[PATCH 100/111] GR_701: fix build warnings
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:39:42 UTC 2015
 c/src/lib/libbsp/sparc/shared/include/gr_701.h |    9 ++++++---
 c/src/lib/libbsp/sparc/shared/pci/gr_701.c     |   18 ++++++++----------
 2 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_701.h b/c/src/lib/libbsp/sparc/shared/include/gr_701.h
index 0ff75cc..d0976e9 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gr_701.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_701.h
@@ -27,17 +27,20 @@ extern "C" {
 /* An array of pointers to GR-701 resources. The resources will be
  * used by the drivers controlling the cores on the GR-701 target AMBA bus.
- * The gr_rasta_io_resources is declared weak so that the user can override the
- * default configuration.
+ * The gr701_resources is declared weak so that the user can override the
+ * default configuration. The array must be terminated with a NULL resource.
 extern struct drvmgr_bus_res *gr701_resources[];
 #define GR701_OPTIONS_AMBA   0x01
 #define GR701_OPTIONS_IRQ    0x02
-/* Print information about GR-RASTA-IO PCI board */
+/* Print information about all GR-701 PCI boards */
 void gr701_print(int options);
+/* Print information about one GR-701 PCI board */
+void gr701_print_dev(struct drvmgr_dev *dev, int options);
 /* Register GR-701 driver */
 void gr701_register_drv(void);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_701.c b/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
index 1483008..b52b14a 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
@@ -32,6 +32,7 @@
 #include <drvmgr/drvmgr.h>
 #include <drvmgr/ambapp_bus.h>
 #include <drvmgr/pci_bus.h>
+#include <drvmgr/bspcommon.h>
 #include <genirq.h>
 #include <gr_701.h>
@@ -50,6 +51,7 @@
 int gr701_init1(struct drvmgr_dev *dev);
 int gr701_init2(struct drvmgr_dev *dev);
+void gr701_interrupt(void *arg);
 #define READ_REG(address) (*(volatile unsigned int *)address)
@@ -186,7 +188,6 @@ struct drvmgr_bus_res *gr701_resources[] __attribute__((weak)) =
 	NULL
-int gr701_resources_cnt = 0;
@@ -213,7 +214,7 @@ void gr701_interrupt(void *arg)
 		drvmgr_interrupt_clear(priv->dev, 0);
-int gr701_hw_init(struct gr701_priv *priv)
+static int gr701_hw_init(struct gr701_priv *priv)
 	uint32_t com1;
 	struct pci_bridge_regs *pcib;
@@ -277,7 +278,7 @@ int gr701_hw_init(struct gr701_priv *priv)
 			NULL, &priv->amba_maps[0]);
 	/* Frequency is the same as the PCI bus frequency */
-	drvmgr_freq_get(priv->dev, NULL, &pci_freq_hz);
+	drvmgr_freq_get(priv->dev, 0, &pci_freq_hz);
 	/* Initialize Frequency of AMBA bus */
 	ambapp_freq_init(&priv->abus, NULL, pci_freq_hz);
@@ -293,7 +294,7 @@ int gr701_hw_init(struct gr701_priv *priv)
 	return 0;
-void gr701_hw_init2(struct gr701_priv *priv)
+static void gr701_hw_init2(struct gr701_priv *priv)
 	/* Enable PCI Master (for DMA) */
 	pci_master_enable(priv->pcidev);
@@ -307,6 +308,7 @@ int gr701_init1(struct drvmgr_dev *dev)
 	struct gr701_priv *priv;
 	struct pci_dev_info *devinfo;
 	uint32_t bar0, bar1, bar0_size, bar1_size;
+	int resources_cnt;
 	priv = malloc(sizeof(struct gr701_priv));
 	if ( !priv )
@@ -317,13 +319,9 @@ int gr701_init1(struct drvmgr_dev *dev)
 	priv->dev = dev;
 	/* Determine number of configurations */
-	if ( gr701_resources_cnt == 0 ) {
-		while ( gr701_resources[gr701_resources_cnt] )
-			gr701_resources_cnt++;
+	resources_cnt = get_resarray_count(gr701_resources);
 	/* Generate Device prefix */
 	strcpy(priv->prefix, "/dev/gr701_0");
 	priv->prefix[11] += dev->minor_drv;
 	mkdir(priv->prefix, S_IRWXU | S_IRWXG | S_IRWXO);
@@ -369,7 +367,7 @@ int gr701_init1(struct drvmgr_dev *dev)
 	priv->config.ops = &ambapp_gr701_ops;
 	priv->config.maps_up = &priv->bus_maps_up[0];
 	priv->config.maps_down = &priv->bus_maps_down[0];
-	if ( priv->dev->minor_drv < gr701_resources_cnt ) {
+	if ( priv->dev->minor_drv < resources_cnt ) {
 		priv->config.resources = gr701_resources[priv->dev->minor_drv];
 	} else {
 		priv->config.resources = NULL;
1.7.0.4
