[PATCH 022/111] LEON: added network device configuration helper function
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:24 UTC 2015
c/src/lib/libbsp/sparc/Makefile.am | 4 +
c/src/lib/libbsp/sparc/leon2/Makefile.am | 5 ++
c/src/lib/libbsp/sparc/leon2/preinstall.am | 4 +
c/src/lib/libbsp/sparc/leon3/Makefile.am | 6 ++
c/src/lib/libbsp/sparc/leon3/preinstall.am | 6 ++
.../sparc/shared/include/network_interface_add.h | 47 +++++++++++++++
.../sparc/shared/net/network_interface_add.c | 62 ++++++++++++++++++++
7 files changed, 134 insertions(+), 0 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/shared/include/network_interface_add.h
create mode 100644 c/src/lib/libbsp/sparc/shared/net/network_interface_add.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 719feba..cbd2a14 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -83,6 +83,10 @@ EXTRA_DIST += shared/include/b1553brm.h
EXTRA_DIST += shared/i2c/i2cmst.c
EXTRA_DIST += shared/include/i2cmst.h
+# Network configuration
+EXTRA_DIST += shared/net/network_interface_add.c
+EXTRA_DIST += shared/include/network_interface_add.h
# Driver Manager
EXTRA_DIST += shared/drvmgr/ambapp_bus.c
EXTRA_DIST += shared/drvmgr/ambapp_bus_grlib.c
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 008e203..3f29d46 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -166,6 +166,11 @@ leon_open_eth_rel_CPPFLAGS += -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
leon_open_eth_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
endif
+# BSP Network configuration
+include_HEADERS += ../../sparc/shared/include/network_interface_add.h
+libbsp_a_SOURCES += ../../sparc/shared/net/network_interface_add.c
+endif
libbsp_a_LIBADD = \
../../../libcpu/@RTEMS_CPU@/access.rel \
../../../libcpu/@RTEMS_CPU@/cache.rel \
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index ab2498d..11dae63 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -166,3 +166,7 @@ $(PROJECT_INCLUDE)/drvmgr/leon2_amba_bus.h: ../../sparc/shared/include/drvmgr/le
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/leon2_amba_bus.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/leon2_amba_bus.h
+$(PROJECT_INCLUDE)/network_interface_add.h: ../../sparc/shared/include/network_interface_add.h $(PROJECT_INCLUDE)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/network_interface_add.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/network_interface_add.h
+endif
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index dee5d57..dae3ecc 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -191,6 +191,12 @@ leon_greth_rel_CPPFLAGS += -D__INSIDE_RTEMS_BSD_TCPIP_STACK__
leon_greth_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
endif
+if HAS_NETWORKING
+endif
EXTRA_DIST = shmsupp/README
if HAS_MP
# shmsupp
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 631a7f0..41f7d6d 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -193,3 +193,9 @@ PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/ambapp_bus_grlib.h
$(PROJECT_INCLUDE)/drvmgr/ambapp_bus.h: ../../sparc/shared/include/drvmgr/ambapp_bus.h $(PROJECT_INCLUDE)/drvmgr/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/ambapp_bus.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/ambapp_bus.h
+if HAS_NETWORKING
+endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/network_interface_add.h b/c/src/lib/libbsp/sparc/shared/include/network_interface_add.h
new file mode 100644
index 0000000..761e48b
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/network_interface_add.h
@@ -0,0 +1,47 @@
+/* Network interface register help function
+ * COPYRIGHT (c) 2008.
+ * Cobham Gaisler AB.
+ * This function adds a network interface to the
+ * rtems_bsdnet_config.ifconfig linked list of interfaces.
+ * The interface configuration is taken from the user defined
+ * array interface_configs. This function is useful for PnP
+ * systems when an unknown number of interfaces are available.
+ * found in found in the file LICENSE in this distribution or at
+ * http://www.rtems.com/license/LICENSE.
+#ifndef __NETWORK_INTERFACE_ADD_H__
+#define __NETWORK_INTERFACE_ADD_H__
+#include <rtems/rtems_bsdnet.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Interface configuration description */
+struct ethernet_config {
+ char *ip_addr; /* IP address */
+ char *ip_netmask; /* IP Netmask */
+ char eth_adr[6]; /* Ethernet hardware MAC address */
+/* Array with configurations for all interfaces in the system
+ * Must be defined by the user.
+extern struct ethernet_config interface_configs[];
+/* Routine adding interface to rtems_bsdnet_config.ifconfig linked
+ * list of interfaces.
+int network_interface_add(struct rtems_bsdnet_ifconfig *interface);
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_NETWORKCONFIG_H_ */
diff --git a/c/src/lib/libbsp/sparc/shared/net/network_interface_add.c b/c/src/lib/libbsp/sparc/shared/net/network_interface_add.c
index 0000000..6e3a58a
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/net/network_interface_add.c
@@ -0,0 +1,62 @@
+#include <stdio.h>
+#include <network_interface_add.h>
+extern struct rtems_bsdnet_config rtems_bsdnet_config;
+/* Number of interfaces taken */
+int network_interface_cnt = 0;
+ struct ethernet_config *cfg = NULL;
+ int i, last_entry = 1;
+ /* Init interface description */
+ interface->next = NULL;
+ cfg = &interface_configs[network_interface_cnt];
+ for(i=0; i<6; i++) {
+ if ( cfg->eth_adr[i] != 0 ) {
+ last_entry = 0;
+ break;
+ /* Do we have a valid configuration? */
+ if ( last_entry == 0 ) {
+ interface->ip_address = cfg->ip_addr;
+ interface->ip_netmask = cfg->ip_netmask;
+ interface->hardware_address = cfg->eth_adr;
+ network_interface_cnt++;
+ } else {
+ interface->ip_address = NULL;
+ interface->ip_netmask = NULL;
+ interface->hardware_address = NULL;
+ /* Insert interface first into list */
+ interface->next = rtems_bsdnet_config.ifconfig;
+ rtems_bsdnet_config.ifconfig = interface;
+ return 0;
1.7.0.4
