[PATCH 2/7] IMFS: Split linfile and memfile modules
Mon Feb 9 20:35:52 UTC 2015
Make several functions static.
 cpukit/libfs/Makefile.am                      |   7 +-
 cpukit/libfs/src/imfs/imfs.h                  |  62 +-
 cpukit/libfs/src/imfs/imfs_handlers_memfile.c |  87 ---
 cpukit/libfs/src/imfs/imfs_linfile.c          |  97 +++
 cpukit/libfs/src/imfs/imfs_memfile.c          | 860 +++++++++++++++++++++++++
 cpukit/libfs/src/imfs/imfs_stat_file.c        |  33 +
 cpukit/libfs/src/imfs/memfile.c               | 893 --------------------------
 7 files changed, 1004 insertions(+), 1035 deletions(-)
 delete mode 100644 cpukit/libfs/src/imfs/imfs_handlers_memfile.c
 create mode 100644 cpukit/libfs/src/imfs/imfs_linfile.c
 create mode 100644 cpukit/libfs/src/imfs/imfs_memfile.c
 create mode 100644 cpukit/libfs/src/imfs/imfs_stat_file.c
 delete mode 100644 cpukit/libfs/src/imfs/memfile.c
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index 4bff8cf..3c454e7 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -49,13 +49,14 @@ libimfs_a_SOURCES += src/imfs/deviceio.c \
     src/imfs/imfs_fsunmount.c \
     src/imfs/imfs_handlers_device.c \
     src/imfs/imfs_handlers_directory.c \
-    src/imfs/imfs_handlers_memfile.c src/imfs/imfs_init.c \
+    src/imfs/imfs_init.c \
     src/imfs/imfs_initsupp.c src/imfs/imfs_link.c src/imfs/imfs_load_tar.c \
+    src/imfs/imfs_linfile.c \
     src/imfs/imfs_mknod.c src/imfs/imfs_mount.c \
     src/imfs/imfs_rename.c src/imfs/imfs_rmnod.c \
-    src/imfs/imfs_stat.c src/imfs/imfs_symlink.c \
+    src/imfs/imfs_stat.c src/imfs/imfs_stat_file.c src/imfs/imfs_symlink.c \
     src/imfs/imfs_unmount.c src/imfs/imfs_utime.c src/imfs/ioman.c \
-    src/imfs/memfile.c src/imfs/miniimfs_init.c src/imfs/imfs.h
+    src/imfs/imfs_memfile.c src/imfs/miniimfs_init.c src/imfs/imfs.h
 # POSIX FIFO/pipe
 libimfs_a_SOURCES += src/pipe/fifo.c src/pipe/pipe.c src/pipe/pipe.h
diff --git a/cpukit/libfs/src/imfs/imfs.h b/cpukit/libfs/src/imfs/imfs.h
index f69408a..12881c4 100644
--- a/cpukit/libfs/src/imfs/imfs.h
+++ b/cpukit/libfs/src/imfs/imfs.h
@@ -511,6 +511,11 @@ extern int IMFS_stat(
   struct stat *buf
+extern int IMFS_stat_file(
+  const rtems_filesystem_location_info_t *loc,
+  struct stat *buf
  * @brief IMFS evaluation node support.
@@ -711,20 +716,6 @@ extern int IMFS_unmount(
   rtems_filesystem_mount_table_entry_t *mt_entry  /* IN */
-extern void IMFS_memfile_remove(
- IMFS_jnode_t  *the_jnode         /* IN/OUT */
- * @brief Truncate a memory file.
- * This routine processes the ftruncate() system call.
-extern int memfile_ftruncate(
-  rtems_libio_t *iop,               /* IN  */
-  off_t          length             /* IN  */
  * @brief Read the next directory of the IMFS.
@@ -756,44 +747,11 @@ extern ssize_t imfs_dir_read(
- * @brief Open a linear file.
- * Transforms the file into a memfile if opened for writing.
-extern int IMFS_linfile_open(
-  const char    *pathname,        /* IN  */
-  int            oflag,           /* IN  */
-  mode_t         mode             /* IN  */
-extern ssize_t IMFS_linfile_read(
-  void          *buffer,
-  size_t         count
- * @brief Read a memory file.
- * This routine processes the read() system call.
-extern ssize_t memfile_read(
-  void          *buffer,          /* IN  */
-  size_t         count            /* IN  */
- * @brief Write a memory file.
- * This routine processes the write() system call.
