[PATCH 067/111] GRETH: fix build warnings with GCC-4.9
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:09 UTC 2015
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 2 +-
c/src/lib/libbsp/sparc/shared/net/greth.c | 43 +++++++++++++++-------------
2 files changed, 24 insertions(+), 21 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 0be33a9..13eafb5 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -101,7 +101,7 @@ extern int rtems_leon_greth_driver_attach(
/* Configure GRETH driver */
#define GRETH_SUPPORTED
-#define GRETH_MEM_LOAD(addr) leon_r32_no_cache(addr)
+#define GRETH_MEM_LOAD(addr) leon_r32_no_cache((uintptr_t)addr)
extern int CPU_SPARC_HAS_SNOOPING;
diff --git a/c/src/lib/libbsp/sparc/shared/net/greth.c b/c/src/lib/libbsp/sparc/shared/net/greth.c
index 71562a1..d5d477f 100644
--- a/c/src/lib/libbsp/sparc/shared/net/greth.c
+++ b/c/src/lib/libbsp/sparc/shared/net/greth.c
@@ -117,7 +117,7 @@ extern void ipalign(struct mbuf *m);
#endif
const struct timespec greth_tan = {
GRETH_AUTONEGO_TIMEOUT_MS/1000,
- GRETH_AUTONEGO_TIMEOUT_MS*1000000
+ (GRETH_AUTONEGO_TIMEOUT_MS % 1000) * 1000000
/* For optimizing the autonegotiation time */
@@ -213,7 +213,7 @@ static char *almalloc(int sz, int alignment)
/* GRETH interrupt handler */
-void greth_interrupt (void *arg)
+static void greth_interrupt (void *arg)
uint32_t status;
uint32_t ctrl;
@@ -256,16 +256,17 @@ static uint32_t read_mii(struct greth_softc *sc, uint32_t phy_addr, uint32_t reg
sc->regs->mdio_ctrl = (phy_addr << 11) | (reg_addr << 6) | GRETH_MDIO_READ;
while (sc->regs->mdio_ctrl & GRETH_MDIO_BUSY) {}
if (!(sc->regs->mdio_ctrl & GRETH_MDIO_LINKFAIL)) {
- MIIDBG("greth%d: mii read[%d] OK to %x.%x (0x%08x,0x%08x)\n",
- sc->minor, sc->phy_read_access, phy_addr, reg_addr,
- sc->regs->ctrl, sc->regs->mdio_ctrl);
+ MIIDBG("greth%d: mii read[%d] OK to %" PRIx32 ".%" PRIx32
+ " (0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
+ sc->minor, sc->phy_read_access, phy_addr, reg_addr,
+ sc->regs->ctrl, sc->regs->mdio_ctrl);
return((sc->regs->mdio_ctrl >> 16) & 0xFFFF);
} else {
- printf("greth%d: mii read[%d] failed to %x.%x (0x%08x,0x%08x)\n",
- return (0xffff);
+ printf("greth%d: mii read[%d] failed to %" PRIx32 ".%" PRIx32
+ return (0xffff);
@@ -277,13 +278,15 @@ static void write_mii(struct greth_softc *sc, uint32_t phy_addr, uint32_t reg_ad
((data & 0xFFFF) << 16) | (phy_addr << 11) | (reg_addr << 6) | GRETH_MDIO_WRITE;
- MIIDBG("greth%d: mii write[%d] OK to %x.%x (0x%08x,0x%08x)\n",
- sc->minor, sc->phy_write_access, phy_addr, reg_addr,
+ MIIDBG("greth%d: mii write[%d] OK to to %" PRIx32 ".%" PRIx32
+ "(0x%08" PRIx32 ",0x%08" PRIx32 ")\n",
+ sc->minor, sc->phy_write_access, phy_addr, reg_addr,
} else {
- printf("greth%d: mii write[%d] failed to %x.%x (0x%08x,0x%08x)\n",
+ printf("greth%d: mii write[%d] failed to to %" PRIx32 ".%" PRIx32
@@ -310,7 +313,7 @@ static void print_init_info(struct greth_softc *sc)
#ifdef GRETH_AUTONEGO_PRINT_TIME
if ( sc->auto_neg ) {
- printf("Autonegotiation Time: %dms\n", sc->auto_neg_time.tv_sec * 1000 +
+ printf("Autonegotiation Time: %ldms\n", sc->auto_neg_time.tv_sec * 1000 +
sc->auto_neg_time.tv_nsec / 1000000);
#endif
@@ -621,7 +624,7 @@ void ipalign(struct mbuf *m)
#endif
-void
+static void
greth_Daemon (void *arg)
struct ether_header *eh;
@@ -841,7 +844,7 @@ sendpacket (struct ifnet *ifp, struct mbuf *m)
-int
+static int
sendpacket_gbit (struct ifnet *ifp, struct mbuf *m)
struct greth_softc *dp = ifp->if_softc;
@@ -1236,7 +1239,7 @@ greth_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
* Attach an GRETH driver to the system
-int
+static int
greth_interface_driver_attach (
struct rtems_bsdnet_ifconfig *config,
int attach
1.7.0.4
