[PATCH 059/111] GRSPW_PKT: Add support for Interrupt-codes
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:01 UTC 2015
Update: Daniel Hellstrom updated SpW-IRQ implementation accoring to
changes in hardware register layout and features.
c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h | 72 +++++-
c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c | 309 +++++++++++++++++++--
2 files changed, 363 insertions(+), 18 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
index 943dbe0..ee71980 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
@@ -173,6 +173,9 @@ struct grspw_hw_sup {
char strip_pid; /* Hardware can strip PID from packet data */
int hw_version; /* GRSPW Hardware Version */
char reserved[2];
+ char irq; /* SpW Distributed Interrupt available if 1 */
+ char irq_num; /* Number of interrupts that can be generated */
+ char itmr_width; /* SpW Intr. ISR timers bit width. 0=no timer */
struct grspw_core_stats {
@@ -200,11 +203,29 @@ struct grspw_core_stats {
#define TCOPTS_EN_TX 0x0004
#define TCOPTS_EN_RX 0x0008
+/* grspw_ic_ctrl() options:
+ * Corresponds code duplicatingly to GRSPW_CTRL_XX_BIT defines
+#define ICOPTS_INTNUM (0x1f << 27)
+#define ICOPTS_EN_SPWIRQ_ON_EE (1 << 24)
+#define ICOPTS_EN_SPWIRQ_ON_IA (1 << 23)
+#define ICOPTS_EN_PRIO (1 << 22)
+#define ICOPTS_EN_TIMEOUTIRQ (1 << 20)
+#define ICOPTS_EN_ACKIRQ (1 << 19)
+#define ICOPTS_EN_TICKOUTIRQ (1 << 18)
+#define ICOPTS_EN_RX (1 << 17)
+#define ICOPTS_EN_TX (1 << 16)
+#define ICOPTS_BASEIRQ (0x1f << 8)
+#define ICOPTS_EN_FLAGFILTER (1 << 0) /* NOTE: Not in icctrl. CTRL.bit12 */
+/* grspw_ic_rlisr() and grspw_ic_rlintack() */
+#define ICRELOAD_EN (1 << 31)
+#define ICRELOAD_MASK 0x7fffffff
/* grspw_rmap_ctrl() options */
#define RMAPOPTS_EN_RMAP 0x0001
#define RMAPOPTS_EN_BUF 0x0002
/* grspw_dma_config.flags options */
#define DMAFLAG_NO_SPILL 0x0001 /* See HW doc DMA-CTRL NS bit */
#define DMAFLAG_RESV1 0x0002 /* HAS NO EFFECT */
@@ -302,6 +323,55 @@ extern void grspw_tc_isr(void *d, void (*tcisr)(void *data, int tc), void *data)
extern void grspw_tc_time(void *d, int *time);
+/*** Interrupt-code Interface ***/
+struct spwpkt_ic_config {
+ unsigned int tomask;
+ unsigned int aamask;
+ unsigned int scaler;
+ unsigned int isr_reload;
+ unsigned int ack_reload;
+/* Function Interrupt-Code ISR callback prototype. Called when respective
+ * interrupt handling option has been enabled by grspw_ic_ctrl(), the
+ * arguments rxirq, rxack and intto are read from the registers of the
+ * GRSPW core read by the GRSPW ISR, they are individually valid only when
+ * repective handling been turned on.
+ * data - Custom data provided by user
+ * rxirq - Interrupt-Code Recevie register of the GRSPW core read by ISR
+ * (only defined if IQ bit enabled through grspw_ic_ctrl())
+ * rxack - Interrupt-Ack-Code Recevie register of the GRSPW core read by ISR
+ * (only defined if AQ bit enabled through grspw_ic_ctrl())
+ * intto - Interrupt Tick-out Recevie register of the GRSPW core read by ISR
+ * (only defined if TQ bit enabled through grspw_ic_ctrl())
+typedef void (*spwpkt_ic_isr_t)(void *data, unsigned int rxirq,
+ unsigned int rxack, unsigned int intto);
+/* Control Interrupt-code settings of core
+ * Write if 'options' not pointing to -1, always read current value
+extern void grspw_ic_ctrl(void *d, unsigned int *options);
+/* Write (rw&1 == 1) configuration parameters to registers and/or,
+ * Read (rw&2 == 1) configuration parameters from registers, in that sequence.