-extern ssize_t memfile_write(
-  const void    *buffer,          /* IN  */
+extern ssize_t IMFS_memfile_write(
+  IMFS_memfile_t      *memfile,
+  off_t                start,
+  const unsigned char *source,
+  unsigned int         length
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
deleted file mode 100644
index 1e5dba2..0000000
--- a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
+++ /dev/null
@@ -1,87 +0,0 @@
- * @file
- * @brief Memfile Operations Tables
- * @ingroup IMFS
- *  COPYRIGHT (c) 1989-1999.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include "imfs.h"
-static int IMFS_stat_file(
-  const rtems_filesystem_location_info_t *loc,
-  struct stat *buf
-  const IMFS_file_t *file = loc->node_access;
-  buf->st_size = file->File.size;
-  buf->st_blksize = imfs_rq_memfile_bytes_per_block;
-  return IMFS_stat( loc, buf );
-static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
-  .open_h = rtems_filesystem_default_open,
-  .close_h = rtems_filesystem_default_close,
-  .read_h = memfile_read,
-  .write_h = memfile_write,
-  .ioctl_h = rtems_filesystem_default_ioctl,
-  .lseek_h = rtems_filesystem_default_lseek_file,
-  .fstat_h = IMFS_stat_file,
-  .ftruncate_h = memfile_ftruncate,
-  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
-  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
-  .fcntl_h = rtems_filesystem_default_fcntl,
-  .kqfilter_h = rtems_filesystem_default_kqfilter,
-  .poll_h = rtems_filesystem_default_poll,
-  .readv_h = rtems_filesystem_default_readv,
-  .writev_h = rtems_filesystem_default_writev
-static const rtems_filesystem_file_handlers_r IMFS_linfile_handlers = {
-  .open_h = IMFS_linfile_open,
-  .read_h = IMFS_linfile_read,
-  .write_h = rtems_filesystem_default_write,
-  .ftruncate_h = rtems_filesystem_default_ftruncate,
-const IMFS_mknod_control IMFS_mknod_control_memfile = {
-    .handlers = &IMFS_memfile_handlers,
-    .node_initialize = IMFS_node_initialize_default,
-    .node_remove = IMFS_node_remove_default,
-    .node_destroy = IMFS_memfile_remove
-  .node_size = sizeof( IMFS_file_t )
-const IMFS_node_control IMFS_node_control_linfile = {
-  .handlers = &IMFS_linfile_handlers,
-  .node_destroy = IMFS_node_destroy_default
diff --git a/cpukit/libfs/src/imfs/imfs_linfile.c b/cpukit/libfs/src/imfs/imfs_linfile.c
new file mode 100644
index 0000000..8a14866
--- /dev/null
+++ b/cpukit/libfs/src/imfs/imfs_linfile.c
@@ -0,0 +1,97 @@
+ * @file
+ * @ingroup IMFS
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "imfs.h"
+static ssize_t IMFS_linfile_read(
+  rtems_libio_t *iop,
+  void          *buffer,
+  size_t         count
+  IMFS_file_t *file = IMFS_iop_to_file( iop );
+  off_t start = iop->offset;
+  size_t size = file->File.size;
+  const unsigned char *data = file->Linearfile.direct;
+  if (count > size - start)
+    count = size - start;
+  IMFS_update_atime( &file->Node );
+  iop->offset = start + count;
+  memcpy(buffer, &data[start], count);
+  return (ssize_t) count;
+static int IMFS_linfile_open(
+  const char    *pathname,
+  int            oflag,
+  mode_t         mode
+  IMFS_file_t *file;
+  file = iop->pathinfo.node_access;
+   * Perform 'copy on write' for linear files
+  if ((iop->flags & LIBIO_FLAGS_WRITE) != 0) {
+    uint32_t count = file->File.size;
+    const unsigned char *buffer = file->Linearfile.direct;
+    file->Node.control            = &IMFS_mknod_control_memfile.node_control;
+    file->File.size               = 0;
+    file->Memfile.indirect        = 0;
+    file->Memfile.doubly_indirect = 0;
+    file->Memfile.triply_indirect = 0;
+    if ((count != 0)
+     && (IMFS_memfile_write(&file->Memfile, 0, buffer, count) == -1))
+        return -1;
+  return 0;
+static const rtems_filesystem_file_handlers_r IMFS_linfile_handlers = {
+  .open_h = IMFS_linfile_open,
+  .close_h = rtems_filesystem_default_close,
+  .read_h = IMFS_linfile_read,
+  .write_h = rtems_filesystem_default_write,
+  .ioctl_h = rtems_filesystem_default_ioctl,
+  .lseek_h = rtems_filesystem_default_lseek_file,
+  .fstat_h = IMFS_stat_file,
+  .ftruncate_h = rtems_filesystem_default_ftruncate,
+  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
+  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
+  .fcntl_h = rtems_filesystem_default_fcntl,
+  .kqfilter_h = rtems_filesystem_default_kqfilter,
+  .poll_h = rtems_filesystem_default_poll,
+  .readv_h = rtems_filesystem_default_readv,
+  .writev_h = rtems_filesystem_default_writev
+const IMFS_node_control IMFS_node_control_linfile = {
+  .handlers = &IMFS_linfile_handlers,
+  .node_initialize = IMFS_node_initialize_default,
+  .node_remove = IMFS_node_remove_default,
+  .node_destroy = IMFS_node_destroy_default
diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c b/cpukit/libfs/src/imfs/imfs_memfile.c
index 0000000..2b6a496
--- /dev/null
+++ b/cpukit/libfs/src/imfs/imfs_memfile.c
@@ -0,0 +1,860 @@
+ * @file
+ * @brief IMFS Memory File Handlers
+ * @ingroup IMFS
+ *  COPYRIGHT (c) 1989-2010.
+#if HAVE_CONFIG_H
+#endif
+#include "imfs.h"
+#include <stdlib.h>
+#include <string.h>
+ *  Prototypes of private routines
+static int IMFS_memfile_extend(
+   bool            zero_fill,
+   off_t           new_length
+static int IMFS_memfile_addblock(
+   unsigned int    block
+static void IMFS_memfile_remove_block(
+static block_p *IMFS_memfile_get_block_pointer(
+   unsigned int    block,
+   int             malloc_it
+static ssize_t IMFS_memfile_read(
+   IMFS_file_t     *file,
+   off_t            start,
+   unsigned char   *destination,
+static void *memfile_alloc_block(void);
+static void memfile_free_block(
+  void *memory
+static ssize_t memfile_read(
+  void          *buffer,
+  size_t         count
+  ssize_t      status;
+  status = IMFS_memfile_read( file, iop->offset, buffer, count );
+  if ( status > 0 )
+    iop->offset += status;
+  return status;
+static ssize_t memfile_write(
+  const void    *buffer,
+  size_t         count
+  IMFS_memfile_t *memfile = IMFS_iop_to_memfile( iop );
+  ssize_t         status;
+  if ((iop->flags & LIBIO_FLAGS_APPEND) != 0)
+    iop->offset = memfile->File.size;
+  status = IMFS_memfile_write( memfile, iop->offset, buffer, count );
+  if ( status > 0 )
+  return status;
+ *  memfile_stat
+ *  This IMFS_stat() can be used.
