>> --- /dev/null
>> +++ b/testsuites/smptests/smpcapture02/Makefile.am
>> @@ -0,0 +1,19 @@
>> +rtems_tests_PROGRAMS = smpcapture02
>> +smpcapture02_SOURCES = init.c
>> +dist_rtems_tests_DATA = smpcapture02.scn smpcapture02.doc
>> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>> +include $(top_srcdir)/../automake/compile.am
>> +include $(top_srcdir)/../automake/leaf.am
>> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>> +LINK_OBJS = $(smpcapture02_OBJECTS)
>> +LINK_LIBS = $(smpcapture02_LDLIBS)
>> +smpcapture02$(EXEEXT): $(smpcapture02_OBJECTS)
>> $(smpcapture02_DEPENDENCIES)
>> +    @rm -f smpcapture02$(EXEEXT)
>> +    $(make-exe)
>> +include $(top_srcdir)/../automake/local.am
>> diff --git a/testsuites/smptests/smpcapture02/init.c
>> b/testsuites/smptests/smpcapture02/init.c
>> index 0000000..bd912ee
>> --- /dev/null
>> +++ b/testsuites/smptests/smpcapture02/init.c
>> @@ -0,0 +1,425 @@
>> + *  COPYRIGHT (c) 2015
>> + *  Cobham Gaisler
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE.
>> + * SMP Capture Test 2
>> + * This program tests the functionality to add custom entries to
>> + * the SMP capture trace.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <rtems.h>
>> +#include <bsp/irq.h>
>> +#include <rtems/captureimpl.h>
>> +#include "tmacros.h"
>> +const char rtems_test_name[] = "SMPCAPTURE 2";
>> +#define MAX_CPUS       4
>> +#define TASKS_PER_CPU  5
>> +#define ITERATIONS     3
>> +#define TASK_PRIO      30
>> +#define CLOCK_TICKS    100
>> +typedef struct  {
>> +  rtems_id id;
>> +  rtems_id task_sem;
>> +  rtems_id prev_sem;
>> +} task_data_t;
>> +typedef struct {
>> +  bool found;
>> +  const char *info;
>> +  rtems_option options;
>> +  rtems_interrupt_handler handler;
>> +  void *arg;
>> +} clock_interrupt_handler;
>> +static rtems_id finished_sem;
>> +static task_data_t task_data[ TASKS_PER_CPU * TASKS_PER_CPU ];
>> +static rtems_interrupt_handler org_clock_handler;
>> +enum cap_rec_types {
>> +  enter_add_number,
>> +  exit_add_number,
>> +  clock_tick
>> + * These records define the data stored in the capture trace.
>> + * The records must be 64-bit aligned to make sure that the time
>> + * attribute in rtems_capture_record_t is correctly aligned.
> Chris
>> +typedef struct {
>> +  enum cap_rec_types id;
>> +  uint32_t a;
>> +  uint32_t b;
>> +} __attribute__ ((aligned (8))) enter_add_number_record_t;
>> +typedef struct {
>> +  uint32_t res;
>> +} __attribute__ ((aligned (8))) exit_add_number_record_t;
>> +typedef struct {
>> +  void *arg;
>> +} __attribute__ ((aligned (8))) clock_tick_record_t;
>> +typedef struct {
>> +} empty_record_t ;
>> + * The function that we want to trace
>> +static uint32_t add_number(uint32_t a, uint32_t b)
>> +  return a+b;
>> + * The wrapper for the function we want to trace. Records
>> + * input arguments and the result to the capture trace.
>> +static uint32_t add_number_wrapper(uint32_t a, uint32_t b)
>> +  enter_add_number_record_t enter_rec;
>> +  exit_add_number_record_t exit_rec;
>> +  uint32_t res;
>> +  void* rec;
>> +  enter_rec.id = enter_add_number;
>> +  enter_rec.a = a;
>> +  enter_rec.b = b;
>> +  rtems_capture_begin_add_record(_Thread_Get_executing(),
>> +      RTEMS_CAPTURE_TIMESTAMP, sizeof(rtems_capture_record_t)+
>> +      sizeof(enter_add_number_record_t), &rec);
>> +  rec = rtems_capture_append_to_record(rec, &enter_rec,
>> sizeof(enter_rec));
>> +  rtems_capture_end_add_record(rec);
>> +  res = add_number(a, b);
>> +  exit_rec.id = exit_add_number;
>> +  exit_rec.res = res;
>> +      sizeof(exit_add_number_record_t), &rec);
>> +  rec = rtems_capture_append_to_record(rec, &exit_rec,
>> sizeof(exit_rec));
>> +  return res;
>> + * Task that calls the function we want to trace
>> +static void task(rtems_task_argument arg)
>> +  rtems_status_code sc;
>> +  uint32_t i;
>> +  for ( i = 0; i < ITERATIONS; i++ ) {
>> +     * Wait until the previous task in the task chain
>> +     * has completed its operation.