+extern void grspw_ic_config(void *d, int rw, struct spwpkt_ic_config *cfg);
+/* Read or Write Interrupt-code status registers.
+ * If pointer argument *ptr == 0 then only read, if *ptr != 0 then only write.
+ * If *ptr is NULL no operation.
+extern void grspw_ic_sts(void *d, unsigned int *rxirq, unsigned int *rxack,
+ unsigned int *intto);
+/* Generate Tick-In for the given Interrupt-code
+ * Returns zero on success and non-zero on failure
+ * Interrupt code bits (ic):
+ * Bit 5 - ACK if 1
+ * Bits 4-0 Interrupt-code number
+extern int grspw_ic_tickin(void *d, int ic);
+/* Assign handler function to Interrupt-code timeout IRQ */
+extern void grspw_ic_isr(void *d, spwpkt_ic_isr_t handler, void *data);
/*** RMAP Control Interface ***/
/* Set (not -1) and/or read RMAP options. */
extern int grspw_rmap_ctrl(void *d, int *options, int *dstkey);
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 1696c3c..23d9d9c 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -87,6 +87,19 @@ struct grspw_regs {
* up to 4 channels are supported
struct grspw_dma_regs dma[4];
+ volatile unsigned int icctrl;
+ volatile unsigned int icrx;
+ volatile unsigned int icack;
+ volatile unsigned int ictimeout;
+ volatile unsigned int ictickomask;
+ volatile unsigned int icaamask;
+ volatile unsigned int icrlpresc;
+ volatile unsigned int icrlisr;
+ volatile unsigned int icrlintack;
+ volatile unsigned int resv2;
+ volatile unsigned int icisr;
+ volatile unsigned int resv3;
/* GRSPW - Control Register - 0x00 */
@@ -95,10 +108,13 @@ struct grspw_regs {
#define GRSPW_CTRL_RC_BIT 29
#define GRSPW_CTRL_NCH_BIT 27
#define GRSPW_CTRL_PO_BIT 26
+#define GRSPW_CTRL_ID_BIT 24
+#define GRSPW_CTRL_LE_BIT 22
#define GRSPW_CTRL_PS_BIT 21
#define GRSPW_CTRL_NP_BIT 20
#define GRSPW_CTRL_RD_BIT 17
#define GRSPW_CTRL_RE_BIT 16
+#define GRSPW_CTRL_TF_BIT 12
#define GRSPW_CTRL_TR_BIT 11
#define GRSPW_CTRL_TT_BIT 10
#define GRSPW_CTRL_LI_BIT 9
@@ -116,10 +132,13 @@ struct grspw_regs {
#define GRSPW_CTRL_RC (1<<GRSPW_CTRL_RC_BIT)
#define GRSPW_CTRL_NCH (0x3<<GRSPW_CTRL_NCH_BIT)
#define GRSPW_CTRL_PO (1<<GRSPW_CTRL_PO_BIT)
+#define GRSPW_CTRL_ID (1<<GRSPW_CTRL_ID_BIT)
+#define GRSPW_CTRL_LE (1<<GRSPW_CTRL_LE_BIT)
#define GRSPW_CTRL_PS (1<<GRSPW_CTRL_PS_BIT)
#define GRSPW_CTRL_NP (1<<GRSPW_CTRL_NP_BIT)
#define GRSPW_CTRL_RD (1<<GRSPW_CTRL_RD_BIT)