+static int memfile_ftruncate(
+  off_t                 length
+   *  POSIX 1003.1b does not specify what happens if you truncate a file
+   *  and the new length is greater than the current size.  We treat this
+   *  as an extend operation.
+  if ( length > memfile->File.size )
+    return IMFS_memfile_extend( memfile, true, length );
+   *  The in-memory files do not currently reclaim memory until the file is
+   *  deleted.  So we leave the previously allocated blocks in place for
+   *  future use and just set the length.
+  memfile->File.size = length;
+  IMFS_mtime_ctime_update( &memfile->File.Node );
+  return 0;
+ *  IMFS_memfile_extend
+ *  This routine insures that the in-memory file is of the length
+ *  specified.  If necessary, it will allocate memory blocks to
+ *  extend the file.
+   bool            zero_fill,
+   off_t           new_length
+  unsigned int   block;
+  unsigned int   new_blocks;
+  unsigned int   old_blocks;
+  unsigned int   offset;
+   *  Perform internal consistency checks
+  IMFS_assert( memfile );
+   *  Verify new file size is supported
+  if ( new_length >= IMFS_MEMFILE_MAXIMUM_SIZE )
+    rtems_set_errno_and_return_minus_one( EFBIG );
+   *  Verify new file size is actually larger than current size
+  if ( new_length <= memfile->File.size )
+    return 0;
+   *  Calculate the number of range of blocks to allocate
+  new_blocks = new_length / IMFS_MEMFILE_BYTES_PER_BLOCK;
+  old_blocks = memfile->File.size / IMFS_MEMFILE_BYTES_PER_BLOCK;
+  offset = memfile->File.size - old_blocks * IMFS_MEMFILE_BYTES_PER_BLOCK;
+   *  Now allocate each of those blocks.
+  for ( block=old_blocks ; block<=new_blocks ; block++ ) {
+    if ( !IMFS_memfile_addblock( memfile, block ) ) {
+       if ( zero_fill ) {
+          size_t count = IMFS_MEMFILE_BYTES_PER_BLOCK - offset;
+          block_p *block_ptr =
+            IMFS_memfile_get_block_pointer( memfile, block, 0 );
+          memset( &(*block_ptr) [offset], 0, count);
+          offset = 0;
+    } else {
+       for ( ; block>=old_blocks ; block-- ) {
+         IMFS_memfile_remove_block( memfile, block );
+       rtems_set_errno_and_return_minus_one( ENOSPC );
+   *  Set the new length of the file.
+  memfile->File.size = new_length;
+  return 0;
+ *  IMFS_memfile_addblock
+ *  This routine adds a single block to the specified in-memory file.
+  block_p  memory;
+  block_p *block_entry_ptr;
+   * Obtain the pointer for the specified block number
+  block_entry_ptr = IMFS_memfile_get_block_pointer( memfile, block, 1 );
+  if ( !block_entry_ptr )
+    return 1;
+  if ( *block_entry_ptr )
+    return 0;
+   *  There is no memory for this block number so allocate it.
+  memory = memfile_alloc_block();
+  if ( !memory )
+    return 1;
+  *block_entry_ptr = memory;
+  return 0;
+ *  IMFS_memfile_remove_block
+ *  This routine removes the specified block from the in-memory file.
+ *  NOTE:  This is a support routine and is called only to remove
+ *         the last block or set of blocks in a file.  Removing a
+ *         block from the middle of a file would be exceptionally
+ *         dangerous and the results unpredictable.
+  block_p *block_ptr;
+  block_p  ptr;
+  block_ptr = IMFS_memfile_get_block_pointer( memfile, block, 0 );
+  if ( block_ptr ) {
+    ptr = *block_ptr;
+    *block_ptr = 0;
+    memfile_free_block( ptr );
+ *  memfile_free_blocks_in_table
+ *  This is a support routine for IMFS_memfile_remove.  It frees all the
+ *  blocks in one of the indirection tables.
+static void memfile_free_blocks_in_table(
+  block_p **block_table,
+  int       entries
+  int      i;
+  block_p *b;
+  IMFS_assert( block_table );
+   *  Now go through all the slots in the table and free the memory.
+  b = *block_table;
+  for ( i=0 ; i<entries ; i++ ) {
+    if ( b[i] ) {
+      memfile_free_block( b[i] );
+      b[i] = 0;
+   *  Now that all the blocks in the block table are free, we can
+   *  free the block table itself.
+  memfile_free_block( *block_table );
+  *block_table = 0;
+ *  IMFS_memfile_destroy
+ *  This routine frees all memory associated with an in memory file.
+ *  NOTE:  This is an exceptionally conservative implementation.
+ *         It will check EVERY pointer which is non-NULL and insure
+ *         any child non-NULL pointers are freed.  Optimistically, all that
+ *         is necessary is to scan until a NULL pointer is found.  There
+ *         should be no allocated data past that point.
+ *         In experimentation on the powerpc simulator, it was noted
+ *         that using blocks which held 128 slots versus 16 slots made
+ *         a significant difference in the performance of this routine.
+ *         Regardless until the IMFS implementation is proven, it
+ *         is better to stick to simple, easy to understand algorithms.
+static void IMFS_memfile_destroy(
+ IMFS_jnode_t  *the_jnode
+  IMFS_memfile_t  *memfile;
+  int              i;
+  int              j;
+  unsigned int     to_free;
+  block_p         *p;
+  memfile = (IMFS_memfile_t *) the_jnode;
+   *  Eventually this could be set smarter at each call to
+   *  memfile_free_blocks_in_table to greatly speed this up.
