[PATCH 1/2] score: Fix FP context restore via _Thread_Handler
Sebastian Huber
Tue Feb 17 18:58:44 UTC 2015
After a context switch we end up in the second part of
_Thread_Dispatch() or in _Thread_Handler() in case of new threads. Use
the same function _Thread_Restore_fp() to restore the floating-point
context. It makes no sense to do this in _Thread_Start_multitasking().
This fixes also a race condition in SMP configurations.
Update #2268.
cpukit/score/include/rtems/score/threadimpl.h | 41 +++++++++++++++++++++++++++
cpukit/score/src/threaddispatch.c | 38 ++-----------------------
cpukit/score/src/threadhandler.c | 11 +------
cpukit/score/src/threadstartmultitasking.c | 22 --------------
4 files changed, 44 insertions(+), 68 deletions(-)
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index bfaf1fd..353093c 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -587,6 +587,47 @@ RTEMS_INLINE_ROUTINE bool _Thread_Is_allocated_fp (
#endif
+ * If the CPU has hardware floating point, then we must address saving
+ * and restoring it as part of the context switch.
+ * The second conditional compilation section selects the algorithm used
+ * to context switch between floating point tasks. The deferred algorithm
+ * can be significantly better in a system with few floating point tasks
+ * because it reduces the total number of save and restore FP context
+ * operations. However, this algorithm can not be used on all CPUs due
+ * to unpredictable use of FP registers by some compilers for integer
+ * operations.
+RTEMS_INLINE_ROUTINE void _Thread_Save_fp( Thread_Control *executing )
+#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
+#if ( CPU_USE_DEFERRED_FP_SWITCH != TRUE )
+ if ( executing->fp_context != NULL )
+ _Context_Save_fp( &executing->fp_context );
+#endif
+#endif
+RTEMS_INLINE_ROUTINE void _Thread_Restore_fp( Thread_Control *executing )
+#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
+ if ( (executing->fp_context != NULL) &&
+ !_Thread_Is_allocated_fp( executing ) ) {
+ if ( _Thread_Allocated_fp != NULL )
+ _Context_Save_fp( &_Thread_Allocated_fp->fp_context );
+ _Context_Restore_fp( &executing->fp_context );
+ _Thread_Allocated_fp = executing;
+#else
+#endif
+#endif
* This routine is invoked when the currently loaded floating
* point context is now longer associated with an active thread.
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 982bbc4..cc023fc 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -142,43 +142,9 @@ void _Thread_Dispatch( void )
#endif
_User_extensions_Thread_switch( executing, heir );
- * If the CPU has hardware floating point, then we must address saving
- * and restoring it as part of the context switch.
- * The second conditional compilation section selects the algorithm used
- * to context switch between floating point tasks. The deferred algorithm
- * can be significantly better in a system with few floating point tasks
- * because it reduces the total number of save and restore FP context
- * operations. However, this algorithm can not be used on all CPUs due
- * to unpredictable use of FP registers by some compilers for integer
- * operations.
-#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
-#if ( CPU_USE_DEFERRED_FP_SWITCH != TRUE )
- if ( executing->fp_context != NULL )
- _Context_Save_fp( &executing->fp_context );
-#endif
-#endif
+ _Thread_Save_fp( executing );
_Context_Switch( &executing->Registers, &heir->Registers );
-#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
- if ( (executing->fp_context != NULL) &&
- !_Thread_Is_allocated_fp( executing ) ) {
- if ( _Thread_Allocated_fp != NULL )
- _Context_Save_fp( &_Thread_Allocated_fp->fp_context );
- _Context_Restore_fp( &executing->fp_context );
- _Thread_Allocated_fp = executing;
-#else
-#endif
-#endif
+ _Thread_Restore_fp( executing );
* We have to obtain this value again after the context switch since the
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index f8a9a62..db73028 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -51,16 +51,7 @@ void _Thread_Handler( void )
* through _Thread_Dispatch on our first invocation. So the normal
* code path for performing the FP context switch is not hit.
- #if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
- #if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
- #endif
- #endif
* Take care that 'begin' extensions get to complete before
diff --git a/cpukit/score/src/threadstartmultitasking.c b/cpukit/score/src/threadstartmultitasking.c
index 7fbdd84..838cf23 100644
--- a/cpukit/score/src/threadstartmultitasking.c
+++ b/cpukit/score/src/threadstartmultitasking.c
@@ -37,28 +37,6 @@ void _Thread_Start_multitasking( void )
heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
- * Get the init task(s) running.
- * Note: Thread_Dispatch() is normally used to dispatch threads. As
- * part of its work, Thread_Dispatch() restores floating point
- * state for the heir task.
- * This code avoids Thread_Dispatch(), and so we have to restore
- * (actually initialize) the floating point state "by hand".
- * Ignore the CPU_USE_DEFERRED_FP_SWITCH because we must always
- * switch in the first thread if it is FP.
- * don't need to worry about saving BSP's floating point state
- if ( heir->fp_context != NULL )
- _Context_Restore_fp( &heir->fp_context );
-#endif
_Profiling_Thread_dispatch_disable( cpu_self, 0 );
#if defined(RTEMS_SMP)
2.1.4
