Moxie BSP Build Failure
Fri Jan 2 16:31:23 UTC 2015
On 1/2/2015 12:10 AM, Anthony Green wrote:
> Joel Sherrill <joel.sherrill at oarcorp.com> writes:
>> Hi
>> This is with the binutils and gcc heads.
> Change "sub.l" to "sub" and you're good.  I've been testing with this.  Sorry about the change!
Thanks. Will this still work with the old tools?
--joel
> AG
>> moxie-rtems4.11-gcc --pipe -B../../../../../.././lib/
>> -B../../../../../.././moxiesim/lib/ -specs bsp_specs -qrtems
>> -DHAVE_CONFIG_H   -isystem ../../../../../.././moxiesim/lib/include
>> -DASM -Os -g -ffunction-sections -fdata-sections -Wall
>> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
>> -Wnested-externs -MT start.o -MD -MP -MF .deps/start.Tpo -c -o start.o
>> `test -f 'start/start.S' || echo
>> '../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/'`start/start.S
>> ../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/start/start.S:
>> Assembler messages:
>> ../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/start/start.S:15:
>> Error: unknown opcode sub.l $r2,$r0