+  to_free = IMFS_MEMFILE_BLOCK_SLOTS;
+   *  Now start freeing blocks in this order:
+   *    + indirect
+   *    + doubly indirect
+   *    + triply indirect
+  if ( memfile->indirect ) {
+    memfile_free_blocks_in_table( &memfile->indirect, to_free );
+  if ( memfile->doubly_indirect ) {
+    for ( i=0 ; i<IMFS_MEMFILE_BLOCK_SLOTS ; i++ ) {
+      if ( memfile->doubly_indirect[i] ) {
+         (block_p **)&memfile->doubly_indirect[i], to_free );
+    memfile_free_blocks_in_table( &memfile->doubly_indirect, to_free );
+  if ( memfile->triply_indirect ) {
+      p = (block_p *) memfile->triply_indirect[i];
+      if ( !p )  /* ensure we have a valid pointer */
+         break;
+      for ( j=0 ; j<IMFS_MEMFILE_BLOCK_SLOTS ; j++ ) {
+        if ( p[j] ) {
+          memfile_free_blocks_in_table( (block_p **)&p[j], to_free);
+        (block_p **)&memfile->triply_indirect[i], to_free );
+        (block_p **)&memfile->triply_indirect, to_free );
+  IMFS_node_destroy_default( the_jnode );
+ *  IMFS_memfile_read
+ *  This routine read from memory file pointed to by the_jnode into
+ *  the specified data buffer specified by destination.  The file
+ *  is NOT extended.  An offset greater than the length of the file
+ *  is considered an error.  Read from an offset for more bytes than
+ *  are between the offset and the end of the file will result in
+ *  reading the data between offset and the end of the file (truncated
+ *  read).
+   off_t            start,
+  unsigned int         my_length;
+  unsigned int         to_copy = 0;
+  unsigned int         last_byte;
+  unsigned int         copied;
+  unsigned int         start_offset;
+  unsigned char       *dest;
+  dest = destination;
+  IMFS_assert( file );
+  IMFS_assert( dest );
+   *  Linear files (as created from a tar file are easier to handle
+   *  than block files).
+  my_length = length;
+   *  If the last byte we are supposed to read is past the end of this
+   *  in memory file, then shorten the length to read.
+  last_byte = start + length;
+  if ( last_byte > file->Memfile.File.size )
+    my_length = file->Memfile.File.size - start;
+  copied = 0;
+   *  Three phases to the read:
+   *    + possibly the last part of one block
+   *    + all of zero of more blocks
+   *    + possibly the first part of one block
+   *  Phase 1: possibly the last part of one block
+  start_offset = start % IMFS_MEMFILE_BYTES_PER_BLOCK;
+  block = start / IMFS_MEMFILE_BYTES_PER_BLOCK;
+  if ( start_offset )  {
+    to_copy = IMFS_MEMFILE_BYTES_PER_BLOCK - start_offset;
+    if ( to_copy > my_length )
+      to_copy = my_length;
+    block_ptr = IMFS_memfile_get_block_pointer( &file->Memfile, block, 0 );
+    if ( !block_ptr )
+      return copied;
+    memcpy( dest, &(*block_ptr)[ start_offset ], to_copy );
+    dest += to_copy;
+    block++;
+    my_length -= to_copy;
+    copied += to_copy;
+   *  Phase 2: all of zero of more blocks
+  to_copy = IMFS_MEMFILE_BYTES_PER_BLOCK;
+  while ( my_length >= IMFS_MEMFILE_BYTES_PER_BLOCK ) {
+    if ( !block_ptr )
+      return copied;
+    memcpy( dest, &(*block_ptr)[ 0 ], to_copy );
+    dest += to_copy;
+    block++;
+   *  Phase 3: possibly the first part of one block
+  IMFS_assert( my_length < IMFS_MEMFILE_BYTES_PER_BLOCK );
+  if ( my_length ) {
+    if ( !block_ptr )
+      return copied;
+    memcpy( dest, &(*block_ptr)[ 0 ], my_length );
+    copied += my_length;
+  return copied;
+ *  IMFS_memfile_write
+ *  This routine writes the specified data buffer into the in memory
+ *  file pointed to by memfile.  The file is extended as needed.
+ssize_t IMFS_memfile_write(
+   off_t                  start,
+  int                  status;
+  int                  copied;
+  const unsigned char *src;
+  src = source;
+  IMFS_assert( source );
+   *  If the last byte we are supposed to write is past the end of this
+   *  in memory file, then extend the length.
+  last_byte = start + my_length;
+  if ( last_byte > memfile->File.size ) {
+    bool zero_fill = start > memfile->File.size;
+    status = IMFS_memfile_extend( memfile, zero_fill, last_byte );
+    if ( status )
+      return status;
+  copied = 0;
+   *  Three phases to the write:
+    if ( !block_ptr )
+      return copied;
+    #if 0
+      fprintf(
+        stderr,
+        "write %d at %d in %d: %*s\n",
+        to_copy,
+        start_offset,
+        block,
+        to_copy,
+        src
+    #endif
+    memcpy( &(*block_ptr)[ start_offset ], src, to_copy );
+    src += to_copy;
+    block++;
+    if ( !block_ptr )
+      return copied;
+    #if 0
+      fprintf(stdout, "write %d in %d: %*s\n", to_copy, block, to_copy, src );
+    #endif
+    memcpy( &(*block_ptr)[ 0 ], src, to_copy );
+    src += to_copy;
+    block++;
+    if ( !block_ptr )
+      return copied;
+    #if 0
+    #endif
+    memcpy( &(*block_ptr)[ 0 ], src, my_length );
+    my_length = 0;
+  return copied;
+ *  IMFS_memfile_get_block_pointer
+ *  This routine looks up the block pointer associated with the given block
+ *  number.  If that block has not been allocated and "malloc_it" is
+ *  TRUE, then the block is allocated.  Otherwise, it is an error.
