[PATCH] Don't fail to create passwd and group files if /etc already exists
Chris Johns
chrisj at rtems.org
Sat Feb 21 20:34:09 UTC 2015
On 20/02/2015 11:00 pm, Sebastian Huber wrote:
> On 20/02/15 12:18, Chris Johns wrote:
>> On 20/02/2015 8:29 pm, Sebastian Huber wrote:
>>> On 20/02/15 10:06, Nick Withers wrote:
>>>> On Fri, 2015-02-20 at 08:59 +0100, Sebastian Huber wrote:
>>>>> >Hello Nick,
>>>>> >thanks for the patch. I checked in a slightly different version which
>>>>> >ignores the return status completely.
>>>> Hi Sebastian,
>>>> Your commit effectively reverts Joel's changes in
>>>> https://git.rtems.org/rtems/commit/?id=3211e8e9c0565fae8b13ba0115e3a23ad3ae8ade
>>>> Would chucking a (void) in front of the mkdir() shut Coverity up?
>>> Ok, I should have checked the commit history since I wondered why I
>>> added this error check in the first place. Lets try a (void) cast.
>> What about doing a stat, create the directory if not present and then
>> error on a mkdir failure ? There are other failures that could happen
>> making a directory that we should correctly report.
> The stat approach is not thread safe.
> Its up to the users of the create files to do the error handling.
Maybe just check the error code for EEXIST and ignore it, plus the call
is protected by a posix init once variable so I am not sure I follow
this thread safe bit.
