[PATCH] arm/tms570: sci context has to be writable because it holds state variable.
Pavel Pisa
pisa at cmp.felk.cvut.cz
Wed Feb 4 17:20:27 UTC 2015
The structure tms570_sci_context holds state variable
tx_chars_in_hw which holds if and how many characters
(in the optional FIFO support for some Ti SCIs) are submitted
into hardware.
When field is not writable then code breaks when RTEMS
is build for Flash area.
The problem found and analyzed by Martin Galvan from tallertechnologies.
Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
c/src/lib/libbsp/arm/tms570/console/tms570-sci.c | 6 +++---
c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h | 2 +-
2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
index 3f10300..d78cf20 100644
--- a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
+++ b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
@@ -40,7 +40,7 @@
* Definitions of all serial drivers
-const tms570_sci_context driver_context_table[] = {
+tms570_sci_context driver_context_table[] = {
.base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("TMS570 SCI1"),
.device_name = "/dev/console",
@@ -91,7 +91,7 @@ rtems_device_driver console_initialize(
minor < RTEMS_ARRAY_SIZE(driver_context_table);
++minor
- const tms570_sci_context *ctx = &driver_context_table[minor];
+ tms570_sci_context *ctx = &driver_context_table[minor];
* Install this device in the file system and Termios. In order
@@ -105,7 +105,7 @@ rtems_device_driver console_initialize(
minor,
handler,
NULL,
- RTEMS_DECONST(rtems_termios_device_context *, &ctx->base)
+ &ctx->base
if ( sc != RTEMS_SUCCESSFUL ) {
bsp_fatal(BSP_FATAL_CONSOLE_NO_DEV);
diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h b/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h
index f32eaea..1d9eaa7 100644
--- a/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h
+++ b/c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h
@@ -47,7 +47,7 @@ extern const rtems_termios_device_handler tms570_sci_handler_polled;
extern const rtems_termios_device_handler tms570_sci_handler_interrupt;
-extern const tms570_sci_context driver_context_table[];
+extern tms570_sci_context driver_context_table[];
1.9.1
