[PATCH 002/111] LEON3: GPTIMER timer watchdog driver
Daniel Hellstrom
daniel at gaisler.com
Fri Feb 27 08:55:22 UTC 2015
On 02/26/2015 07:13 PM, Gedare Bloom wrote:
> bsp-specific headers should not be installed to include/. this has
> historically been allowed but we want to get away from it.
Ok, this is a problem for all drivers I submit. I will add a patch in the end to move all existing BSP drivers and all new BSP drivers headers into include/bsp. Is that okay?
> On Thu, Feb 26, 2015 at 11:38 AM, Daniel Hellstrom <daniel at gaisler.com> wrote:
>> Last timer instance of GPTIMER is sometimes a watchdog timer that
>> can reset the system on timer underflow.
>> c/src/lib/libbsp/sparc/leon3/Makefile.am | 2 +
>> c/src/lib/libbsp/sparc/leon3/include/watchdog.h | 49 ++++++++++++
>> c/src/lib/libbsp/sparc/leon3/preinstall.am | 4 +
>> c/src/lib/libbsp/sparc/leon3/timer/watchdog.c | 90 +++++++++++++++++++++++
>> 4 files changed, 145 insertions(+), 0 deletions(-)
>> create mode 100644 c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>> create mode 100644 c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> index cec0b34..4cb6e79 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>> @@ -125,6 +125,8 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
>> # timer
>> libbsp_a_SOURCES += timer/timer.c
>> +libbsp_a_SOURCES += timer/watchdog.c
>> +include_HEADERS += include/watchdog.h
>> # Cache
>> libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>> diff --git a/c/src/lib/libbsp/sparc/leon3/include/watchdog.h b/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>> new file mode 100644
>> index 0000000..fd984e1
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/leon3/include/watchdog.h
>> @@ -0,0 +1,49 @@
>> +/* watchdog.h
>> + * The LEON3 BSP timer watch-dog interface
>> + * COPYRIGHT (c) 2012.
>> + * Cobham Gaisler AB.
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.com/license/LICENSE.
>> +#ifndef __WATCHDOG_H__
>> +#define __WATCHDOG_H__
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif
>> +/* Initialize BSP watchdog routines. Returns number of watchdog timers found.
>> + * Currently only one is supported.
>> +int bsp_watchdog_init(void);
>> +/* Reload watchdog (last timer on the first GPTIMER core), all systems does not
>> + * feature a watchdog, it is expected that if this function is called the
>> + * user knows that there is a watchdog available.
>> + * The prescaler is normally set to number of MHz of system, this is to
>> + * make the system clock tick be stable.
>> + * Arguments
>> + * watchdog - Always 0 for now
>> + * reload_value - Number of timer clocks (after prescaler) to count before
>> + * watchdog is woken.
>> +void bsp_watchdog_reload(int watchdog, unsigned int reload_value);
>> +/* Stop watchdog timer */
>> +void bsp_watchdog_stop(int watchdog);
>> +/* Use watchdog0 timer to reset the system */
>> +void bsp_watchdog_system_reset(void);
>> +#ifdef __cplusplus
>> +#endif
>> +#endif
>> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> index d7b28e4..0c0139f 100644
>> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>> @@ -165,3 +165,7 @@ $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLU
>> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
>> +$(PROJECT_INCLUDE)/watchdog.h: include/watchdog.h $(PROJECT_INCLUDE)/$(dirstamp)
>> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/watchdog.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/watchdog.h
>> diff --git a/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>> index 0000000..15e2142
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/sparc/leon3/timer/watchdog.c
>> @@ -0,0 +1,90 @@
>> +/* GPTIMER Watchdog timer routines. On some systems the first GPTIMER
>> + * core's last Timer instance underflow signal is connected to system
>> + * reset.
>> +#include <bsp.h>
>> +#include <watchdog.h>
>> +#include <grlib.h>
>> +extern volatile struct gptimer_regs *LEON3_Timer_Regs;
>> +struct gptimer_watchdog_priv {
>> + struct gptimer_regs *regs;
>> + struct gptimer_timer_regs *timer;
>> + int timerno;
>> +struct gptimer_watchdog_priv bsp_watchdogs[1];
>> +int bsp_watchdog_count = 0;
>> + int timercnt;
>> + if (!LEON3_Timer_Regs)
>> + return 0;
>> + /* Get Watchdogs in system, this is implemented for one GPTIMER core
>> + * only.
>> + * First watchdog is a special case, we can get the first timer core by
>> + * looking at LEON3_Timer_Regs, the watchdog within a timer core is
>> + * always the last timer. Unfortunately we can not know it the watchdog
>> + * functionality is available or not, we assume that it is if we
>> + * reached this function.
>> + bsp_watchdogs[0].regs = (struct gptimer_regs *)LEON3_Timer_Regs;
>> + /* Find Timer that has watchdog functionality */
>> + timercnt = bsp_watchdogs[0].regs->cfg & 0x7;
>> + if (timercnt < 2) /* First timer system clock timer */
>> + return 0;
>> + bsp_watchdogs[0].timerno = timercnt - 1;
>> + bsp_watchdogs[0].timer = &bsp_watchdogs[0].regs->timer[bsp_watchdogs[0].timerno];
>> + bsp_watchdog_count = 1;
>> + return bsp_watchdog_count;
>> + if (bsp_watchdog_count == 0)
>> + bsp_watchdog_init();
>> + if (bsp_watchdog_count <= watchdog)
>> + return;
>> + /* Kick watchdog, and clear interrupt pending bit */
>> + bsp_watchdogs[watchdog].timer->reload = reload_value;
>> + bsp_watchdogs[watchdog].timer->ctrl =
>> + (LEON3_GPTIMER_LD | LEON3_GPTIMER_EN) |
>> + (bsp_watchdogs[watchdog].timer->ctrl & ~(1<<4));
>> + return;
>> + /* Stop watchdog timer */
>> + bsp_watchdogs[watchdog].timer->ctrl = 0;
>> +/* Use watchdog timer to reset system */
>> + sparc_disable_interrupts();
>> + bsp_watchdog_reload(0, 1);
>> 1.7.0.4
>> devel mailing list
>> devel at rtems.org