+#if 0
+block_p *IMFS_memfile_get_block_pointer_DEBUG(
+   IMFS_jnode_t   *the_jnode,
+   int             malloc_it
+block_p *IMFS_memfile_get_block_pointer(
+   int             malloc_it
+  block_p *p;
+  p = IMFS_memfile_get_block_pointer_DEBUG( the_jnode, block, malloc_it );
+  fprintf(stdout, "(%d -> %p) ", block, p );
+  return p;
+#else
+#endif
+   int             malloc_it
+  unsigned int    my_block;
+  unsigned int    singly;
+  unsigned int    doubly;
+  unsigned int    triply;
+  block_p        *p;
+  block_p        *p1;
+  block_p        *p2;
+  my_block = block;
+   *  Is the block number in the simple indirect portion?
+  if ( my_block <= LAST_INDIRECT ) {
+    p = memfile->indirect;
+    if ( malloc_it ) {
+      if ( !p ) {
+        p = memfile_alloc_block();
+        if ( !p )
+           return 0;
+        memfile->indirect = p;
+      return &memfile->indirect[ my_block ];
+    if ( !p )
+      return 0;
+   *  Is the block number in the doubly indirect portion?
+  if ( my_block <= LAST_DOUBLY_INDIRECT ) {
+    my_block -= FIRST_DOUBLY_INDIRECT;
+    singly = my_block % IMFS_MEMFILE_BLOCK_SLOTS;
+    doubly = my_block / IMFS_MEMFILE_BLOCK_SLOTS;
+    p = memfile->doubly_indirect;
+      if ( !p ) {
+        if ( !p )
+           return 0;
+        memfile->doubly_indirect = p;
+      p1 = (block_p *)p[ doubly ];
+      if ( !p1 ) {
+        p1 = memfile_alloc_block();
+        if ( !p1 )
+           return 0;
+        p[ doubly ] = (block_p) p1;
+      return (block_p *)&p1[ singly ];
+    if ( !p )
+      return 0;
+    p = (block_p *)p[ doubly ];
+    if ( !p )
+      return 0;
+    return (block_p *)&p[ singly ];
+   *  Is the block number in the triply indirect portion?
+  if ( my_block <= LAST_TRIPLY_INDIRECT ) {
+    my_block -= FIRST_TRIPLY_INDIRECT;
+    triply = doubly / IMFS_MEMFILE_BLOCK_SLOTS;
+    doubly %= IMFS_MEMFILE_BLOCK_SLOTS;
+    p = memfile->triply_indirect;
+      if ( !p ) {
+        if ( !p )
+           return 0;
+        memfile->triply_indirect = p;
+      p1 = (block_p *) p[ triply ];
+      if ( !p1 ) {
+        if ( !p1 )
+           return 0;
+        p[ triply ] = (block_p) p1;
+      p2 = (block_p *)p1[ doubly ];
+      if ( !p2 ) {
+        p2 = memfile_alloc_block();
+        if ( !p2 )
+           return 0;
+        p1[ doubly ] = (block_p) p2;
+      return (block_p *)&p2[ singly ];
+    if ( !p )
+      return 0;
+    if ( !p1 )
+      return 0;
+    if ( !p2 )
+      return 0;
+   *  This means the requested block number is out of range.
+  return 0;
+ *  memfile_alloc_block
+ *  Allocate a block for an in-memory file.
+int memfile_blocks_allocated = 0;
+void *memfile_alloc_block(void)
+  void *memory;
+  memory = (void *)calloc(1, IMFS_MEMFILE_BYTES_PER_BLOCK);
+  if ( memory )
+    memfile_blocks_allocated++;
+  return memory;
+ *  Free a block from an in-memory file.
+void memfile_free_block(
+  void *memory
+  free(memory);
+  memfile_blocks_allocated--;
+static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
+  .open_h = rtems_filesystem_default_open,
+  .read_h = memfile_read,
+  .write_h = memfile_write,
+  .ftruncate_h = memfile_ftruncate,
+const IMFS_mknod_control IMFS_mknod_control_memfile = {
+    .handlers = &IMFS_memfile_handlers,
+    .node_destroy = IMFS_memfile_destroy
+  .node_size = sizeof( IMFS_file_t )
diff --git a/cpukit/libfs/src/imfs/imfs_stat_file.c b/cpukit/libfs/src/imfs/imfs_stat_file.c
index 0000000..2302705
--- /dev/null
+++ b/cpukit/libfs/src/imfs/imfs_stat_file.c
@@ -0,0 +1,33 @@
+ * @file
+ * @ingroup IMFS
+#if HAVE_CONFIG_H
+#endif
+#include "imfs.h"
+int IMFS_stat_file(
+  struct stat *buf
+  const IMFS_file_t *file = loc->node_access;
+  buf->st_size = file->File.size;
+  buf->st_blksize = imfs_rq_memfile_bytes_per_block;
+  return IMFS_stat( loc, buf );
diff --git a/cpukit/libfs/src/imfs/memfile.c b/cpukit/libfs/src/imfs/memfile.c
index 59da9a6..0000000
--- a/cpukit/libfs/src/imfs/memfile.c
+++ /dev/null
@@ -1,893 +0,0 @@
- * @file
- * @brief IMFS Memory File Handlers
- * @ingroup IMFS
- *  COPYRIGHT (c) 1989-2010.
