[PATCH] score: Make <rtems/score/atomic.h> available
Sebastian Huber
Wed Feb 18 16:46:37 UTC 2015
Make <rtems/score/atomic.h> available for all RTEMS configurations. Use
inline functions instead of macros. Use ISR disable/enable on
uni-processor configurations to ensure atomicity.
Update #2273.
cpukit/score/Makefile.am | 4 +-
cpukit/score/include/rtems/score/atomic.h | 2 +
cpukit/score/include/rtems/score/cpustdatomic.h | 772 ++++++++++++++++++------
cpukit/score/preinstall.am | 16 +-
testsuites/smptests/smpatomic01/init.c | 200 ------
testsuites/smptests/smpatomic01/smpatomic01.scn | 7 -
testsuites/sptests/Makefile.am | 1 +
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spatomic01/Makefile.am | 19 +
testsuites/sptests/spatomic01/init.c | 254 ++++++++
testsuites/sptests/spatomic01/spatomic01.doc | 37 ++
testsuites/sptests/spatomic01/spatomic01.scn | 9 +
12 files changed, 909 insertions(+), 413 deletions(-)
create mode 100644 testsuites/sptests/spatomic01/Makefile.am
create mode 100644 testsuites/sptests/spatomic01/init.c
create mode 100644 testsuites/sptests/spatomic01/spatomic01.doc
create mode 100644 testsuites/sptests/spatomic01/spatomic01.scn
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 3e646a1..7bb7dab 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -17,6 +17,7 @@ include_rtems_score_HEADERS = include/rtems/score/address.h
include_rtems_score_HEADERS += include/rtems/score/apiext.h
include_rtems_score_HEADERS += include/rtems/score/apimutex.h
include_rtems_score_HEADERS += include/rtems/score/assert.h
+include_rtems_score_HEADERS += include/rtems/score/atomic.h
include_rtems_score_HEADERS += include/rtems/score/chain.h
include_rtems_score_HEADERS += include/rtems/score/chainimpl.h
include_rtems_score_HEADERS += include/rtems/score/context.h
@@ -31,6 +32,7 @@ include_rtems_score_HEADERS += include/rtems/score/coresem.h
include_rtems_score_HEADERS += include/rtems/score/coresemimpl.h
include_rtems_score_HEADERS += include/rtems/score/cpuset.h
include_rtems_score_HEADERS += include/rtems/score/cpusetimpl.h
+include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
include_rtems_score_HEADERS += include/rtems/score/heap.h
include_rtems_score_HEADERS += include/rtems/score/heapimpl.h
include_rtems_score_HEADERS += include/rtems/score/protectedheap.h
@@ -112,8 +114,6 @@ include_rtems_score_HEADERS += include/rtems/score/threadmp.h
endif
if HAS_SMP
-include_rtems_score_HEADERS += include/rtems/score/atomic.h
-include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
include_rtems_score_HEADERS += include/rtems/score/schedulerprioritysmpimpl.h
include_rtems_score_HEADERS += include/rtems/score/schedulerpriorityaffinitysmp.h
include_rtems_score_HEADERS += include/rtems/score/schedulersimplesmp.h
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index 4ea7354..cb09c95 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -42,6 +42,8 @@ typedef CPU_atomic_Pointer Atomic_Pointer;
typedef CPU_atomic_Flag Atomic_Flag;
+typedef CPU_atomic_Order Atomic_Order;
#define ATOMIC_ORDER_RELAXED CPU_ATOMIC_ORDER_RELAXED
#define ATOMIC_ORDER_ACQUIRE CPU_ATOMIC_ORDER_ACQUIRE
diff --git a/cpukit/score/include/rtems/score/cpustdatomic.h b/cpukit/score/include/rtems/score/cpustdatomic.h
index a9b8eae..1c216a2 100644
--- a/cpukit/score/include/rtems/score/cpustdatomic.h
+++ b/cpukit/score/include/rtems/score/cpustdatomic.h
@@ -6,6 +6,7 @@
* COPYRIGHT (c) 2013 Deng Hengyi.
