[PATCH] Don't fail to create passwd and group files if /etc already exists
Fri Feb 20 11:18:19 UTC 2015
On 20/02/2015 8:29 pm, Sebastian Huber wrote:
> On 20/02/15 10:06, Nick Withers wrote:
>> On Fri, 2015-02-20 at 08:59 +0100, Sebastian Huber wrote:
>>> >Hello Nick,
>>> >thanks for the patch. I checked in a slightly different version which
>>> >ignores the return status completely.
>> Hi Sebastian,
>> Your commit effectively reverts Joel's changes in
>> https://git.rtems.org/rtems/commit/?id=3211e8e9c0565fae8b13ba0115e3a23ad3ae8ade
>> Would chucking a (void) in front of the mkdir() shut Coverity up?
> Ok, I should have checked the commit history since I wondered why I
> added this error check in the first place. Lets try a (void) cast.
What about doing a stat, create the directory if not present and then
error on a mkdir failure ? There are other failures that could happen
making a directory that we should correctly report.
