[PATCH 086/111] GRTM: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:28 UTC 2015
c/src/lib/libbsp/sparc/shared/include/grtm.h | 3 +++
c/src/lib/libbsp/sparc/shared/tmtc/grtm.c | 10 ++++++----
2 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grtm.h b/c/src/lib/libbsp/sparc/shared/include/grtm.h
index 1bf7681..d61330a 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grtm.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grtm.h
@@ -235,6 +235,9 @@ struct grtm_ioc_stats {
/* Register GRTM driver at driver manager */
void grtm_register_drv(void);
+/* Register GRTM RMAP driver at driver manager */
+void grtm_rmap_register_drv (void);
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c b/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c
index 49025bc..1d9fb00 100644
--- a/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c
+++ b/c/src/lib/libbsp/sparc/shared/tmtc/grtm.c
@@ -649,7 +649,8 @@ static void grtm_hw_get_implementation(struct grtm_priv *pDev, struct grtm_ioc_h
hwcfg->fifo_size= (cfg & GRTM_DMA_CFG_FIFOSZ) >> GRTM_DMA_CFG_FIFOSZ_BIT;
-#warning Extra: Implement proper default calculation from hardware configuration
+/* TODO: Implement proper default calculation from hardware configuration */
static void grtm_hw_get_default_modes(struct grtm_ioc_config *cfg, struct grtm_ioc_hw *hwcfg)
cfg->mode = GRTM_MODE_TM;
@@ -1094,7 +1095,7 @@ static int grtm_schedule_ready(struct grtm_priv *pDev, int ints_off)
/* Do translation */
drvmgr_translate(pDev->dev, CPUMEM_TO_DMA, (void *)curr_frm->payload, (void **)&curr_bd->bd->address);
if ( curr_frm->flags & GRTM_FLAGS_TRANSLATE_AND_REMEMBER ) {
- if ( curr_frm->payload != curr_bd->bd->address ) {
+ if ( curr_frm->payload != (unsigned int *)curr_bd->bd->address ) {
/* Translation needed */
curr_frm->flags &= ~GRTM_FLAGS_TRANSLATE_AND_REMEMBER;
curr_frm->flags |= GRTM_FLAGS_TRANSLATE;
@@ -1313,7 +1314,7 @@ static rtems_device_driver grtm_ioctl(rtems_device_major_number major, rtems_dev
/* We disable interrupt in order to get a snapshot of the registers */
IRQ_GLOBAL_DISABLE(oldLevel);
-#warning IMPLEMENT HWREGS
+/* TODO: implement hwregs */
IRQ_GLOBAL_ENABLE(oldLevel);
break;
@@ -1564,9 +1565,10 @@ static void grtm_interrupt(void *arg)
+#if 0
procceed_processing_interrupts:
+#endif
static rtems_device_driver grtm_initialize(
1.7.0.4