-#if HAVE_CONFIG_H
-#endif
-#include "imfs.h"
-#include <stdlib.h>
-#include <string.h>
-#define MEMFILE_STATIC
- *  Prototypes of private routines
-MEMFILE_STATIC int IMFS_memfile_extend(
-   IMFS_memfile_t *memfile,
-   bool            zero_fill,
-   off_t           new_length
-MEMFILE_STATIC int IMFS_memfile_addblock(
-   unsigned int    block
-MEMFILE_STATIC void IMFS_memfile_remove_block(
-MEMFILE_STATIC block_p *IMFS_memfile_get_block_pointer(
-   unsigned int    block,
-   int             malloc_it
-MEMFILE_STATIC ssize_t IMFS_memfile_read(
-   IMFS_file_t     *file,
-   off_t            start,
-   unsigned char   *destination,
-   unsigned int     length
-ssize_t IMFS_memfile_write(  /* cannot be static as used in imfs_fchmod.c */
-   off_t                  start,
-   const unsigned char   *source,
-void *memfile_alloc_block(void);
-void memfile_free_block(
-  void *memory
-int IMFS_linfile_open(
-  int            oflag,
-  mode_t         mode
-  IMFS_file_t *file;
-  file = iop->pathinfo.node_access;
-   * Perform 'copy on write' for linear files
-  if ((iop->flags & LIBIO_FLAGS_WRITE) != 0) {
-    uint32_t count = file->File.size;
-    const unsigned char *buffer = file->Linearfile.direct;
-    file->Node.control            = &IMFS_mknod_control_memfile.node_control;
-    file->File.size               = 0;
-    file->Memfile.indirect        = 0;
-    file->Memfile.doubly_indirect = 0;
-    file->Memfile.triply_indirect = 0;
-    if ((count != 0)
-     && (IMFS_memfile_write(&file->Memfile, 0, buffer, count) == -1))
-        return -1;
-  return 0;
-ssize_t IMFS_linfile_read(
-  void          *buffer,
-  size_t         count
-  IMFS_file_t *file = IMFS_iop_to_file( iop );
-  off_t start = iop->offset;
-  size_t size = file->File.size;
-  const unsigned char *data = file->Linearfile.direct;
-  if (count > size - start)
-    count = size - start;
-  IMFS_update_atime( &file->Node );
-  iop->offset = start + count;
-  memcpy(buffer, &data[start], count);
-  return (ssize_t) count;
-ssize_t memfile_read(
-  void          *buffer,
-  size_t         count
-  ssize_t      status;
-  status = IMFS_memfile_read( file, iop->offset, buffer, count );
-  if ( status > 0 )
-    iop->offset += status;
-  return status;
-ssize_t memfile_write(
-  size_t         count
-  IMFS_memfile_t *memfile = IMFS_iop_to_memfile( iop );
-  ssize_t         status;
-  if ((iop->flags & LIBIO_FLAGS_APPEND) != 0)
-    iop->offset = memfile->File.size;
-  status = IMFS_memfile_write( memfile, iop->offset, buffer, count );
-  if ( status > 0 )
-  return status;
- *  memfile_stat
- *  This IMFS_stat() can be used.
-int memfile_ftruncate(
-  off_t                 length
-   *  POSIX 1003.1b does not specify what happens if you truncate a file
-   *  and the new length is greater than the current size.  We treat this
-   *  as an extend operation.
-  if ( length > memfile->File.size )
-    return IMFS_memfile_extend( memfile, true, length );
-   *  The in-memory files do not currently reclaim memory until the file is
-   *  deleted.  So we leave the previously allocated blocks in place for
-   *  future use and just set the length.
-  memfile->File.size = length;
-  IMFS_mtime_ctime_update( &memfile->File.Node );
-  return 0;
- *  IMFS_memfile_extend
- *  This routine insures that the in-memory file is of the length
- *  specified.  If necessary, it will allocate memory blocks to
- *  extend the file.
-   bool            zero_fill,
-   off_t           new_length
-  unsigned int   block;
-  unsigned int   new_blocks;
-  unsigned int   old_blocks;
-  unsigned int   offset;
-   *  Perform internal consistency checks
-  IMFS_assert( memfile );
-   *  Verify new file size is supported
-  if ( new_length >= IMFS_MEMFILE_MAXIMUM_SIZE )
-    rtems_set_errno_and_return_minus_one( EFBIG );
-   *  Verify new file size is actually larger than current size
-  if ( new_length <= memfile->File.size )
-    return 0;
-   *  Calculate the number of range of blocks to allocate
-  new_blocks = new_length / IMFS_MEMFILE_BYTES_PER_BLOCK;
-  old_blocks = memfile->File.size / IMFS_MEMFILE_BYTES_PER_BLOCK;
-  offset = memfile->File.size - old_blocks * IMFS_MEMFILE_BYTES_PER_BLOCK;
-   *  Now allocate each of those blocks.
-  for ( block=old_blocks ; block<=new_blocks ; block++ ) {
-    if ( !IMFS_memfile_addblock( memfile, block ) ) {
-       if ( zero_fill ) {
-          size_t count = IMFS_MEMFILE_BYTES_PER_BLOCK - offset;
-          block_p *block_ptr =
-            IMFS_memfile_get_block_pointer( memfile, block, 0 );
-          memset( &(*block_ptr) [offset], 0, count);
-          offset = 0;
-    } else {
-       for ( ; block>=old_blocks ; block-- ) {
-         IMFS_memfile_remove_block( memfile, block );
-       rtems_set_errno_and_return_minus_one( ENOSPC );
-   *  Set the new length of the file.
-  memfile->File.size = new_length;
-  return 0;
- *  IMFS_memfile_addblock
- *  This routine adds a single block to the specified in-memory file.
-  block_p  memory;
-  block_p *block_entry_ptr;
-   * Obtain the pointer for the specified block number
-  block_entry_ptr = IMFS_memfile_get_block_pointer( memfile, block, 1 );
-  if ( !block_entry_ptr )
-    return 1;
-  if ( *block_entry_ptr )
-    return 0;
-   *  There is no memory for this block number so allocate it.
-  memory = memfile_alloc_block();
-  if ( !memory )
-    return 1;
-  *block_entry_ptr = memory;
-  return 0;
- *  IMFS_memfile_remove_block
- *  This routine removes the specified block from the in-memory file.
- *  NOTE:  This is a support routine and is called only to remove
- *         the last block or set of blocks in a file.  Removing a
- *         block from the middle of a file would be exceptionally
- *         dangerous and the results unpredictable.