>> +    sc = rtems_semaphore_obtain(task_data[arg].prev_sem, 0, 0);
>> +    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>> +    add_number_wrapper(arg, i);
>> +     * Signal the next task in the chain to continue
>> +    sc = rtems_semaphore_release(task_data[arg].task_sem);
>> +  /* Signal the main task that this task has finished */
>> +  sc = rtems_semaphore_release(finished_sem);
>> +  rtems_task_suspend(rtems_task_self());
>> +static void test(void)
>> +  uint32_t cpu_count;
>> +  uint32_t t;
>> +  uint32_t c;
>> +  rtems_task_argument idx;
>> +  cpu_set_t cpu_set;
>> +  /* Semaphore to signal end of test */
>> +  sc = rtems_semaphore_create(rtems_build_name('D', 'o', 'n', 'e'), 0,
>> +      RTEMS_LOCAL |
>> +      RTEMS_NO_INHERIT_PRIORITY |
>> +      RTEMS_NO_PRIORITY_CEILING |
>> +      RTEMS_FIFO, 0, &finished_sem);
>> +  /* Get the number of processors that we are using. */
>> +  cpu_count = rtems_get_processor_count();
>> +   * Create a set of tasks per CPU. Chain them together using
>> +   * semaphores so that only one task can be active at any given
>> +   * time.
>> +  for ( c = 0; c < cpu_count; c++ ) {
>> +    for ( t = 0; t < TASKS_PER_CPU; t++ ) {
>> +      idx = c * TASKS_PER_CPU + t;
>> +      sc = rtems_task_create(rtems_build_name('T', 'A', '0' + c, '0'
>> + t),
>> +          TASK_PRIO,
>> +          RTEMS_MINIMUM_STACK_SIZE,
>> +          RTEMS_DEFAULT_MODES,
>> +          RTEMS_DEFAULT_ATTRIBUTES,
>> +          &task_data[idx].id);
>> +      sc = rtems_semaphore_create(rtems_build_name('S', 'E', '0' + c,
>> '0' + t),
>> +          0,
>> +          RTEMS_LOCAL |
>> +          RTEMS_SIMPLE_BINARY_SEMAPHORE |
>> +          RTEMS_FIFO, 0, &task_data[idx].task_sem);
>> +      task_data[(idx + 1) % (cpu_count * TASKS_PER_CPU)].prev_sem =
>> +          task_data[idx].task_sem;
>> +      CPU_ZERO_S(sizeof(cpu_set_t), &cpu_set);
>> +      CPU_SET_S(c, sizeof(cpu_set_t), &cpu_set);
>> +      sc = rtems_task_set_affinity(task_data[idx].id, sizeof(cpu_set_t),
>> +          &cpu_set);
>> +  /* Start the tasks */
>> +  for ( idx = 0; idx < cpu_count * TASKS_PER_CPU; idx++ ) {
>> +    sc = rtems_task_start(task_data[idx].id, task, idx);
>> +  /* Start chain */
>> +  sc = rtems_semaphore_release(task_data[0].task_sem);
>> +  /* Wait until chain has completed */
>> +    rtems_semaphore_obtain(finished_sem, 0, 0);
>> +/* Writes an entry in the capture trace for every clock tick */
>> +static void clock_tick_wrapper(void *arg)
>> +  void* rec;
>> +  clock_tick_record_t clock_tick_record = {.id = clock_tick};
>> +  Thread_Control* tcb = _Thread_Get_executing();
>> +  rtems_capture_begin_add_record(tcb, RTEMS_CAPTURE_TIMESTAMP,
>> +      sizeof(rtems_capture_record_t) + sizeof(clock_tick_record_t),
>> &rec);
>> +  rec = rtems_capture_append_to_record(rec, &clock_tick_record,
>> +      sizeof(clock_tick_record));
>> +  org_clock_handler(arg);
>> +/* Tries to locate the clock interrupt handler by looking
>> + * for a handler with the name "Clock" or "clock" */
>> +static void locate_clock_interrupt_handler(
>> +    void *arg, const char *info, rtems_option options,
>> +    rtems_interrupt_handler handler, void *handler_arg)
>> +  clock_interrupt_handler *cih = (clock_interrupt_handler*)arg;
>> +  if ( !strcmp(info, "clock") || !strcmp(info, "Clock") ) {
>> +    cih->info = info;
>> +    cih->options = options;
>> +    cih->handler = handler;
>> +    cih->arg = handler_arg;
>> +    cih->found = true;
>> +static void Init(rtems_task_argument arg)
>> +  uint32_t i;
>> +  uint32_t cpu;
>> +  uint32_t read;
>> +  uint32_t enter_count;
>> +  uint32_t exit_count;
>> +  uint32_t clock_tick_count;
>> +  uint32_t res_should_be;
>> +  rtems_name name;