#define GRSPW_CTRL_RE (1<<GRSPW_CTRL_RE_BIT)
+#define GRSPW_CTRL_TF (1<<GRSPW_CTRL_TF_BIT)
#define GRSPW_CTRL_TR (1<<GRSPW_CTRL_TR_BIT)
#define GRSPW_CTRL_TT (1<<GRSPW_CTRL_TT_BIT)
#define GRSPW_CTRL_LI (1<<GRSPW_CTRL_LI_BIT)
@@ -132,12 +151,18 @@ struct grspw_regs {
#define GRSPW_CTRL_LS (1<<GRSPW_CTRL_LS_BIT)
#define GRSPW_CTRL_LD (1<<GRSPW_CTRL_LD_BIT)
+#define GRSPW_CTRL_IRQSRC_MASK \
+ (GRSPW_CTRL_LI | GRSPW_CTRL_TQ)
+#define GRSPW_ICCTRL_IRQSRC_MASK \
+ (GRSPW_ICCTRL_TQ | GRSPW_ICCTRL_AQ | GRSPW_ICCTRL_IQ)
/* GRSPW - Status Register - 0x04 */
#define GRSPW_STS_LS_BIT 21
#define GRSPW_STS_AP_BIT 9
#define GRSPW_STS_EE_BIT 8
#define GRSPW_STS_IA_BIT 7
-#define GRSPW_STS_WE_BIT 6
+#define GRSPW_STS_WE_BIT 6 /* GRSPW1 */
#define GRSPW_STS_PE_BIT 4
#define GRSPW_STS_DE_BIT 3
#define GRSPW_STS_ER_BIT 2
@@ -148,7 +173,7 @@ struct grspw_regs {
#define GRSPW_STS_AP (1<<GRSPW_STS_AP_BIT)
#define GRSPW_STS_EE (1<<GRSPW_STS_EE_BIT)
#define GRSPW_STS_IA (1<<GRSPW_STS_IA_BIT)
-#define GRSPW_STS_WE (1<<GRSPW_STS_WE_BIT)
+#define GRSPW_STS_WE (1<<GRSPW_STS_WE_BIT) /* GRSPW1 */
#define GRSPW_STS_PE (1<<GRSPW_STS_PE_BIT)
#define GRSPW_STS_DE (1<<GRSPW_STS_DE_BIT)
#define GRSPW_STS_ER (1<<GRSPW_STS_ER_BIT)
@@ -225,6 +250,38 @@ struct grspw_regs {
#define GRSPW_DMAADR_ADDR (0xff<<GRSPW_DMAADR_ADDR_BIT)
#define GRSPW_DMAADR_MASK (0xff<<GRSPW_DMAADR_MASK_BIT)
+/* GRSPW - Interrupt code receive register - 0xa4 */
+#define GRSPW_ICCTRL_INUM_BIT 27
+#define GRSPW_ICCTRL_IA_BIT 24
+#define GRSPW_ICCTRL_LE_BIT 23
+#define GRSPW_ICCTRL_PR_BIT 22
+#define GRSPW_ICCTRL_DQ_BIT 21 /* never used */
+#define GRSPW_ICCTRL_TQ_BIT 20
+#define GRSPW_ICCTRL_AQ_BIT 19
+#define GRSPW_ICCTRL_IQ_BIT 18
+#define GRSPW_ICCTRL_IR_BIT 17
+#define GRSPW_ICCTRL_IT_BIT 16
+#define GRSPW_ICCTRL_NUMI_BIT 13
+#define GRSPW_ICCTRL_BIRQ_BIT 8
+#define GRSPW_ICCTRL_ID_BIT 7
+#define GRSPW_ICCTRL_II_BIT 6
+#define GRSPW_ICCTRL_TXIRQ_BIT 0
+#define GRSPW_ICCTRL_INUM (0x3f << GRSPW_ICCTRL_INUM_BIT)
+#define GRSPW_ICCTRL_IA (1 << GRSPW_ICCTRL_IA_BIT)
+#define GRSPW_ICCTRL_LE (1 << GRSPW_ICCTRL_LE_BIT)
+#define GRSPW_ICCTRL_PR (1 << GRSPW_ICCTRL_PR_BIT)
+#define GRSPW_ICCTRL_DQ (1 << GRSPW_ICCTRL_DQ_BIT)
+#define GRSPW_ICCTRL_TQ (1 << GRSPW_ICCTRL_TQ_BIT)
+#define GRSPW_ICCTRL_AQ (1 << GRSPW_ICCTRL_AQ_BIT)
+#define GRSPW_ICCTRL_IQ (1 << GRSPW_ICCTRL_IQ_BIT)