+ * Copyright (c) 2015 embedded brains GmbH.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -15,20 +16,29 @@
#ifndef _RTEMS_SCORE_CPUSTDATOMIC_H
#define _RTEMS_SCORE_CPUSTDATOMIC_H
-#include <stdint.h>
-#if defined(__cplusplus) && __GNUC__ >= 4 && __GNUC_MINOR__ >= 9
- * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
- * suggested solution was to include <atomic> in case C++ is used. This works
- * at least with GCC 4.9. See also:
- * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
- * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
-#include <atomic>
+#include <rtems/score/basedefs.h>
+#ifdef RTEMS_SMP
+ #if defined(__cplusplus) && __GNUC__ >= 4 && __GNUC_MINOR__ >= 9
+ * The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible. The
+ * suggested solution was to include <atomic> in case C++ is used. This works
+ * at least with GCC 4.9. See also:
+ * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
+ * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
+ #include <atomic>
+ #define _RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC
+ #else
+ #include <stdatomic.h>
+ #define _RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC
+ #endif
+#else
+ #include <rtems/score/isrlevel.h>
+#endif
+#if defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_ATOMIC)
typedef std::atomic_uint CPU_atomic_Uint;
@@ -38,6 +48,8 @@ typedef std::atomic_uintptr_t CPU_atomic_Pointer;
typedef std::atomic_flag CPU_atomic_Flag;
+typedef std::memory_order CPU_atomic_Order;
#define CPU_ATOMIC_ORDER_RELAXED std::memory_order_relaxed
#define CPU_ATOMIC_ORDER_ACQUIRE std::memory_order_acquire
@@ -55,98 +67,7 @@ typedef std::atomic_flag CPU_atomic_Flag;
#define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
-#define _CPU_atomic_Fence( order ) atomic_thread_fence( order )
-#define _CPU_atomic_Init_uint( obj, desired ) \
- (obj)->store( desired )
-#define _CPU_atomic_Init_ulong( obj, desired ) \
-#define _CPU_atomic_Init_ptr( obj, desired ) \
-#define _CPU_atomic_Load_uint( obj, order ) \
- (obj)->load( order )
-#define _CPU_atomic_Load_ulong( obj, order ) \
-#define _CPU_atomic_Load_ptr( obj, order ) \
- (void *) (obj)->load( order )
-#define _CPU_atomic_Store_uint( obj, desr, order ) \
- (obj)->store( desr, order )
-#define _CPU_atomic_Store_ulong( obj, desr, order ) \
-#define _CPU_atomic_Store_ptr( obj, desr, order ) \
- (obj)->store( (uintptr_t) desr, order )
-#define _CPU_atomic_Fetch_add_uint( obj, arg, order ) \
- (obj)->fetch_add( arg, order )
-#define _CPU_atomic_Fetch_add_ulong( obj, arg, order ) \
-#define _CPU_atomic_Fetch_add_ptr( obj, arg, order ) \
- (obj)->fetch_add( arg, (uintptr_t) order )
-#define _CPU_atomic_Fetch_sub_uint( obj, arg, order ) \
- (obj)->fetch_sub( arg, order )
-#define _CPU_atomic_Fetch_sub_ulong( obj, arg, order ) \
-#define _CPU_atomic_Fetch_sub_ptr( obj, arg, order ) \
- (obj)->fetch_sub( arg, (uintptr_t) order )
-#define _CPU_atomic_Fetch_or_uint( obj, arg, order ) \
- (obj)->fetch_or( arg, order )
-#define _CPU_atomic_Fetch_or_ulong( obj, arg, order ) \
-#define _CPU_atomic_Fetch_or_ptr( obj, arg, order ) \
- (obj)->fetch_or( arg, (uintptr_t) order )
-#define _CPU_atomic_Fetch_and_uint( obj, arg, order ) \
- (obj)->fetch_and( arg, order )
-#define _CPU_atomic_Fetch_and_ulong( obj, arg, order ) \
-#define _CPU_atomic_Fetch_and_ptr( obj, arg, order ) \
- (obj)->fetch_and( arg, (uintptr_t) order )
-#define _CPU_atomic_Exchange_uint( obj, desr, order ) \
- (obj)->exchange( desr, order )
-#define _CPU_atomic_Exchange_ulong( obj, desr, order ) \
-#define _CPU_atomic_Exchange_ptr( obj, desr, order ) \
- (void *) (obj)->exchange( desr, (uintptr_t) order )
-#define _CPU_atomic_Compare_exchange_uint( obj, expected, desired, succ, fail ) \
- (obj)->compare_exchange_strong( expected, desired, succ, fail )
-#define _CPU_atomic_Compare_exchange_ulong( obj, expected, desired, succ, fail ) \
-#define _CPU_atomic_Compare_exchange_ptr( obj, expected, desired, succ, fail ) \
- (obj)->compare_exchange_strong( (void **) expected, (uintptr_t) desired, succ, fail )
-#define _CPU_atomic_Flag_clear( obj, order ) \
