Moxie BSP Build Failure
Anthony Green green at moxielogic.com
Fri Jan 2 06:10:29 UTC 2015
Joel Sherrill <joel.sherrill at oarcorp.com> writes:
> Hi
> This is with the binutils and gcc heads.
Change "sub.l" to "sub" and you're good.  I've been testing with this.  Sorry about the change!
AG
> moxie-rtems4.11-gcc --pipe -B../../../../../.././lib/
> -B../../../../../.././moxiesim/lib/ -specs bsp_specs -qrtems
> -DHAVE_CONFIG_H   -isystem ../../../../../.././moxiesim/lib/include
> -DASM -Os -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -MT start.o -MD -MP -MF .deps/start.Tpo -c -o start.o
> `test -f 'start/start.S' || echo
> '../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/'`start/start.S
> ../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/start/start.S:
> Assembler messages:
> ../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/start/start.S:15:
> Error: unknown opcode sub.l $r2,$r0