-  block_p *block_ptr;
-  block_p  ptr;
-  block_ptr = IMFS_memfile_get_block_pointer( memfile, block, 0 );
-  if ( block_ptr ) {
-    ptr = *block_ptr;
-    *block_ptr = 0;
-    memfile_free_block( ptr );
- *  memfile_free_blocks_in_table
- *  This is a support routine for IMFS_memfile_remove.  It frees all the
- *  blocks in one of the indirection tables.
-static void memfile_free_blocks_in_table(
-  block_p **block_table,
-  int       entries
-  int      i;
-  block_p *b;
-  IMFS_assert( block_table );
-   *  Now go through all the slots in the table and free the memory.
-  b = *block_table;
-  for ( i=0 ; i<entries ; i++ ) {
-    if ( b[i] ) {
-      memfile_free_block( b[i] );
-      b[i] = 0;
-   *  Now that all the blocks in the block table are free, we can
-   *  free the block table itself.
-  memfile_free_block( *block_table );
-  *block_table = 0;
- *  This routine frees all memory associated with an in memory file.
- *  NOTE:  This is an exceptionally conservative implementation.
- *         It will check EVERY pointer which is non-NULL and insure
- *         any child non-NULL pointers are freed.  Optimistically, all that
- *         is necessary is to scan until a NULL pointer is found.  There
- *         should be no allocated data past that point.
- *         In experimentation on the powerpc simulator, it was noted
- *         that using blocks which held 128 slots versus 16 slots made
- *         a significant difference in the performance of this routine.
- *         Regardless until the IMFS implementation is proven, it
- *         is better to stick to simple, easy to understand algorithms.
-void IMFS_memfile_remove(
-  IMFS_memfile_t  *memfile;
-  int              i;
-  int              j;
-  unsigned int     to_free;
-  block_p         *p;
-  memfile = (IMFS_memfile_t *) the_jnode;
-   *  Eventually this could be set smarter at each call to
-   *  memfile_free_blocks_in_table to greatly speed this up.
-  to_free = IMFS_MEMFILE_BLOCK_SLOTS;
-   *  Now start freeing blocks in this order:
-   *    + indirect
-   *    + doubly indirect
-   *    + triply indirect
-  if ( memfile->indirect ) {
-    memfile_free_blocks_in_table( &memfile->indirect, to_free );
-  if ( memfile->doubly_indirect ) {
-    for ( i=0 ; i<IMFS_MEMFILE_BLOCK_SLOTS ; i++ ) {
-      if ( memfile->doubly_indirect[i] ) {
-         (block_p **)&memfile->doubly_indirect[i], to_free );
-    memfile_free_blocks_in_table( &memfile->doubly_indirect, to_free );
-  if ( memfile->triply_indirect ) {
-      p = (block_p *) memfile->triply_indirect[i];
-      if ( !p )  /* ensure we have a valid pointer */
-         break;
-      for ( j=0 ; j<IMFS_MEMFILE_BLOCK_SLOTS ; j++ ) {
-        if ( p[j] ) {
-          memfile_free_blocks_in_table( (block_p **)&p[j], to_free);
-        (block_p **)&memfile->triply_indirect[i], to_free );
-        (block_p **)&memfile->triply_indirect, to_free );
-  IMFS_node_destroy_default( the_jnode );
- *  IMFS_memfile_read
- *  This routine read from memory file pointed to by the_jnode into
- *  the specified data buffer specified by destination.  The file
- *  is NOT extended.  An offset greater than the length of the file
- *  is considered an error.  Read from an offset for more bytes than
- *  are between the offset and the end of the file will result in
- *  reading the data between offset and the end of the file (truncated
- *  read).
-   off_t            start,
-  unsigned int         my_length;
-  unsigned int         to_copy = 0;
-  unsigned int         last_byte;
-  unsigned int         copied;
-  unsigned int         start_offset;
-  unsigned char       *dest;
-  dest = destination;
-  IMFS_assert( file );
-  IMFS_assert( dest );
-   *  Linear files (as created from a tar file are easier to handle
-   *  than block files).
-  my_length = length;
-   *  If the last byte we are supposed to read is past the end of this
-   *  in memory file, then shorten the length to read.
-  last_byte = start + length;
-  if ( last_byte > file->Memfile.File.size )
-    my_length = file->Memfile.File.size - start;
-  copied = 0;
-   *  Three phases to the read:
-   *    + possibly the last part of one block
-   *    + all of zero of more blocks
-   *    + possibly the first part of one block
-   *  Phase 1: possibly the last part of one block
-  start_offset = start % IMFS_MEMFILE_BYTES_PER_BLOCK;
-  block = start / IMFS_MEMFILE_BYTES_PER_BLOCK;
-  if ( start_offset )  {
-    to_copy = IMFS_MEMFILE_BYTES_PER_BLOCK - start_offset;
-    if ( to_copy > my_length )
-      to_copy = my_length;
-    block_ptr = IMFS_memfile_get_block_pointer( &file->Memfile, block, 0 );
-    if ( !block_ptr )
-      return copied;
-    memcpy( dest, &(*block_ptr)[ start_offset ], to_copy );
-    dest += to_copy;
-    block++;
-    my_length -= to_copy;
-    copied += to_copy;
-   *  Phase 2: all of zero of more blocks
-  to_copy = IMFS_MEMFILE_BYTES_PER_BLOCK;
-  while ( my_length >= IMFS_MEMFILE_BYTES_PER_BLOCK ) {
-    if ( !block_ptr )
-      return copied;
-    memcpy( dest, &(*block_ptr)[ 0 ], to_copy );
-    dest += to_copy;
-    block++;
-   *  Phase 3: possibly the first part of one block
-  IMFS_assert( my_length < IMFS_MEMFILE_BYTES_PER_BLOCK );
-  if ( my_length ) {
-    if ( !block_ptr )
-      return copied;
-    memcpy( dest, &(*block_ptr)[ 0 ], my_length );
-    copied += my_length;
-  return copied;
- *  IMFS_memfile_write
- *  This routine writes the specified data buffer into the in memory
- *  file pointed to by memfile.  The file is extended as needed.