- (obj)->clear( order )
-#define _CPU_atomic_Flag_test_and_set( obj, order ) \
- (obj)->test_and_set( order )
-#else /* __cplusplus */
-#include <stdatomic.h>
+#elif defined(_RTEMS_SCORE_CPUSTDATOMIC_USE_STDATOMIC)
typedef atomic_uint CPU_atomic_Uint;
@@ -156,6 +77,8 @@ typedef atomic_uintptr_t CPU_atomic_Pointer;
typedef atomic_flag CPU_atomic_Flag;
+typedef memory_order CPU_atomic_Order;
#define CPU_ATOMIC_ORDER_RELAXED memory_order_relaxed
#define CPU_ATOMIC_ORDER_ACQUIRE memory_order_acquire
@@ -173,95 +96,552 @@ typedef atomic_flag CPU_atomic_Flag;
- atomic_init( obj, desired )
- atomic_init( obj, (uintptr_t) desired )
- atomic_load_explicit( obj, order )
- (void *) atomic_load_explicit( obj, order )
- atomic_store_explicit( obj, desr, order )
- atomic_fetch_add_explicit( obj, arg, order )
- atomic_fetch_sub_explicit( obj, arg, order )
- atomic_fetch_or_explicit( obj, arg, order )
- atomic_fetch_and_explicit( obj, arg, order )
- atomic_exchange_explicit( obj, desr, order )
- atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail )
- atomic_flag_clear_explicit( obj, order )
- atomic_flag_test_and_set_explicit( obj, order )
-#endif /* __cplusplus */
+#else
+typedef unsigned int CPU_atomic_Uint;
+typedef unsigned long CPU_atomic_Ulong;
+typedef uintptr_t CPU_atomic_Pointer;
+typedef bool CPU_atomic_Flag;
+typedef int CPU_atomic_Order;
+#define CPU_ATOMIC_ORDER_RELAXED 0
+#define CPU_ATOMIC_ORDER_ACQUIRE 2
+#define CPU_ATOMIC_ORDER_RELEASE 3
+#define CPU_ATOMIC_ORDER_SEQ_CST 5
+#define CPU_ATOMIC_INITIALIZER_UINT( value ) ( value )
+#define CPU_ATOMIC_INITIALIZER_ULONG( value ) ( value )
+#define CPU_ATOMIC_INITIALIZER_PTR( value ) ( (uintptr_t) (value) )
+#define CPU_ATOMIC_INITIALIZER_FLAG false
+#endif
+static inline void _CPU_atomic_Fence( CPU_atomic_Order order )
+ std::atomic_thread_fence( order );
+ atomic_thread_fence( order );
+#else
+ (void) order;
+ RTEMS_COMPILER_MEMORY_BARRIER();
+#endif
+static inline void _CPU_atomic_Init_uint( CPU_atomic_Uint *obj, unsigned int desired )
+ obj->store( desired );
+ atomic_init( obj, desired );
+#else
+ *obj = desired;
+#endif
+static inline void _CPU_atomic_Init_ulong( CPU_atomic_Ulong *obj, unsigned long desired )
+#else
+ *obj = desired;
+#endif
+static inline void _CPU_atomic_Init_ptr( CPU_atomic_Pointer *obj, void *desired )
+ obj->store( (uintptr_t) desired );
+ atomic_init( obj, (uintptr_t) desired );
+#else
+ *obj = (uintptr_t) desired;
+#endif
+static inline unsigned int _CPU_atomic_Load_uint( const CPU_atomic_Uint *obj, CPU_atomic_Order order )
+ return obj->load( order );
+ return atomic_load_explicit( obj, order );
+#else
+ (void) order;
+ return *obj;
+#endif
+static inline unsigned long _CPU_atomic_Load_ulong( const CPU_atomic_Ulong *obj, CPU_atomic_Order order )
+#else
+ (void) order;
+ return *obj;
+#endif
+static inline void *_CPU_atomic_Load_ptr( const CPU_atomic_Pointer *obj, CPU_atomic_Order order )
+ return (void *) obj->load( order );
+ return (void *) atomic_load_explicit( obj, order );
+#else
+ (void) order;
+ return (void *) *obj;
+#endif
+static inline void _CPU_atomic_Store_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
+ atomic_store_explicit( obj, desired, order );
+#else
+ (void) order;
+ *obj = desired;
+#endif
+static inline void _CPU_atomic_Store_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
+#else
+ (void) order;
+ *obj = desired;
+#endif
+static inline void _CPU_atomic_Store_ptr( CPU_atomic_Pointer *obj, void *desired, CPU_atomic_Order order )
+ atomic_store_explicit( obj, (uintptr_t) desired, order );
+#else
+ (void) order;
+#endif
+static inline unsigned int _CPU_atomic_Fetch_add_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
+ return obj->fetch_add( arg, order );
+ return atomic_fetch_add_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ _ISR_Disable( level );
+ val = *obj;
+ *obj = val + arg;
+ _ISR_Enable( level );
+ return val;
+#endif
+static inline unsigned long _CPU_atomic_Fetch_add_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
+#else
+ unsigned long val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val + arg;
+ return val;
+#endif
