[PATCH 035/111] GRPCI: initialize cache-line-size and latency timer
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:37 UTC 2015
In some GRPCI cores not setting the cache line size could result
in long prefetches on the AMBA bus which would lead to bad
performance when doing PCI reads to GRPCI target interface (DMA).
c/src/lib/libbsp/sparc/shared/pci/grpci.c | 7 +++++++
1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci.c b/c/src/lib/libbsp/sparc/shared/pci/grpci.c
index 0b781d3..eb188bb 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci.c
@@ -449,6 +449,13 @@ int grpci_hw_init(struct grpci_priv *priv)
/* Translate I/O accesses 1:1 */
priv->regs->iomap = priv->pci_io & 0xffff0000;
+ /* Setup Latency Timer and cache line size. Default cache line
+ * size will result in poor performance (256 word fetches), 0xff
+ * will set it according to the max size of the PCI FIFO.
+ grpci_cfg_w8(host, PCI_CACHE_LINE_SIZE, 0xff);
+ grpci_cfg_w8(host, PCI_LATENCY_TIMER, 0x40);
/* set as bus master and enable pci memory responses */
grpci_cfg_r32(host, PCI_COMMAND, &data);
data |= (PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER);
1.7.0.4
