[PATCH 024/111] DRVMGR: add LEON BSPs driver registration
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:26 UTC 2015
cpukit/libdrvmgr/drvmgr_confdefs.h | 218 +++++++++++++++++++++++++++++++++++-
1 files changed, 215 insertions(+), 3 deletions(-)
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index 23affe9..b2e4aba 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -29,18 +29,230 @@ extern struct drvmgr_drv_reg_func drvmgr_drivers[];
#ifdef CONFIGURE_INIT
-#if 0 /* EXAMPLE: GPTIMER driver definition */
+/*** AMBA Plug & Play Drivers ***/
#define DRIVER_AMBAPP_GAISLER_GPTIMER_REG {gptimer_register_drv}
extern void gptimer_register_drv(void);
-#endif
+#define DRIVER_AMBAPP_GAISLER_APBUART_REG {apbuart_cons_register_drv}
+extern void apbuart_cons_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRETH_REG {greth_register_drv}
+extern void greth_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRSPW_REG {grspw_register_drv}
+extern void grspw_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRCAN_REG {grcan_register_drv}
+extern void grcan_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_OCCAN_REG {occan_register_drv}
+extern void occan_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GR1553B_REG {gr1553_register}
+extern void gr1553_register(void);
+#define DRIVER_AMBAPP_GAISLER_GR1553BC_REG {gr1553bc_register}
+extern void gr1553bc_register(void);
+#define DRIVER_AMBAPP_GAISLER_GR1553BM_REG {gr1553bm_register}
+extern void gr1553bm_register(void);
+#define DRIVER_AMBAPP_GAISLER_GR1553RT_REG {gr1553rt_register}
+extern void gr1553rt_register(void);
+#define DRIVER_AMBAPP_GAISLER_B1553BRM_REG {b1553brm_register_drv}
+extern void b1553brm_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_B1553RT_REG {b1553rt_register_drv}
+extern void b1553rt_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRTM_REG {grtm_register_drv}
+extern void grtm_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRTC_REG {grtc_register_drv}
+extern void grtc_register_drv(void);
+#define DRIVER_AMBAPP_MCTRL_REG {mctrl_register_drv}
+extern void mctrl_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_PCIF_REG {pcif_register_drv}
+extern void pcif_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRPCI_REG {grpci_register_drv}
+extern void grpci_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRPCI2_REG {grpci2_register_drv}
+extern void grpci2_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_SPICTRL_REG {spictrl_register_drv}
+extern void spictrl_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_I2CMST_REG {i2cmst_register_drv}
+extern void i2cmst_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRGPIO_REG {grgpio_register_drv}
+extern void grgpio_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRPWM_REG {grpwm_register_drv}
+extern void grpwm_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRADCDAC_REG {gradcdac_register_drv}
+extern void gradcdac_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_SPWCUC_REG {spwcuc_register}
+extern void spwcuc_register(void);
+#define DRIVER_AMBAPP_GAISLER_GRCTM_REG {grctm_register}
+extern void grctm_register(void);
+#define DRIVER_AMBAPP_GAISLER_SPW_ROUTER_REG {router_register_drv}
+extern void router_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_AHBSTAT_REG {ahbstat_register_drv}
+extern void ahbstat_register_drv(void);
+/*** LEON2 AMBA Hard coded bus Drivers ***/
+#define DRIVER_LEON2_AT697PCI_REG {at697pci_register_drv}
+extern void at697pci_register_drv(void);
+#define DRIVER_LEON2_AMBAPP_REG {ambapp_leon2_register}
+extern void ambapp_leon2_register(void);
+/*** PCI Bus Drivers (PCI Target drivers) ***/
+#define DRIVER_PCI_GR_RASTA_ADCDAC {gr_rasta_adcdac_register_drv}
+extern void gr_rasta_adcdac_register_drv(void);
+#define DRIVER_PCI_GR_RASTA_IO {gr_rasta_io_register_drv}
+extern void gr_rasta_io_register_drv(void);
