[PATCH 043/111] GRPCI2: updated register layout to newer specification
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:45 UTC 2015
c/src/lib/libbsp/sparc/shared/pci/grpci2.c | 7 ++++---
1 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
index 3891c25..5886336 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
@@ -90,13 +90,14 @@
struct grpci2_regs {
volatile unsigned int ctrl; /* 0x00 */
volatile unsigned int sts_cap; /* 0x04 */
- int res1; /* 0x08 */
+ volatile unsigned int ppref; /* 0x08 */
volatile unsigned int io_map; /* 0x0C */
volatile unsigned int dma_ctrl; /* 0x10 */
volatile unsigned int dma_bdbase; /* 0x14 */
- int res2[2]; /* 0x18 */
+ volatile unsigned int dma_chact; /* 0x18 */
+ int res1; /* 0x1C */
volatile unsigned int bars[6]; /* 0x20 */
- int res3[2]; /* 0x38 */
+ int res2[2]; /* 0x38 */
volatile unsigned int ahbmst_map[16]; /* 0x40 */
1.7.0.4
