[PATCH 074/111] APBUART_CONS: fix build warning
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:16 UTC 2015
c/src/lib/libbsp/sparc/Makefile.am | 1 +
c/src/lib/libbsp/sparc/leon3/Makefile.am | 1 +
c/src/lib/libbsp/sparc/leon3/preinstall.am | 4 ++++
.../lib/libbsp/sparc/shared/include/apbuart_cons.h | 16 ++++++++++++++++
c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c | 9 +++++----
5 files changed, 27 insertions(+), 4 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/shared/include/apbuart_cons.h
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index ca93999..de125ca 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -77,6 +77,7 @@ EXTRA_DIST += shared/include/grspw_router.h
EXTRA_DIST += shared/uart/cons.c
EXTRA_DIST += shared/uart/apbuart_cons.c
EXTRA_DIST += shared/include/cons.h
+EXTRA_DIST += shared/include/apbuart_cons.h
EXTRA_DIST += shared/uart/apbuart.c
EXTRA_DIST += shared/include/apbuart.h
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index a61549f..7acd9cb 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -84,6 +84,7 @@ libbsp_a_SOURCES += console/console.c
libbsp_a_SOURCES += ../../sparc/shared/uart/cons.c
libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart_cons.c
include_HEADERS += ../../sparc/shared/include/cons.h
+include_HEADERS += ../../sparc/shared/include/apbuart_cons.h
# debugio
libbsp_a_SOURCES += console/printk_support.c
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 3d92b37..33a295b 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -117,6 +117,10 @@ $(PROJECT_INCLUDE)/cons.h: ../../sparc/shared/include/cons.h $(PROJECT_INCLUDE)/
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/cons.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/cons.h
+$(PROJECT_INCLUDE)/apbuart_cons.h: ../../sparc/shared/include/apbuart_cons.h $(PROJECT_INCLUDE)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/apbuart_cons.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/apbuart_cons.h
$(PROJECT_INCLUDE)/genirq.h: ../../sparc/shared/include/genirq.h $(PROJECT_INCLUDE)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/genirq.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/genirq.h
diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_cons.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_cons.h
new file mode 100644
index 0000000..7aed0a4
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/apbuart_cons.h
@@ -0,0 +1,16 @@
+/* APBUART Console driver interface
+ * COPYRIGHT (c) 2015.
+ * Cobham Gaisler.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef __APBUART_CONS_H__
+#define __APBUART_CONS_H__
+void apbuart_cons_register_drv (void);
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index e0fa64e..8bee2e9 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -32,6 +32,7 @@
#include <grlib.h>
#include <cons.h>
#include <rtems/termiostypes.h>
+#include <apbuart_cons.h>
/*#define DEBUG 1 */
@@ -450,7 +451,7 @@ struct apbuart_baud {
unsigned int num;
unsigned int baud;
-struct apbuart_baud apbuart_baud_table[] = {
+static struct apbuart_baud apbuart_baud_table[] = {
{B50, 50},
{B75, 75},
{B110, 110},
@@ -473,7 +474,7 @@ struct apbuart_baud apbuart_baud_table[] = {
#define BAUD_NUM (sizeof(apbuart_baud_table)/sizeof(struct apbuart_baud))
-int apbuart_baud_num2baud(unsigned int num)
+static int apbuart_baud_num2baud(unsigned int num)
int i;
@@ -483,7 +484,7 @@ int apbuart_baud_num2baud(unsigned int num)
return -1;
-struct apbuart_baud *apbuart_baud_find_closest(unsigned int baud)
+static struct apbuart_baud *apbuart_baud_find_closest(unsigned int baud)
int i, diff;
@@ -511,7 +512,7 @@ int apbuart_get_baud(struct apbuart_priv *uart)
return core_clk_hz / ((scaler + 1) * 8);
-struct apbuart_baud *apbuart_get_baud_closest(struct apbuart_priv *uart)
+static struct apbuart_baud *apbuart_get_baud_closest(struct apbuart_priv *uart)
return apbuart_baud_find_closest(apbuart_get_baud(uart));
1.7.0.4