+#define DRIVER_PCI_GR_RASTA_TMTC {gr_rasta_tmtc_register_drv}
+extern void gr_rasta_tmtc_register_drv(void);
+#define DRIVER_PCI_GR_701 {gr701_register_drv}
+extern void gr701_register_drv(void);
+#define DRIVER_PCI_GR_TMTC_1553 {gr_tmtc_1553_register_drv}
+extern void gr_tmtc_1553_register_drv(void);
+#define DRIVER_PCI_GR_RASTA_SPW_ROUTER {gr_rasta_spw_router_register_drv}
+extern void gr_rasta_spw_router_register_drv(void);
/* CONFIGURE DRIVER MANAGER */
struct drvmgr_drv_reg_func drvmgr_drivers[] = {
-#if 0 /* EXAMPLE: GPTIMER Driver registration */
+ /*** AMBA Plug & Play Drivers ***/
#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GPTIMER
DRIVER_AMBAPP_GAISLER_GPTIMER_REG,
#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_APBUART
+ DRIVER_AMBAPP_GAISLER_APBUART_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRETH
+ DRIVER_AMBAPP_GAISLER_GRETH_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW
+ DRIVER_AMBAPP_GAISLER_GRSPW_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCAN
+ DRIVER_AMBAPP_GAISLER_GRCAN_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_OCCAN
+ DRIVER_AMBAPP_GAISLER_OCCAN_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553B
+ DRIVER_AMBAPP_GAISLER_GR1553B_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553BC
+ DRIVER_AMBAPP_GAISLER_GR1553BC_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553BM
+ DRIVER_AMBAPP_GAISLER_GR1553BM_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553RT
+ DRIVER_AMBAPP_GAISLER_GR1553RT_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_B1553BRM
+ DRIVER_AMBAPP_GAISLER_B1553BRM_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_B1553RT
+ DRIVER_AMBAPP_GAISLER_B1553RT_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRTM
+ DRIVER_AMBAPP_GAISLER_GRTM_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRTC
+ DRIVER_AMBAPP_GAISLER_GRTC_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_PCIF
+ DRIVER_AMBAPP_GAISLER_PCIF_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPCI
+ DRIVER_AMBAPP_GAISLER_GRPCI_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPCI2
+ DRIVER_AMBAPP_GAISLER_GRPCI2_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_MCTRL
+ DRIVER_AMBAPP_MCTRL_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPICTRL
+ DRIVER_AMBAPP_GAISLER_SPICTRL_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_I2CMST
+ DRIVER_AMBAPP_GAISLER_I2CMST_REG,
#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRGPIO
+ DRIVER_AMBAPP_GAISLER_GRGPIO_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPWM
+ DRIVER_AMBAPP_GAISLER_GRPWM_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRADCDAC
+ DRIVER_AMBAPP_GAISLER_GRADCDAC_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPWCUC
+ DRIVER_AMBAPP_GAISLER_SPWCUC_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCTM
+ DRIVER_AMBAPP_GAISLER_GRCTM_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPW_ROUTER
+ DRIVER_AMBAPP_GAISLER_SPW_ROUTER_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_AHBSTAT
+ DRIVER_AMBAPP_GAISLER_AHBSTAT_REG,
+#endif
+ /*** LEON2 AMBA Drivers ***/
+#ifdef CONFIGURE_DRIVER_LEON2_AT697PCI
+ DRIVER_LEON2_AT697PCI_REG,
+#endif
+#ifdef CONFIGURE_DRIVER_LEON2_AMBAPP
+ DRIVER_LEON2_AMBAPP_REG,
+#endif
+ /*** PCI Target Drivers ***/
+#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_ADCDAC
+ DRIVER_PCI_GR_RASTA_ADCDAC,
+#endif
+#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_IO
+ DRIVER_PCI_GR_RASTA_IO,
+#endif
+#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_TMTC
+ DRIVER_PCI_GR_RASTA_TMTC,
+#endif
+#ifdef CONFIGURE_DRIVER_PCI_GR_701
+ DRIVER_PCI_GR_701,
+#endif
+#ifdef CONFIGURE_DRIVER_PCI_GR_TMTC_1553
+ DRIVER_PCI_GR_TMTC_1553,
+#endif
+#ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_SPW_ROUTER
+ DRIVER_PCI_GR_RASTA_SPW_ROUTER,
+#endif
/* Macros for adding custom drivers without needing to recompile
* kernel.
1.7.0.4
