[PATCH 052/111] AT697PCI: fix PCI cfg writes
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:54 UTC 2015
c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c | 4 ++--
1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
index 6289a56..423fada 100644
--- a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
+++ b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
@@ -304,7 +304,7 @@ int at697pci_cfg_w32(pci_dev_t dev, int offset, uint32_t val)
int func = PCI_DEV_FUNC(dev);
int retval;
- if (slot > 21 || (offset & ~0xfc))
+ if (slot > 15 || (offset & ~0xfc))
return PCISTS_EINVAL;
regs = at697pcipriv->regs;
@@ -313,7 +313,7 @@ int at697pci_cfg_w32(pci_dev_t dev, int offset, uint32_t val)
if ( bus == 0 ) {
/* PCI Access - TYPE 0 */
- address = (1<<(11+slot)) | (func << 8) | offset;
+ address = (1<<(16+slot)) | (func << 8) | offset;
} else {
/* PCI access - TYPE 1 */
address = ((bus & 0xff) << 16) | ((slot & 0x1f) << 11) |
1.7.0.4