>> +  rtems_capture_record_t *recs;
>> +  rtems_capture_record_t *prev_rec;
>> +  empty_record_t *record;
>> +  enter_add_number_record_t *enter_add_number_rec;
>> +  exit_add_number_record_t *exit_add_number_rec;
>> +  rtems_vector_number vec;
>> +  clock_interrupt_handler cih = {.found = 0};
>> +  TEST_BEGIN();
>> +  sc = rtems_capture_open(50000, NULL);
>> +  sc = rtems_capture_watch_global(true);
>> +  sc = rtems_capture_control(true);
>> +  /* Run main test */
>> +  test();
>> +  /* Try to find the clock interrupt handler */
>> +  for ( vec=BSP_INTERRUPT_VECTOR_MIN; vec<BSP_INTERRUPT_VECTOR_MAX;
>> vec++ ) {
>> +    rtems_interrupt_handler_iterate(vec,
>> locate_clock_interrupt_handler, &cih);
>> +    if ( cih.found )
>> +      break;
>> +  /* If we find the clock interrupt handler we replace it with
>> +   * a wrapper and wait for a fixed number of ticks.
>> +  if ( cih.found ) {
>> +#ifdef VERBOSE
>> +    printf("Found a clock handler\n");
>> +#endif
>> +    org_clock_handler = cih.handler;
>> +    rtems_interrupt_handler_install(vec, cih.info,
>> +        cih.options | RTEMS_INTERRUPT_REPLACE, clock_tick_wrapper,
>> cih.arg);
>> +    rtems_task_wake_after(CLOCK_TICKS);
>> +  /* Disable capturing */
>> +  sc = rtems_capture_control(false);
>> +  clock_tick_count = 0;
>> +  /* Read out the trace from all processors */
>> +  for ( cpu = 0; cpu < rtems_get_processor_count(); cpu++ ) {
>> +    sc = rtems_capture_read(cpu, &read, &recs);
>> +    prev_rec = recs;
>> +    enter_count = 0;
>> +    exit_count = 0;
>> +    res_should_be = 0;
>> +    for ( i = 0; i < read; i++ ) {
>> +      /* Verify that time goes forward */
>> +      rtems_test_assert(recs->time>=prev_rec->time);
>> +      if ( recs->events & RTEMS_CAPTURE_TIMESTAMP ) {
>> +        record = (empty_record_t*)((char*) recs +
>> +            sizeof(rtems_capture_record_t));
>> +        switch ( record->id ) {
>> +        case enter_add_number:
>> +          rtems_test_assert(enter_count==exit_count);
>> +          enter_count++;
>> +          enter_add_number_rec = (enter_add_number_record_t*)record;
>> +          res_should_be = add_number(enter_add_number_rec->a,
>> +              enter_add_number_rec->b);
>> +          rtems_object_get_classic_name(recs->task_id, &name);
>> +#ifdef VERBOSE
>> +          /* Print record */
>> +          printf("Time: %"PRIu64"us Task: %4s => Add %"PRIu32" and"
>> +              " %"PRIu32"\n",
>> +              recs->time/1000,
>> +              (char*)&name,
>> +              enter_add_number_rec->a,
>> +#endif
>> +          break;
>> +        case exit_add_number:
>> +          rtems_test_assert(enter_count==exit_count+1);
>> +          exit_count++;
>> +          exit_add_number_rec = (exit_add_number_record_t*)record;
>> +          /* Verify that the result matches the expected result */
>> +          rtems_test_assert(res_should_be == exit_add_number_rec->res);
>> +#ifdef VERBOSE
>> +          printf("Time: %"PRIu64"us Task: %4s => Result is %"PRIu32"\n",
>> +              recs->time/1000,
>> +              (char*)&name,
>> +              exit_add_number_rec->res);
>> +#endif
>> +          break;
>> +        case clock_tick:
>> +          clock_tick_count++;
>> +#ifdef VERBOSE
>> +          printf("Time: %"PRIu64"us Task: %4s => Clock tick\n",
>> +              recs->time/1000,
>> +              (char*)&name);
>> +#endif
>> +          break;
>> +        default:
>> +          rtems_test_assert(0);
>> +      prev_rec = recs;
>> +      recs = (rtems_capture_record_t*) ((char*) recs + recs->size);
>> +    rtems_test_assert(enter_count == exit_count);
>> +    rtems_test_assert(enter_count == TASKS_PER_CPU * ITERATIONS);