+#define GRSPW_ICCTRL_IR (1 << GRSPW_ICCTRL_IR_BIT)
+#define GRSPW_ICCTRL_IT (1 << GRSPW_ICCTRL_IT_BIT)
+#define GRSPW_ICCTRL_NUMI (0x7 << GRSPW_ICCTRL_NUMI_BIT)
+#define GRSPW_ICCTRL_BIRQ (0x1f << GRSPW_ICCTRL_BIRQ_BIT)
+#define GRSPW_ICCTRL_ID (1 << GRSPW_ICCTRL_ID_BIT)
+#define GRSPW_ICCTRL_II (1 << GRSPW_ICCTRL_II_BIT)
+#define GRSPW_ICCTRL_TXIRQ (0x3f << GRSPW_ICCTRL_TXIRQ_BIT)
/* RX Buffer Descriptor */
struct grspw_rxbd {
volatile unsigned int ctrl;
@@ -408,6 +465,10 @@ struct grspw_priv {
void (*tcisr)(void *data, int timecode);
void *tcisr_arg;
+ /*** Interrupt-code Handling ***/
+ spwpkt_ic_isr_t icisr;
+ void *icisr_arg;
/* Disable Link on SpW Link error */
int dis_link_on_err;
@@ -475,6 +536,8 @@ void *grspw_open(int dev_no)
priv->tcisr = NULL;
priv->tcisr_arg = NULL;
+ priv->icisr = NULL;
+ priv->icisr_arg = NULL;
grspw_stats_clr(priv);
@@ -664,6 +727,14 @@ spw_link_state_t grspw_link_state(void *d)
return (status & GRSPW_STS_LS) >> GRSPW_STS_LS_BIT;
+/* Enable Global IRQ only if some irq source is set */
+static inline int grspw_is_irqsource_set(unsigned int ctrl, unsigned int icctrl)
+ return (ctrl & GRSPW_CTRL_IRQSRC_MASK) ||
+ (icctrl & GRSPW_ICCTRL_IRQSRC_MASK);
/* options and clkdiv [in/out]: set to -1 to only read current config */
void grspw_link_ctrl(void *d, int *options, int *clkdiv)
@@ -685,8 +756,8 @@ void grspw_link_ctrl(void *d, int *options, int *clkdiv)
ctrl = (ctrl & ~GRSPW_LINK_CFG) |
(*options & GRSPW_LINK_CFG);
- /* Enable Global IRQ only of LI or TQ is set */
- if (ctrl & (GRSPW_CTRL_LI|GRSPW_CTRL_TQ))
+ /* Enable Global IRQ only if some irq source is set */
+ if (grspw_is_irqsource_set(ctrl, REG_READ(®s->icctrl)))
ctrl |= GRSPW_CTRL_IE;
else
ctrl &= ~GRSPW_CTRL_IE;
@@ -728,10 +799,10 @@ void grspw_tc_ctrl(void *d, int *options)
ctrl &= ~(GRSPW_CTRL_TR|GRSPW_CTRL_TT|GRSPW_CTRL_TQ);
ctrl |= (*options & 0xd) << GRSPW_CTRL_TQ_BIT;
- else
+ else
REG_WRITE(®s->ctrl, ctrl);
@@ -756,14 +827,157 @@ void grspw_tc_isr(void *d, void (*tcisr)(void *data, int tc), void *data)
+ struct grspw_priv *priv = d;
+ struct grspw_regs *regs = priv->regs;
+ if (time == NULL)
+ return;
+ if (*time != -1)
+ REG_WRITE(®s->time, *time & (GRSPW_TIME_TCNT | GRSPW_TIME_CTRL));
+ *time = REG_READ(®s->time) & (GRSPW_TIME_TCNT | GRSPW_TIME_CTRL);
+/* Generate Tick-In for the given Interrupt-code and check for generation
+ * error.
