[PATCH 102/111] GR-RASTA-ADCDAC: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:44 UTC 2015
.../libbsp/sparc/shared/include/gr_rasta_adcdac.h | 9 +++++--
.../lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c | 22 +++++++++----------
2 files changed, 16 insertions(+), 15 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h
index 42c7c56..ea8d2f3 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h
@@ -27,8 +27,8 @@ extern "C" {
/* An array of pointers to GR-RASTA-ADCDAC resources. The resources will be
* used by the drivers controlling the cores on the GR-RASTA-ADCDAC target AMBA bus.
- * The gr_rasta_io_resources is declared weak so that the user can override the
- * default configuration.
+ * The gr_rasta_adcdac_resources is declared weak so that the user can override
+ * the default configuration. The array must be terminated with a NULL resource.
extern struct drvmgr_bus_res *gr_rasta_adcdac_resources[];
@@ -36,9 +36,12 @@ extern struct drvmgr_bus_res *gr_rasta_adcdac_resources[];
#define RASTA_ADCDAC_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
#define RASTA_ADCDAC_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
-/* Print information about GR-RASTA-IO PCI board */
+/* Print information about all GR-RASTA-IO PCI boards */
void gr_rasta_adcdac_print(int options);
+/* Print information about one GR-RASTA-IO PCI board */
+void gr_rasta_adcdac_print_dev(struct drvmgr_dev *dev, int options);
/* Register GR-RASTA-IO driver */
void gr_rasta_adcdac_register_drv(void);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
index 3ee6293..145c9f2 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
@@ -30,6 +30,7 @@
#include <drvmgr/drvmgr.h>
#include <drvmgr/ambapp_bus.h>
#include <drvmgr/pci_bus.h>
+#include <drvmgr/bspcommon.h>
#include <genirq.h>
#include <gr_rasta_adcdac.h>
@@ -55,6 +56,7 @@ extern unsigned int _RAM_START;
int gr_rasta_adcdac_init1(struct drvmgr_dev *dev);
int gr_rasta_adcdac_init2(struct drvmgr_dev *dev);
+void gr_rasta_adcdac_isr (void *arg);
struct grpci_regs {
volatile unsigned int cfg_stat;
@@ -179,7 +181,6 @@ struct drvmgr_bus_res *gr_rasta_adcdac_resources[] __attribute__((weak)) =
NULL
-int gr_rasta_adcdac_resources_cnt = 0;
@@ -213,12 +214,11 @@ void gr_rasta_adcdac_isr (void *arg)
DBG("RASTA-ADCDAC-IRQ: 0x%x\n", tmp);
-int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
+static int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
uint32_t data;
unsigned int *page0 = NULL;
struct ambapp_dev *tmp;
- int status;
struct ambapp_ahb_info *ahb;
struct pci_dev_info *devinfo = priv->devinfo;
uint32_t bar0, bar0_size;
@@ -285,7 +285,7 @@ int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
*page0 = 0x80000000;
/* Find GRPCI controller */
- tmp = (void *)ambapp_for_each(&priv->abus,
+ tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
(OPTIONS_ALL|OPTIONS_APB_SLVS),
VENDOR_GAISLER, GAISLER_PCIFBRG,
ambapp_find_by_idx, NULL);
@@ -302,7 +302,7 @@ int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
priv->grpci->page1 = 0x40000000;
/* Find IRQ controller */
VENDOR_GAISLER, GAISLER_IRQMP,
@@ -330,7 +330,7 @@ int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
priv->bus_maps_down[2].size = 0;
/* Find GRPCI controller AHB Slave interface */
(OPTIONS_ALL|OPTIONS_AHB_SLVS),
@@ -353,7 +353,7 @@ int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
return 0;
-int gr_rasta_adcdac_hw_init2(struct gr_rasta_adcdac_priv *priv)
+static int gr_rasta_adcdac_hw_init2(struct gr_rasta_adcdac_priv *priv)
/* Enable DMA by enabling PCI target as master */
pci_master_enable(priv->pcidev);
@@ -371,6 +371,7 @@ int gr_rasta_adcdac_init1(struct drvmgr_dev *dev)
int status;
uint32_t bar0, bar1, bar0_size, bar1_size;
union drvmgr_key_value *value;
+ int resources_cnt;
priv = malloc(sizeof(struct gr_rasta_adcdac_priv));
if ( !priv )
@@ -381,10 +382,7 @@ int gr_rasta_adcdac_init1(struct drvmgr_dev *dev)
priv->dev = dev;
/* Determine number of configurations */
- if ( gr_rasta_adcdac_resources_cnt == 0 ) {
- while ( gr_rasta_adcdac_resources[gr_rasta_adcdac_resources_cnt] )
- gr_rasta_adcdac_resources_cnt++;
+ resources_cnt = get_resarray_count(gr_rasta_adcdac_resources);
/* Generate Device prefix */
@@ -446,7 +444,7 @@ int gr_rasta_adcdac_init1(struct drvmgr_dev *dev)
priv->config.ops = &ambapp_rasta_adcdac_ops;
priv->config.maps_up = &priv->bus_maps_up[0];
priv->config.maps_down = &priv->bus_maps_down[0];
- if ( priv->dev->minor_drv < gr_rasta_adcdac_resources_cnt ) {
+ if ( priv->dev->minor_drv < resources_cnt ) {
priv->config.resources = gr_rasta_adcdac_resources[priv->dev->minor_drv];
} else {
priv->config.resources = NULL;
1.7.0.4