>> +    rtems_capture_release(cpu, read);
>> +  if( cih.found )
>> +    rtems_test_assert(clock_tick_count == CLOCK_TICKS);
>> +  TEST_END();
>> +  rtems_test_exit(0);
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_SMP_APPLICATION
>> +#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
>> +#define CONFIGURE_SMP_MAXIMUM_PROCESSORS MAX_CPUS
>> +#define CONFIGURE_MAXIMUM_PROCESSORS MAX_CPUS
>> +#define CONFIGURE_MAXIMUM_SEMAPHORES MAX_CPUS * TASKS_PER_CPU + 1
>> +#define CONFIGURE_MAXIMUM_TASKS MAX_CPUS * TASKS_PER_CPU + 1
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS  1
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#include <rtems/confdefs.h>
>> diff --git a/testsuites/smptests/smpcapture02/smpcapture02.doc
>> b/testsuites/smptests/smpcapture02/smpcapture02.doc
>> index 0000000..8aa7549
>> --- /dev/null
>> +++ b/testsuites/smptests/smpcapture02/smpcapture02.doc
>> @@ -0,0 +1,30 @@
>> +This file describes the directives and concepts tested by this test set.
>> +test set name: smpcapture02
>> +directives:
>> +  rtems_capture_append_to_record
>> +  rtems_capture_read
>> +concepts:
>> +SMP Capture Test 2
>> +This program tests the functionality to add custom entries to
>> +the SMP capture trace.
>> +A simple function is wrapped inside another function that stores
>> +the input arguments and the function's result in the capture trace
>> +every time it is called. The function is called by a set of tasks
>> +per CPU during the test. The tasks are linked together by semaphores
>> +in such a way that only one task is active at any given time. At the
>> +end of the test the data stored in the capture trace is verified to
>> +make sure that all invocations of the traced function were stored
>> correctly.
>> +The test also traces clock tick interrupts. If an interrupt handler
>> +with the name "Clock" or "clock" exists, it is assumed to be the main
>> +clock interrupt handler. The test wraps this function with another
>> function
>> +that adds an entry to the trace for every clock tick.
>> diff --git a/testsuites/smptests/smpcapture02/smpcapture02.scn
>> b/testsuites/smptests/smpcapture02/smpcapture02.scn
>> index 0000000..c4435e2
>> --- /dev/null
>> +++ b/testsuites/smptests/smpcapture02/smpcapture02.scn
>> @@ -0,0 +1,2 @@
>> +*** BEGIN OF TEST SMPCAPTURE 2 ***
>> +*** END OF TEST SMPCAPTURE 2 ***
>> vc mailing list
>> vc at rtems.org
>> http://lists.rtems.org/mailman/listinfo/vc
> devel mailing list
> devel at rtems.org
Daniel Cederman
Software Engineer
Cobham Gaisler
daniel.cederman at gaisler.com
Cobham Gaisler AB, Kungsgatan 12, SE-411 19, GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.cobham.com/gaisler
Please consider the environment before printing this email
This e-mail and any files transmitted with it ("E-mail") is intended
solely for the addressee(s) and may contain confidential and/or legally
privileged information. If you are not the addressee(s), any disclosure,
reproduction, copying, distribution or other use of the E-mail is
prohibited. If you have received this E-mail in error, please delete it
and notify the sender immediately via our switchboard or return e-mail.
Neither the company nor any subsidiary or affiliate or associated
company nor any individual sending this Email accepts any liability in
respect of the content (including errors and omissions) nor shall this
e-mail be deemed to enter the company or any subsidiary or affiliate or
associated company into a contract or to create any legally binding
obligations unless expressly agreed to in writing under separate cover
and timeliness of the E-mail which arise as a result of transmission. If
verification is required, please request a hard copy version from the
sender.
