BSP requests.
Alan Cudmore
alan.cudmore at gmail.com
Tue Feb 10 03:16:33 UTC 2015
Thanks for getting the BSPs in.
I wanted to try to compare the old and new build systems on the raspberry
Pi 2, but I'm still working on getting the tools to build. Chris may have a
clue about this:
The compiler build finishes ( much faster than the RPI 1 ) but the rtems
tools build fails. This can be reproduced with just the rtems tools repo
without trying a complete RSB toolchain build.
I suspect that something is not getting defined for the ARM host in the
configure step:
pi at raspberrypi ~/rtems-tools.git $ ./waf build
Waf: Entering directory `/home/pi/rtems-tools.git/build'
[ 1/142] libelf_convert.c:
rtemstoolkit/elftoolchain/libelf/libelf_convert.m4 ->
build/rtemstoolkit/libelf_convert.c
[ 3/142] libelf_fsize.c: rtemstoolkit/elftoolchain/libelf/libelf_fsize.m4
-> build/rtemstoolkit/libelf_fsize.c
[ 3/142] libelf_msize.c: rtemstoolkit/elftoolchain/libelf/libelf_msize.m4
-> build/rtemstoolkit/libelf_msize.c
[ 4/142] native-elf-format:
rtemstoolkit/elftoolchain/common/native-elf-format ->
build/rtemstoolkit/elftoolchain/common/native-elf-format.h
[ 5/142] c: rtemstoolkit/elftoolchain/libelf/elf.c ->
build/rtemstoolkit/elftoolchain/libelf/elf.c.5.o
[ 6/142] c: rtemstoolkit/elftoolchain/libelf/elf_begin.c ->
build/rtemstoolkit/elftoolchain/libelf/elf_begin.c.5.o
[ 7/142] c: rtemstoolkit/elftoolchain/libelf/elf_cntl.c ->
build/rtemstoolkit/elftoolchain/libelf/elf_cntl.c.5.o
[ 8/142] c: rtemstoolkit/elftoolchain/libelf/elf_end.c ->
build/rtemstoolkit/elftoolchain/libelf/elf_end.c.5.o
../rtemstoolkit/elftoolchain/libelf/elf.c:34:18: error: ‘unknown’
undeclared here (not in a function)
Waf: Leaving directory `/home/pi/rtems-tools.git/build'
Build failed
-> task in 'elf' failed (exit status 1):
{task 38575952: c elf.c -> elf.c.5.o}
['/usr/bin/gcc', '-pipe', '-g', '-O2', '-I/home/pi/rtems-tools.git/build',
'-I/home/pi/rtems-tools.git/build/rtemstoolkit/elftoolchain/libelf', '-
I/home/pi/rtems-tools.git/rtemstoolkit/elftoolchain/libelf',
'-I/home/pi/rtems-tools.git/build/rtemstoolkit/elftoolchain/common',
'-I/home/pi/rtem
s-tools.git/rtemstoolkit/elftoolchain/common',
'-DPYTHONDIR="/media/Projects/rtems/4.11/lib/python2.7/site-packages"',
'-DPYTHONARCHDIR="/media/Pr
'../rtemstoolkit/elftoolchain/libelf/elf.c', '-c', '-o',
'rtemstoolkit/elftoolchain/libelf/elf.c.
5.o']
Thanks,
Alan
On Mon, Feb 9, 2015 at 8:58 PM, Amar Takhar <amar at rtems.org> wrote:
> On 2015-02-09 17:32 +0000, Cudmore, Alan P. (GSFC-5820) wrote:
> > I would like to request Raspberry Pi, LEON3, and m68k/mcf5235.
> m68k/mcf5235 is now working.
> I will work on rpi after I get the Beagle BSPs working.
> Amar.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150209/a819d594/attachment-0002.html>
