[PATCH 108/111] AMBAPP_BUS: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:50 UTC 2015
c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c | 41 +++++++++------------
1 files changed, 18 insertions(+), 23 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
index c95e8fd..29a38d9 100644
--- a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c
@@ -145,11 +145,9 @@ int ambapp_int_register(
drvmgr_isr isr,
void *arg)
- struct drvmgr_dev *busdev;
struct ambapp_priv *priv;
int irq;
- busdev = dev->parent->dev;
priv = dev->parent->priv;
/* Get IRQ number from index and device information */
@@ -157,7 +155,8 @@ int ambapp_int_register(
if ( irq < 0 )
return DRVMGR_EINVAL;
- DBG("Register interrupt on 0x%x for dev 0x%x (IRQ: %d)\n", (unsigned int)busdev, (unsigned int)dev, irq);
+ DBG("Register interrupt on 0x%x for dev 0x%x (IRQ: %d)\n",
+ (unsigned int)dev->parent->dev, (unsigned int)dev, irq);
if ( priv->config->ops->int_register ) {
/* Let device override driver default */
@@ -173,11 +172,9 @@ int ambapp_int_unregister(
drvmgr_isr isr,
void *arg)
int irq;
@@ -185,7 +182,8 @@ int ambapp_int_unregister(
if ( irq < 0 )
- DBG("Unregister interrupt on 0x%x for dev 0x%x (IRQ: %d)\n", (unsigned int)busdev, (unsigned int)dev, irq);
+ DBG("Unregister interrupt on 0x%x for dev 0x%x (IRQ: %d)\n",
if ( priv->config->ops->int_unregister ) {
@@ -199,11 +197,9 @@ int ambapp_int_clear(
struct drvmgr_dev *dev,
int index)
int irq;
@@ -211,7 +207,8 @@ int ambapp_int_clear(
if ( irq < 0 )
return -1;
- DBG("Clear interrupt on 0x%x for dev 0x%x (IRQ: %d)\n", (unsigned int)busdev, (unsigned int)dev, irq);
+ DBG("Clear interrupt on 0x%x for dev 0x%x (IRQ: %d)\n",
if ( priv->config->ops->int_clear ) {
@@ -225,11 +222,9 @@ int ambapp_int_mask(
int index)
int irq;
@@ -237,7 +232,8 @@ int ambapp_int_mask(
if ( irq < 0 )
return -1;
- DBG("MASK interrupt on 0x%x for dev 0x%x (IRQ: %d)\n", (unsigned int)busdev, (unsigned int)dev, irq);
+ DBG("MASK interrupt on 0x%x for dev 0x%x (IRQ: %d)\n",
if ( priv->config->ops->int_mask ) {
@@ -251,11 +247,9 @@ int ambapp_int_unmask(
int index)
int irq;
@@ -263,7 +257,8 @@ int ambapp_int_unmask(
if ( irq < 0 )
- DBG("UNMASK interrupt on 0x%x for dev 0x%x (IRQ: %d)\n", (unsigned int)busdev, (unsigned int)dev, irq);
+ DBG("UNMASK interrupt on 0x%x for dev 0x%x (IRQ: %d)\n",
if ( priv->config->ops->int_unmask ) {
@@ -459,7 +454,7 @@ void ambapp_dev_info(
#endif
/* Fix device in last stage */
-int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
+static int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
/* OCCAN speciality:
* Mulitple cores are supported through the same amba AHB interface.
@@ -496,14 +491,14 @@ int ambapp_dev_fixup(struct drvmgr_dev *dev, struct amba_dev_info *pnp)
struct ambapp_dev_reg_struct {
- struct ambapp_bus *abus;
+ struct ambapp_bus *abus;
struct drvmgr_bus *bus;
- struct ambapp_dev *ahb_mst;
- struct ambapp_dev *ahb_slv;
- struct ambapp_dev *apb_slv;
+ struct ambapp_dev *ahb_mst;
+ struct ambapp_dev *ahb_slv;
+ struct ambapp_dev *apb_slv;
-void ambapp_core_register(
+static void ambapp_core_register(
struct ambapp_dev *ahb_mst,
struct ambapp_dev *ahb_slv,
struct ambapp_dev *apb_slv,
@@ -595,7 +590,7 @@ void ambapp_core_register(
/* Register one AMBA device */
-int ambapp_dev_register(struct ambapp_dev *dev, int index, void *arg)
+static int ambapp_dev_register(struct ambapp_dev *dev, int index, void *arg)
struct ambapp_dev_reg_struct *p = arg;
@@ -672,7 +667,7 @@ int ambapp_dev_register(struct ambapp_dev *dev, int index, void *arg)
/* Register all AMBA devices available on the AMBAPP bus */
-int ambapp_ids_register(struct drvmgr_bus *bus)
+static int ambapp_ids_register(struct drvmgr_bus *bus)
struct ambapp_priv *priv = bus->priv;
1.7.0.4