+static inline void *_CPU_atomic_Fetch_add_ptr( CPU_atomic_Pointer *obj, void *arg, CPU_atomic_Order order )
+ return (void *) obj->fetch_add( (uintptr_t) arg, order );
+ return (void *) atomic_fetch_add_explicit( obj, (uintptr_t) arg, order );
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val + (uintptr_t) arg;
+ return (void *) val;
+#endif
+static inline unsigned int _CPU_atomic_Fetch_sub_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
+ return obj->fetch_sub( arg, order );
+ return atomic_fetch_sub_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val - arg;
+ return val;
+#endif
+static inline unsigned long _CPU_atomic_Fetch_sub_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val - arg;
+ return val;
+#endif
+static inline void *_CPU_atomic_Fetch_sub_ptr( CPU_atomic_Pointer *obj, void *arg, CPU_atomic_Order order )
+ return (void *) obj->fetch_sub( (uintptr_t) arg, order );
+ return (void *) atomic_fetch_sub_explicit( obj, (uintptr_t) arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val - (uintptr_t) arg;
+#endif
+static inline unsigned int _CPU_atomic_Fetch_or_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
+ return obj->fetch_or( arg, order );
+ return atomic_fetch_or_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val | arg;
+ return val;
+#endif
+static inline unsigned long _CPU_atomic_Fetch_or_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val | arg;
+ return val;
+#endif
+static inline void *_CPU_atomic_Fetch_or_ptr( CPU_atomic_Pointer *obj, void *arg, CPU_atomic_Order order )
+ return (void *) obj->fetch_or( (uintptr_t) arg, order );
+ return (void *) atomic_fetch_or_explicit( obj, (uintptr_t) arg, order );
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val | (uintptr_t) arg;
+#endif
+static inline unsigned int _CPU_atomic_Fetch_and_uint( CPU_atomic_Uint *obj, unsigned int arg, CPU_atomic_Order order )
+ return obj->fetch_and( arg, order );
+ return atomic_fetch_and_explicit( obj, arg, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val & arg;
+ return val;
+#endif
+static inline unsigned long _CPU_atomic_Fetch_and_ulong( CPU_atomic_Ulong *obj, unsigned long arg, CPU_atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val & arg;
+ return val;
+#endif
+static inline void *_CPU_atomic_Fetch_and_ptr( CPU_atomic_Pointer *obj, void *arg, CPU_atomic_Order order )
+ return (void *) obj->fetch_and( (uintptr_t) arg, order );
+ return (void *) atomic_fetch_and_explicit( obj, (uintptr_t) arg, order );
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = val & (uintptr_t) arg;
+#endif
+static inline unsigned int _CPU_atomic_Exchange_uint( CPU_atomic_Uint *obj, unsigned int desired, CPU_atomic_Order order )
+ return obj->exchange( desired, order );
+ return atomic_exchange_explicit( obj, desired, order );
+#else
+ unsigned int val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = desired;
+ return val;
+#endif
+static inline unsigned long _CPU_atomic_Exchange_ulong( CPU_atomic_Ulong *obj, unsigned long desired, CPU_atomic_Order order )
+#else
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+ *obj = desired;
+ return val;
+#endif
+static inline void *_CPU_atomic_Exchange_ptr( CPU_atomic_Pointer *obj, void *desired, CPU_atomic_Order order )
+ return (void *) obj->exchange( (uintptr_t) desired, order );
+ return (void *) atomic_exchange_explicit( obj, (uintptr_t) desired, order );
+#else
+ uintptr_t val;
+ ISR_Level level;
+ (void) order;
+ val = *obj;
+#endif
+static inline bool _CPU_atomic_Compare_exchange_uint( CPU_atomic_Uint *obj, unsigned int *expected, unsigned int desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
+ return obj->compare_exchange_strong( expected, desired, succ, fail );
+ return atomic_compare_exchange_strong_explicit( obj, expected, desired, succ, fail );
+#else
+ bool success;
+ ISR_Level level;
+ (void) succ;
+ (void) fail;
+ success = *obj == *expected;
+ if ( success ) {
+ *obj = desired;
+ return success;
+#endif
+static inline bool _CPU_atomic_Compare_exchange_ulong( CPU_atomic_Ulong *obj, unsigned long *expected, unsigned long desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