+int grspw_ic_tickin(void *d, int ic)
+ IRQFLAGS_TYPE irqflags;
+ unsigned int icctrl, mask;
+ /* Prepare before turning off IRQ */
+ mask = 0x3f << GRSPW_ICCTRL_TXIRQ_BIT;
+ ic = ((ic << GRSPW_ICCTRL_TXIRQ_BIT) & mask) |
+ GRSPW_ICCTRL_II | GRSPW_ICCTRL_ID;
+ SPIN_LOCK_IRQ(&priv->devlock, irqflags);
+ icctrl = REG_READ(®s->icctrl);
+ icctrl &= ~mask;
+ icctrl |= ic;
+ REG_WRITE(®s->icctrl, icctrl); /* Generate SpW Interrupt Tick-In */
+ /* the ID bit is valid after two clocks, so we not to wait here */
+ icctrl = REG_READ(®s->icctrl); /* Check SpW-Int generation error */
+ SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
+ return icctrl & GRSPW_ICCTRL_ID;
+#define ICOPTS_CTRL_MASK ICOPTS_EN_FLAGFILTER
+#define ICOPTS_ICCTRL_MASK \
+ (ICOPTS_INTNUM | ICOPTS_EN_SPWIRQ_ON_EE | ICOPTS_EN_SPWIRQ_ON_IA | \
+ ICOPTS_EN_PRIO | ICOPTS_EN_TIMEOUTIRQ | ICOPTS_EN_ACKIRQ | \
+ ICOPTS_EN_TICKOUTIRQ | ICOPTS_EN_RX | ICOPTS_EN_TX | \
+ ICOPTS_BASEIRQ)
+ * Write if not pointing to -1, always read current value
+ * TODO: A lot of code duplication with grspw_tc_ctrl
+void grspw_ic_ctrl(void *d, unsigned int *options)
+ unsigned int ctrl;
+ unsigned int icctrl;
+ if (options == NULL)
+ return;
+ if (*options != -1) {
+ ctrl = REG_READ(®s->ctrl);
+ ctrl &= ~GRSPW_CTRL_TF; /* Depends on one to one relation between
+ * irqopts bits and ctrl bits */
+ ctrl |= (*options & ICOPTS_CTRL_MASK) <<
+ (GRSPW_CTRL_TF_BIT - 0);
+ icctrl &= ~ICOPTS_ICCTRL_MASK; /* Depends on one to one relation between
+ * irqopts bits and icctrl bits */
+ icctrl |= *options & ICOPTS_ICCTRL_MASK;
+ if (grspw_is_irqsource_set(ctrl, icctrl))
+ ctrl |= GRSPW_CTRL_IE;
+ else
+ ctrl &= ~GRSPW_CTRL_IE;
+ REG_WRITE(®s->ctrl, ctrl);
+ *options = ((REG_READ(®s->ctrl) & ICOPTS_CTRL_MASK) |
+ (REG_READ(®s->icctrl) & ICOPTS_ICCTRL_MASK));
+void grspw_ic_config(void *d, int rw, struct spwpkt_ic_config *cfg)
- if (time == NULL)
+ if (!cfg)
return;
- if (*time != -1)
- REG_WRITE(®s->time, *time & (GRSPW_TIME_TCNT | GRSPW_TIME_CTRL));
- *time = REG_READ(®s->time) & (GRSPW_TIME_TCNT | GRSPW_TIME_CTRL);
+ if (rw & 1) {
+ REG_WRITE(®s->ictickomask, cfg->tomask);
+ REG_WRITE(®s->icaamask, cfg->aamask);
+ REG_WRITE(®s->icrlpresc, cfg->scaler);
+ REG_WRITE(®s->icrlisr, cfg->isr_reload);
+ REG_WRITE(®s->icrlintack, cfg->ack_reload);
+ if (rw & 2) {
+ cfg->tomask = REG_READ(®s->ictickomask);
+ cfg->aamask = REG_READ(®s->icaamask);
