[PATCH 3/4] Filesystem: Use rtems_libio_iop_to_descriptor()
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Feb 2 14:37:42 UTC 2015
On 2/2/2015 8:25 AM, Sebastian Huber wrote:
> Drop parameter check from previously unused
> rtems_libio_iop_to_descriptor().
> cpukit/libcsupport/include/rtems/libio_.h | 2 +-
> cpukit/libcsupport/src/fcntl.c | 2 +-
> cpukit/libcsupport/src/open.c | 2 +-
> cpukit/libnetworking/rtems/rtems_syscall.c | 2 +-
> 4 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
> index d021c1b..1300d39 100644
> --- a/cpukit/libcsupport/include/rtems/libio_.h
> +++ b/cpukit/libcsupport/include/rtems/libio_.h
> @@ -107,7 +107,7 @@ extern rtems_filesystem_global_location_t rtems_filesystem_global_location_null;
> #define rtems_libio_iop_to_descriptor(_iop) \
> - ((!(_iop)) ? -1 : (_iop - rtems_libio_iops))
> + ((_iop) - &rtems_libio_iops[0])
You dropped a NULL check. What is the rationale? Should it be
a debug assert?
> * rtems_libio_check_is_open
> diff --git a/cpukit/libcsupport/src/fcntl.c b/cpukit/libcsupport/src/fcntl.c
> index 5a10f91..ddaf447 100644
> --- a/cpukit/libcsupport/src/fcntl.c
> +++ b/cpukit/libcsupport/src/fcntl.c
> @@ -47,7 +47,7 @@ static int duplicate_iop( rtems_libio_t *iop )
> rv = (*diop->pathinfo.handlers->open_h)( diop, NULL, oflag, 0 );
> if ( rv == 0 ) {
> - rv = diop - rtems_libio_iops;
> + rv = rtems_libio_iop_to_descriptor( diop );
> } else {
> rtems_libio_free( diop );
> diff --git a/cpukit/libcsupport/src/open.c b/cpukit/libcsupport/src/open.c
> index 399b5a4..4fb2ea2 100644
> --- a/cpukit/libcsupport/src/open.c
> +++ b/cpukit/libcsupport/src/open.c
> @@ -66,7 +66,7 @@ static int do_open(
> int rv = 0;
> - int fd = iop - rtems_libio_iops;
> + int fd = rtems_libio_iop_to_descriptor( iop );
> int rwflag = oflag + 1;
> bool read_access = (rwflag & _FREAD) == _FREAD;
> bool write_access = (rwflag & _FWRITE) == _FWRITE;
> diff --git a/cpukit/libnetworking/rtems/rtems_syscall.c b/cpukit/libnetworking/rtems/rtems_syscall.c
> index 1063798..c0dccf6 100644
> --- a/cpukit/libnetworking/rtems/rtems_syscall.c
> +++ b/cpukit/libnetworking/rtems/rtems_syscall.c
> @@ -83,7 +83,7 @@ rtems_bsdnet_makeFdForSocket (void *so)
> if (iop == 0)
> rtems_set_errno_and_return_minus_one( ENFILE );
> - fd = iop - rtems_libio_iops;
> + fd = rtems_libio_iop_to_descriptor(iop);
> iop->flags |= LIBIO_FLAGS_WRITE | LIBIO_FLAGS_READ;
> iop->data0 = fd;
> iop->data1 = so;