+#else
+ bool success;
+ ISR_Level level;
+ (void) succ;
+ (void) fail;
+ if ( success ) {
+ *obj = desired;
+ return success;
+#endif
+static inline bool _CPU_atomic_Compare_exchange_ptr( CPU_atomic_Pointer *obj, void **expected, void *desired, CPU_atomic_Order succ, CPU_atomic_Order fail )
+ return obj->compare_exchange_strong( (uintptr_t *) expected, (uintptr_t) desired, succ, fail );
+ return atomic_compare_exchange_strong_explicit( obj, (uintptr_t *) expected, (uintptr_t) desired, succ, fail );
+#else
+ bool success;
+ ISR_Level level;
+ (void) succ;
+ (void) fail;
+ success = *obj == (uintptr_t) *expected;
+ if ( success ) {
+ return success;
+#endif
+static inline void _CPU_atomic_Flag_clear( CPU_atomic_Flag *obj, CPU_atomic_Order order )
+ obj->clear( order );
+ atomic_flag_clear_explicit( obj, order );
+#else
+ (void) order;
+ *obj = false;
+#endif
+static inline bool _CPU_atomic_Flag_test_and_set( CPU_atomic_Flag *obj, CPU_atomic_Order order )
+ return obj->test_and_set( order );
+ return atomic_flag_test_and_set_explicit( obj, order );
+#else
+ bool flag;
+ ISR_Level level;
+ (void) order;
+ flag = *obj;
+ *obj = true;
+ return flag;
+#endif
#endif /* _RTEMS_SCORE_CPUSTDATOMIC_H */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 891c21e..920c0d9 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -51,6 +51,10 @@ $(PROJECT_INCLUDE)/rtems/score/assert.h: include/rtems/score/assert.h $(PROJECT_
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/assert.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/assert.h
+$(PROJECT_INCLUDE)/rtems/score/atomic.h: include/rtems/score/atomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/atomic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/atomic.h
$(PROJECT_INCLUDE)/rtems/score/chain.h: include/rtems/score/chain.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/chain.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/chain.h
@@ -107,6 +111,10 @@ $(PROJECT_INCLUDE)/rtems/score/cpusetimpl.h: include/rtems/score/cpusetimpl.h $(
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpusetimpl.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpusetimpl.h
+$(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h: include/rtems/score/cpustdatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
$(PROJECT_INCLUDE)/rtems/score/heap.h: include/rtems/score/heap.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/heap.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/heap.h
@@ -398,14 +406,6 @@ $(PROJECT_INCLUDE)/rtems/score/threadmp.h: include/rtems/score/threadmp.h $(PROJ
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/threadmp.h
endif
if HAS_SMP
-$(PROJECT_INCLUDE)/rtems/score/atomic.h: include/rtems/score/atomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/atomic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/atomic.h
-$(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h: include/rtems/score/cpustdatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
$(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmpimpl.h: include/rtems/score/schedulerprioritysmpimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmpimpl.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/schedulerprioritysmpimpl.h
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 283200b..cc28dee 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -389,63 +389,12 @@ static void worker_task(size_t worker_index)
rtems_test_assert(0);
-static void test_static_and_dynamic_initialization(void)
- static Atomic_Uint static_uint =
- ATOMIC_INITIALIZER_UINT(0xc01dc0feU);
- static Atomic_Ulong static_ulong =
- ATOMIC_INITIALIZER_ULONG(0xdeadbeefUL);
- static Atomic_Pointer static_ptr =
- ATOMIC_INITIALIZER_PTR(&static_ptr);
- static Atomic_Flag static_flag = ATOMIC_INITIALIZER_FLAG;
- Atomic_Uint stack_uint;
- Atomic_Ulong stack_ulong;
- Atomic_Pointer stack_ptr;
- Atomic_Flag stack_flag;
- puts("=== static and dynamic initialization test case ===");
- _Atomic_Init_uint(&stack_uint, 0xc01dc0feU);
- _Atomic_Init_ulong(&stack_ulong, 0xdeadbeefUL);
- _Atomic_Init_ptr(&stack_ptr, &static_ptr);
