[PATCH] score/or1k/cpu.c: discard linker-symbols.h include and extern the related variable
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Tue Feb 10 22:12:19 UTC 2015
On 2/10/2015 3:46 PM, Peter Dufault wrote:
>> On Feb 10, 2015, at 15:30 , Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
>> On 2/10/2015 2:26 PM, Hesham Moustafa wrote:
>>> On Tue, Feb 10, 2015 at 8:21 PM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>>> Thanks. One down.
>>>> Crap. It should have had a comment that closed the PR. :(
>>> Who should add the comment? The ticket is now closed (fixed). In the
>>> future patches, should I tag the ticket/PR number part of the commit
>>> message?
>> I think the procedure is to use the git commit message like this:
>> or1k/cpu.c: Eliminate dependency on BSP provided .h file
>> close XXXX
>> You just posted a patch and I did remember to add the --author
>> info but forgot the PR.
>>>> On 2/10/2015 2:04 PM, Hesham ALMatary wrote:
>>>>> cpukit/score/cpu/or1k/cpu.c | 7 ++++++-
>>>>> 1 file changed, 6 insertions(+), 1 deletion(-)
>>>>> diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
>>>>> index 9d1ae49..69845ff 100644
>>>>> --- a/cpukit/score/cpu/or1k/cpu.c
>>>>> +++ b/cpukit/score/cpu/or1k/cpu.c
>>>>> @@ -14,9 +14,14 @@
>>>>> #include <rtems/system.h>
>>>>> #include <rtems/score/isr.h>
>>>>> #include <rtems/score/wkspace.h>
>>>>> -#include <bsp/linker-symbols.h>
>>>>> #include <rtems/score/cpu.h>
>>>>> +/* bsp_start_vector_table_begin is the start address of the vector table
>>>>> + * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
>>>>> + * and may differ from one BSP to another.
>>>>> +extern char bsp_start_vector_table_begin[];
>>>>>  * @brief Performs processor dependent initialization.
>>>>> -- 2.1.0
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
> I'm not sure what it fixes, but removing a header file and putting an "extern" declaration in a C file instead needs to be explained in a comment.  In general that's moving backwards, I guess the comment implies something (that it may differ from one BSP to another), but since an extern in C code is bad practice it should be better explained.
The overarching rule is that code in cpukit/ SHALL not include anything
from the BSP.
It possibly could be moved to cpu.h or a port provided file that defines
the symbols expected to be provided by the BSP.
I am happy with anything that moves us in a better direction. This was
breaking the dependency.
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