-MEMFILE_STATIC ssize_t IMFS_memfile_write(
-   off_t                  start,
-  int                  status;
-  int                  copied;
-  const unsigned char *src;
-  src = source;
-  IMFS_assert( source );
-   *  If the last byte we are supposed to write is past the end of this
-   *  in memory file, then extend the length.
-  last_byte = start + my_length;
-  if ( last_byte > memfile->File.size ) {
-    bool zero_fill = start > memfile->File.size;
-    status = IMFS_memfile_extend( memfile, zero_fill, last_byte );
-    if ( status )
-      return status;
-  copied = 0;
-   *  Three phases to the write:
-    if ( !block_ptr )
-      return copied;
-    #if 0
-      fprintf(
-        stderr,
-        "write %d at %d in %d: %*s\n",
-        to_copy,
-        start_offset,
-        block,
-        to_copy,
-        src
-    #endif
-    memcpy( &(*block_ptr)[ start_offset ], src, to_copy );
-    src += to_copy;
-    block++;
-    if ( !block_ptr )
-      return copied;
-    #if 0
-      fprintf(stdout, "write %d in %d: %*s\n", to_copy, block, to_copy, src );
-    #endif
-    memcpy( &(*block_ptr)[ 0 ], src, to_copy );
-    src += to_copy;
-    block++;
-    if ( !block_ptr )
-      return copied;
-    #if 0
-    #endif
-    memcpy( &(*block_ptr)[ 0 ], src, my_length );
-    my_length = 0;
-  return copied;
- *  IMFS_memfile_get_block_pointer
- *  This routine looks up the block pointer associated with the given block
- *  number.  If that block has not been allocated and "malloc_it" is
- *  TRUE, then the block is allocated.  Otherwise, it is an error.
-#if 0
-block_p *IMFS_memfile_get_block_pointer_DEBUG(
-   IMFS_jnode_t   *the_jnode,
-   int             malloc_it
-block_p *IMFS_memfile_get_block_pointer(
-   int             malloc_it
-  block_p *p;
-  p = IMFS_memfile_get_block_pointer_DEBUG( the_jnode, block, malloc_it );
-  fprintf(stdout, "(%d -> %p) ", block, p );
-  return p;
-#else
-#endif
-   int             malloc_it
-  unsigned int    my_block;
-  unsigned int    singly;
-  unsigned int    doubly;
-  unsigned int    triply;
-  block_p        *p;
-  block_p        *p1;
-  block_p        *p2;
-  my_block = block;
-   *  Is the block number in the simple indirect portion?
-  if ( my_block <= LAST_INDIRECT ) {
-    p = memfile->indirect;
-    if ( malloc_it ) {
-      if ( !p ) {
-        p = memfile_alloc_block();
-        if ( !p )
-           return 0;
-        memfile->indirect = p;
-      return &memfile->indirect[ my_block ];
-    if ( !p )
-      return 0;
-   *  Is the block number in the doubly indirect portion?
-  if ( my_block <= LAST_DOUBLY_INDIRECT ) {
-    my_block -= FIRST_DOUBLY_INDIRECT;
-    singly = my_block % IMFS_MEMFILE_BLOCK_SLOTS;
-    doubly = my_block / IMFS_MEMFILE_BLOCK_SLOTS;
-    p = memfile->doubly_indirect;
-      if ( !p ) {
-        if ( !p )
-           return 0;
-        memfile->doubly_indirect = p;
-      p1 = (block_p *)p[ doubly ];
-      if ( !p1 ) {
-        p1 = memfile_alloc_block();
-        if ( !p1 )
-           return 0;
-        p[ doubly ] = (block_p) p1;
-      return (block_p *)&p1[ singly ];
-    if ( !p )
-      return 0;
-    p = (block_p *)p[ doubly ];
-    if ( !p )
-      return 0;
-    return (block_p *)&p[ singly ];
-   *  Is the block number in the triply indirect portion?
-  if ( my_block <= LAST_TRIPLY_INDIRECT ) {
-    my_block -= FIRST_TRIPLY_INDIRECT;
-    triply = doubly / IMFS_MEMFILE_BLOCK_SLOTS;
-    doubly %= IMFS_MEMFILE_BLOCK_SLOTS;
-    p = memfile->triply_indirect;
-      if ( !p ) {
-        if ( !p )
-           return 0;
-        memfile->triply_indirect = p;
-      p1 = (block_p *) p[ triply ];
-      if ( !p1 ) {
-        if ( !p1 )
-           return 0;
-        p[ triply ] = (block_p) p1;
-      p2 = (block_p *)p1[ doubly ];
-      if ( !p2 ) {
-        p2 = memfile_alloc_block();
-        if ( !p2 )
-           return 0;
-        p1[ doubly ] = (block_p) p2;
-      return (block_p *)&p2[ singly ];
-    if ( !p )
-      return 0;
-    if ( !p1 )
-      return 0;
-    if ( !p2 )
-      return 0;
-   *  This means the requested block number is out of range.
-  return 0;
- *  memfile_alloc_block
- *  Allocate a block for an in-memory file.
-int memfile_blocks_allocated = 0;
-  void *memory;
-  memory = (void *)calloc(1, IMFS_MEMFILE_BYTES_PER_BLOCK);
-  if ( memory )
-    memfile_blocks_allocated++;
-  return memory;
- *  Free a block from an in-memory file.
-  void *memory
-  free(memory);
-  memfile_blocks_allocated--;
2.1.4