- _Atomic_Flag_clear(&stack_flag, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(
- memcmp(&stack_uint, &static_uint, sizeof(stack_uint)) == 0
- memcmp(&stack_ulong, &static_ulong, sizeof(stack_ulong)) == 0
- memcmp(&stack_ptr, &static_ptr, sizeof(stack_ptr)) == 0
- memcmp(&stack_flag, &static_flag, sizeof(stack_flag)) == 0
- _Atomic_Load_uint(&stack_uint, ATOMIC_ORDER_RELAXED) == 0xc01dc0feU
- _Atomic_Load_ulong(&stack_ulong, ATOMIC_ORDER_RELAXED) == 0xdeadbeefUL
- _Atomic_Load_ptr(&stack_ptr, ATOMIC_ORDER_RELAXED) == &static_ptr
- !_Atomic_Flag_test_and_set(&stack_flag, ATOMIC_ORDER_RELAXED)
static void test(void)
test_context *ctx = &test_instance;
rtems_status_code sc;
size_t worker_index;
- test_static_and_dynamic_initialization();
ctx->worker_count = rtems_get_processor_count();
sc = rtems_timer_create(
@@ -474,159 +423,10 @@ static void test(void)
run_tests(ctx, 0);
-typedef void (*simple_test_body)(test_context *ctx);
-static void test_simple_atomic_add_body(test_context *ctx)
- unsigned int ia = 8, ib = 4;
- unsigned int ic;
- unsigned long a = 2, b = 1;
- unsigned long c;
- puts("=== atomic simple add test case ===\n");
- _Atomic_Store_uint(&ctx->atomic_int_value, ia, ATOMIC_ORDER_RELAXED);
- _Atomic_Fetch_add_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
- ic = _Atomic_Load_uint(&ctx->atomic_int_value, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(ic == (ia + ib));
- _Atomic_Store_ulong(&ctx->atomic_value, a, ATOMIC_ORDER_RELAXED);
- _Atomic_Fetch_add_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
- c = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(c == (a + b));
-static void test_simple_atomic_sub_body(test_context *ctx)
- unsigned int ic;
- unsigned long c;
- puts("=== atomic simple sub test case ===\n");
- _Atomic_Fetch_sub_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(ic == (ia - ib));
- _Atomic_Fetch_sub_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(c == (a - b));
-static void test_simple_atomic_or_body(test_context *ctx)
- unsigned int ic;
- unsigned long c;
- puts("=== atomic simple or test case ===\n");
- _Atomic_Fetch_or_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(ic == (ia | ib));
- _Atomic_Fetch_or_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(c == (a | b));
-static void test_simple_atomic_and_body(test_context *ctx)
- unsigned int ic;
- unsigned long c;
- puts("=== atomic simple and test case ===\n");
- _Atomic_Fetch_and_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(ic == (ia & ib));
- _Atomic_Fetch_and_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(c == (a & b));
-static void test_simple_atomic_exchange_body(test_context *ctx)
- unsigned int ic;
- unsigned long c;
- puts("=== atomic simple exchange test case ===\n");
- _Atomic_Exchange_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(ic == ib);
- _Atomic_Exchange_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
- rtems_test_assert(c == b);
-static void test_simple_atomic_compare_exchange_body(test_context *ctx)
- unsigned int ic;
- unsigned long c;
- puts("=== atomic simple compare exchange test case ===\n");
- _Atomic_Compare_exchange_uint(&ctx->atomic_int_value, &ia, ib,
- ATOMIC_ORDER_RELAXED, ATOMIC_ORDER_RELAXED);
- _Atomic_Compare_exchange_ulong(&ctx->atomic_value, &a, b,
-static const simple_test_body simple_test_bodies[] = {
- test_simple_atomic_add_body,
- test_simple_atomic_sub_body,
- test_simple_atomic_or_body,
- test_simple_atomic_and_body,
- test_simple_atomic_exchange_body,
- test_simple_atomic_compare_exchange_body,
-#define SIMPLE_TEST_COUNT RTEMS_ARRAY_SIZE(simple_test_bodies)
-static void simple_tests(void)
- test_context *ctx = &test_instance;
- size_t test;
- for (test = 0; test < SIMPLE_TEST_COUNT; ++test) {
- const simple_test_body *test_body = &simple_test_bodies[test];
- (*test_body)(ctx);
static void Init(rtems_task_argument arg)
TEST_BEGIN();
- simple_tests();
test();
TEST_END();
diff --git a/testsuites/smptests/smpatomic01/smpatomic01.scn b/testsuites/smptests/smpatomic01/smpatomic01.scn
index 4a8c230..89b1980 100644
--- a/testsuites/smptests/smpatomic01/smpatomic01.scn