+ cfg->scaler = REG_READ(®s->icrlpresc);
+ cfg->isr_reload = REG_READ(®s->icrlisr);
+ cfg->ack_reload = REG_READ(®s->icrlintack);
+/* Read or Write Interrupt-code status registers */
+void grspw_ic_sts(void *d, unsigned int *rxirq, unsigned int *rxack, unsigned int *intto)
+ /* No locking needed since the status bits are clear-on-write */
+ if (rxirq) {
+ if (*rxirq != 0)
+ REG_WRITE(®s->icrx, *rxirq);
+ else
+ *rxirq = REG_READ(®s->icrx);
+ if (rxack) {
+ if (*rxack != 0)
+ REG_WRITE(®s->icack, *rxack);
+ else
+ *rxack = REG_READ(®s->icack);
+ if (intto) {
+ if (*intto != 0)
+ REG_WRITE(®s->ictimeout, *intto);
+ else
+ *intto = REG_READ(®s->ictimeout);
+/* Assign handler function to Interrupt-code tick out IRQ */
+void grspw_ic_isr(void *d, spwpkt_ic_isr_t handler, void *data)
+ priv->icisr_arg = data;
+ priv->icisr = handler;
@@ -2253,8 +2467,9 @@ void grspw_work_func(rtems_task_argument unused)
STATIC void grspw_isr(void *data)
struct grspw_priv *priv = data;
- unsigned int dma_stat, stat, stat_clrmsk, ctrl, timecode;
- int i, handled = 0, message = WORK_NONE;
+ unsigned int dma_stat, stat, stat_clrmsk, ctrl, icctrl, timecode;
+ unsigned int rxirq, rxack, intto;
+ int i, handled = 0, message = WORK_NONE, call_user_int_isr;
#ifdef RTEMS_HAS_SMP
#endif
@@ -2267,9 +2482,40 @@ STATIC void grspw_isr(void *data)
* smallest possible interrupt latency
if ((stat & GRSPW_STS_TO) && (priv->tcisr != NULL)) {
- /* Timecode received. Let custom function handle this */
- timecode = priv->regs->time;
- (priv->tcisr)(priv->tcisr_arg, timecode);
+ ctrl = REG_READ(&priv->regs->ctrl);
+ if (ctrl & GRSPW_CTRL_TQ) {
+ /* Timecode received. Let custom function handle this */
+ timecode = REG_READ(&priv->regs->time) &
+ (GRSPW_TIME_CTRL | GRSPW_TIME_TCNT);
+ (priv->tcisr)(priv->tcisr_arg, timecode);
+ /* Get Interrupt status from hardware */
+ icctrl = REG_READ(&priv->regs->icctrl);
+ if ((icctrl & GRSPW_ICCTRL_IRQSRC_MASK) && (priv->icisr != NULL)) {
+ call_user_int_isr = 0;
+ rxirq = rxack = intto = 0;
+ if ((icctrl & GRSPW_ICCTRL_IQ) &&
+ (rxirq = REG_READ(&priv->regs->icrx)) != 0)
+ call_user_int_isr = 1;
+ if ((icctrl & GRSPW_ICCTRL_AQ) &&
+ (rxack = REG_READ(&priv->regs->icack)) != 0)
+ if ((icctrl & GRSPW_ICCTRL_TQ) &&
+ (intto = REG_READ(&priv->regs->ictimeout)) != 0)
+ /* Let custom functions handle this POTENTIAL SPW interrupt. The
+ * user function is called even if no such IRQ has happened!
