[PATCH 006/111] leon3,ngmp: simplify cpucounter initialization
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:08 UTC 2015
Remove support for using the second timer for time stamping.
Instead the user can configure the system clock timer to a higher
base clock frequency (lower the prescaler). This change does not
affect the GR712RC or LEON4-N2X. The GR712RC does not have two
GPTIMERs and the N2X uses the Interrupt Controller for time
stamping.
Bow that the AMBA initialization code exports the AMBA device,
the frequency can be obtained without an additional AMBA PnP
scanning.
c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c | 55 ++------------------
1 files changed, 6 insertions(+), 49 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c b/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c
index d28421c..78096cd 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c
@@ -16,11 +16,6 @@
#include <rtems/counter.h>
-static volatile struct gptimer_regs *adev_to_gpt(struct ambapp_dev *adev)
- return (volatile struct gptimer_regs *) DEV_TO_APB(adev)->start;
static CPU_Counter_ticks timestamp_counter_difference(
CPU_Counter_ticks second,
CPU_Counter_ticks first
@@ -29,14 +24,6 @@ static CPU_Counter_ticks timestamp_counter_difference(
return second - first;
-static CPU_Counter_ticks free_counter_difference(
- CPU_Counter_ticks second,
- CPU_Counter_ticks first
- return first - second;
static CPU_Counter_ticks clock_counter_difference(
@@ -66,8 +53,7 @@ void leon3_cpu_counter_initialize(void)
volatile struct irqmp_timestamp_regs *irqmp_ts =
&LEON3_IrqCtrl_Regs->timestamp[0];
- struct ambapp_dev *adev;
- int idx = 1;
+ unsigned int freq;
if (leon3_irqmp_has_timestamp(irqmp_ts)) {
/* Use the interrupt controller timestamp counter if available */
@@ -81,45 +67,16 @@ void leon3_cpu_counter_initialize(void)
/* Get and set the frequency */
- adev = (void *) ambapp_for_each(
- &ambapp_plb,
- OPTIONS_ALL | OPTIONS_APB_SLVS,
- VENDOR_GAISLER,
- GAISLER_IRQMP,
- ambapp_find_by_idx,
- NULL
- rtems_counter_initialize_converter(ambapp_freq_get(&ambapp_plb, adev));
- } else {
- &ambapp_plb,
- VENDOR_GAISLER,
- GAISLER_GPTIMER,
- &idx
- if (adev != NULL) {
- /* Use the second GPTIMER if available */
- volatile struct gptimer_regs *gpt = adev_to_gpt(adev);
- uint32_t max_frequency = ambapp_freq_get(&ambapp_plb, adev);
- unsigned min_prescaler = 8;
- uint32_t frequency = max_frequency / min_prescaler;
- gpt->scaler_reload = min_prescaler - 1;
- gpt->timer[0].reload = 0xffffffff;
- gpt->timer[0].ctrl = GPTIMER_TIMER_CTRL_EN | GPTIMER_TIMER_CTRL_RS
- | GPTIMER_TIMER_CTRL_LD;
- gpt_counter_initialize(gpt, 0, frequency, free_counter_difference);
- } else if (LEON3_Timer_Regs != NULL) {
+ rtems_counter_initialize_converter(ambapp_freq_get(&ambapp_plb, irqmp_dev));
+ } else if (LEON3_Timer_Regs != NULL) {
/* Fall back to the first GPTIMER if available */
+ freq = ambapp_freq_get(&ambapp_plb, timer_dev);
LEON3_Timer_Regs,
LEON3_CLOCK_INDEX,
- LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER,
+ freq / (LEON3_Timer_Regs->scaler_reload - 1),
1.7.0.4