+++ b/testsuites/smptests/smpatomic01/smpatomic01.scn
@@ -1,11 +1,4 @@
*** TEST SMPATOMIC 1 ***
-=== atomic simple add test case ===
-=== atomic simple sub test case ===
-=== atomic simple or test case ===
-=== atomic simple and test case ===
-=== atomic simple exchange test case ===
-=== atomic simple compare exchange test case ===
-=== static and dynamic initialization test case ====
=== atomic add test case ===
worker 0 value: 16686
worker 1 value: 36405
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 2bbe661..bcb9326 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -37,6 +37,7 @@ if HAS_SMP
else
_SUBDIRS += sp29
endif
+_SUBDIRS += spatomic01
_SUBDIRS += spintrcritical22
_SUBDIRS += spsem03
_SUBDIRS += spresource01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 47a9d3f..9534b4e 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -40,6 +40,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
# Explicitly list all Makefiles here
AC_CONFIG_FILES([Makefile
+spatomic01/Makefile
spglobalcon01/Makefile
spintrcritical22/Makefile
spsem03/Makefile
diff --git a/testsuites/sptests/spatomic01/Makefile.am b/testsuites/sptests/spatomic01/Makefile.am
new file mode 100644
index 0000000..abb5209
--- /dev/null
+++ b/testsuites/sptests/spatomic01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spatomic01
+spatomic01_SOURCES = init.c
+dist_rtems_tests_DATA = spatomic01.scn spatomic01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spatomic01_OBJECTS)
+LINK_LIBS = $(spatomic01_LDLIBS)
+spatomic01$(EXEEXT): $(spatomic01_OBJECTS) $(spatomic01_DEPENDENCIES)
+ @rm -f spatomic01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spatomic01/init.c b/testsuites/sptests/spatomic01/init.c
index 0000000..f98c550
--- /dev/null
+++ b/testsuites/sptests/spatomic01/init.c
@@ -0,0 +1,254 @@
+ * Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * Copyright (c) 2013 Deng Hengyi.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/atomic.h>
+#include <stdio.h>
+#include <rtems.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SPATOMIC 1";
+typedef struct {
+ Atomic_Uint atomic_int_value;
+ Atomic_Ulong atomic_value;
+} test_context;
+static test_context test_instance;
+static void test_static_and_dynamic_initialization(void)
+ static Atomic_Uint static_uint =
+ ATOMIC_INITIALIZER_UINT(0xc01dc0feU);
+ static Atomic_Ulong static_ulong =
+ ATOMIC_INITIALIZER_ULONG(0xdeadbeefUL);
+ static Atomic_Pointer static_ptr =
+ ATOMIC_INITIALIZER_PTR(&static_ptr);
+ static Atomic_Flag static_flag = ATOMIC_INITIALIZER_FLAG;
+ Atomic_Uint stack_uint;
+ Atomic_Ulong stack_ulong;
+ Atomic_Pointer stack_ptr;
+ Atomic_Flag stack_flag;
+ puts("=== static and dynamic initialization test case ===");
+ _Atomic_Init_uint(&stack_uint, 0xc01dc0feU);
+ _Atomic_Init_ulong(&stack_ulong, 0xdeadbeefUL);
+ _Atomic_Init_ptr(&stack_ptr, &static_ptr);
+ _Atomic_Flag_clear(&stack_flag, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(
+ memcmp(&stack_uint, &static_uint, sizeof(stack_uint)) == 0
+ memcmp(&stack_ulong, &static_ulong, sizeof(stack_ulong)) == 0
+ memcmp(&stack_ptr, &static_ptr, sizeof(stack_ptr)) == 0
+ memcmp(&stack_flag, &static_flag, sizeof(stack_flag)) == 0
+ _Atomic_Load_uint(&stack_uint, ATOMIC_ORDER_RELAXED) == 0xc01dc0feU
+ _Atomic_Load_ulong(&stack_ulong, ATOMIC_ORDER_RELAXED) == 0xdeadbeefUL
+ _Atomic_Load_ptr(&stack_ptr, ATOMIC_ORDER_RELAXED) == &static_ptr
+ !_Atomic_Flag_test_and_set(&stack_flag, ATOMIC_ORDER_RELAXED)
+typedef void (*simple_test_body)(test_context *ctx);
+static void test_simple_atomic_add_body(test_context *ctx)
+ unsigned int ia = 8, ib = 4;
+ unsigned int ic;
+ unsigned long a = 2, b = 1;
+ unsigned long c;
+ puts("=== atomic simple add test case ===");
+ _Atomic_Store_uint(&ctx->atomic_int_value, ia, ATOMIC_ORDER_RELAXED);
+ _Atomic_Fetch_add_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
+ ic = _Atomic_Load_uint(&ctx->atomic_int_value, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(ic == (ia + ib));
+ _Atomic_Store_ulong(&ctx->atomic_value, a, ATOMIC_ORDER_RELAXED);