+ * User must make sure to clear all interrupts that have been
+ * handled from the three registers by writing a one.
+ if (call_user_int_isr)
+ priv->icisr(priv->icisr_arg, rxirq, rxack, intto);
/* An Error occured? */
@@ -2421,12 +2667,21 @@ STATIC void grspw_hw_stop(struct grspw_priv *priv)
STATIC void grspw_hw_softreset(struct grspw_priv *priv)
int i;
+ unsigned int tmp;
for (i=0; i<priv->hwsup.ndma_chans; i++)
grspw_hw_dma_softreset(&priv->dma[i]);
REG_WRITE(&priv->regs->status, 0xffffffff);
REG_WRITE(&priv->regs->time, 0);
+ /* Clear all but valuable reset values of ICCTRL */
+ tmp = REG_READ(&priv->regs->icctrl);
+ tmp &= GRSPW_ICCTRL_INUM | GRSPW_ICCTRL_BIRQ | GRSPW_ICCTRL_TXIRQ;
+ tmp |= GRSPW_ICCTRL_ID;
+ REG_WRITE(&priv->regs->icctrl, tmp);
+ REG_WRITE(&priv->regs->icrx, 0xffffffff);
+ REG_WRITE(&priv->regs->icack, 0xffffffff);
+ REG_WRITE(&priv->regs->ictimeout, 0xffffffff);
int grspw_dev_count(void)
@@ -2503,7 +2758,7 @@ static int grspw2_init3(struct drvmgr_dev *dev)
struct amba_dev_info *ambadev;
struct ambapp_core *pnpinfo;
int i, size;
- unsigned int ctrl;
+ unsigned int ctrl, icctrl, numi;
union drvmgr_key_value *value;
GRSPW_DBG("GRSPW[%d] on bus %s\n", dev->minor_drv,
@@ -2538,6 +2793,13 @@ static int grspw2_init3(struct drvmgr_dev *dev)
priv->hwsup.rx_unalign = (ctrl & GRSPW_CTRL_RX) >> GRSPW_CTRL_RX_BIT;
priv->hwsup.nports = 1 + ((ctrl & GRSPW_CTRL_PO) >> GRSPW_CTRL_PO_BIT);
priv->hwsup.ndma_chans = 1 + ((ctrl & GRSPW_CTRL_NCH) >> GRSPW_CTRL_NCH_BIT);
+ priv->hwsup.irq = ((ctrl & GRSPW_CTRL_ID) >> GRSPW_CTRL_ID_BIT);
+ numi = (icctrl & GRSPW_ICCTRL_NUMI) >> GRSPW_ICCTRL_NUMI_BIT;
+ if (numi > 0)
+ priv->hwsup.irq_num = 1 << (numi - 1);
+ else
+ priv->hwsup.irq_num = 0;
/* Construct hardware version identification */
priv->hwsup.hw_version = pnpinfo->device << 16 | pnpinfo->apb_slv->ver;
@@ -2552,6 +2814,19 @@ static int grspw2_init3(struct drvmgr_dev *dev)
priv->hwsup.strip_pid = 0;
+ /* Probe width of SpaceWire Interrupt ISR timers. All have the same
+ * width... so only the first is probed, if no timer result will be
+ * zero.
+ REG_WRITE(&priv->regs->icrlpresc, 0x7fffffff);
+ ctrl = REG_READ(&priv->regs->icrlpresc);
+ REG_WRITE(&priv->regs->icrlpresc, 0);
+ priv->hwsup.itmr_width = 0;
+ while (ctrl & 1) {
+ priv->hwsup.itmr_width++;
+ ctrl = ctrl >> 1;
/* Let user limit the number of DMA channels on this core to save
* space. Only the first nDMA channels will be available.
1.7.0.4