+ _Atomic_Fetch_add_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ c = _Atomic_Load_ulong(&ctx->atomic_value, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a + b));
+static void test_simple_atomic_sub_body(test_context *ctx)
+ unsigned int ic;
+ unsigned long c;
+ puts("=== atomic simple sub test case ===");
+ _Atomic_Fetch_sub_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(ic == (ia - ib));
+ _Atomic_Fetch_sub_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a - b));
+static void test_simple_atomic_or_body(test_context *ctx)
+ unsigned int ic;
+ unsigned long c;
+ puts("=== atomic simple or test case ===");
+ _Atomic_Fetch_or_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(ic == (ia | ib));
+ _Atomic_Fetch_or_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a | b));
+static void test_simple_atomic_and_body(test_context *ctx)
+ unsigned int ic;
+ unsigned long c;
+ puts("=== atomic simple and test case ===");
+ _Atomic_Fetch_and_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(ic == (ia & ib));
+ _Atomic_Fetch_and_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == (a & b));
+static void test_simple_atomic_exchange_body(test_context *ctx)
+ unsigned int ic;
+ unsigned long c;
+ puts("=== atomic simple exchange test case ===");
+ _Atomic_Exchange_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(ic == ib);
+ _Atomic_Exchange_ulong(&ctx->atomic_value, b, ATOMIC_ORDER_RELAXED);
+ rtems_test_assert(c == b);
+static void test_simple_atomic_compare_exchange_body(test_context *ctx)
+ unsigned int ic;
+ unsigned long c;
+ puts("=== atomic simple compare exchange test case ===");
+ _Atomic_Compare_exchange_uint(&ctx->atomic_int_value, &ia, ib,
+ ATOMIC_ORDER_RELAXED, ATOMIC_ORDER_RELAXED);
+ _Atomic_Compare_exchange_ulong(&ctx->atomic_value, &a, b,
+static const simple_test_body simple_test_bodies[] = {
+ test_simple_atomic_add_body,
+ test_simple_atomic_sub_body,
+ test_simple_atomic_or_body,
+ test_simple_atomic_and_body,
+ test_simple_atomic_exchange_body,
+ test_simple_atomic_compare_exchange_body,
+#define SIMPLE_TEST_COUNT RTEMS_ARRAY_SIZE(simple_test_bodies)
+static void simple_tests(void)
+ test_context *ctx = &test_instance;
+ size_t test;
+ for (test = 0; test < SIMPLE_TEST_COUNT; ++test) {
+ const simple_test_body *test_body = &simple_test_bodies[test];
+ (*test_body)(ctx);
+static void Init(rtems_task_argument arg)
+ TEST_BEGIN();
+ test_static_and_dynamic_initialization();
+ simple_tests();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spatomic01/spatomic01.doc b/testsuites/sptests/spatomic01/spatomic01.doc
index 0000000..85fae09
--- /dev/null
+++ b/testsuites/sptests/spatomic01/spatomic01.doc
@@ -0,0 +1,37 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spatomic01
+directives:
+ - ATOMIC_INITIALIZER_FLAG
+ - ATOMIC_INITIALIZER_PTR()
+ - ATOMIC_INITIALIZER_UINT()
+ - ATOMIC_INITIALIZER_ULONG()
+ - _Atomic_Compare_exchange_uint()
+ - _Atomic_Compare_exchange_ulong()
+ - _Atomic_Exchange_uint()
+ - _Atomic_Exchange_ulong()
+ - _Atomic_Fence()
+ - _Atomic_Fetch_add_uint()
+ - _Atomic_Fetch_add_ulong()
+ - _Atomic_Fetch_and_uint()
+ - _Atomic_Fetch_and_ulong()
+ - _Atomic_Fetch_or_uint()
+ - _Atomic_Fetch_or_ulong()
+ - _Atomic_Fetch_sub_uint()
+ - _Atomic_Fetch_sub_ulong()
+ - _Atomic_Flag_clear()
+ - _Atomic_Flag_test_and_set()
+ - _Atomic_Init_ptr()
+ - _Atomic_Init_uint()
+ - _Atomic_Init_ulong()
+ - _Atomic_Load_ptr()
+ - _Atomic_Load_uint()
+ - _Atomic_Load_ulong()
+ - _Atomic_Store_uint()
+ - _Atomic_Store_ulong()
+concepts:
+ - Ensure that the atomic operations work.
diff --git a/testsuites/sptests/spatomic01/spatomic01.scn b/testsuites/sptests/spatomic01/spatomic01.scn
index 0000000..237efde
--- /dev/null
+++ b/testsuites/sptests/spatomic01/spatomic01.scn
@@ -0,0 +1,9 @@
+*** BEGIN OF TEST SPATOMIC 1 ***
+=== static and dynamic initialization test case ===
+=== atomic simple add test case ===
+=== atomic simple sub test case ===
+=== atomic simple or test case ===
+=== atomic simple and test case ===
+=== atomic simple exchange test case ===
+=== atomic simple compare exchange test case ===
+*** END OF TEST SPATOMIC 1 ***
2.1.4
