can't compile both_hello - POSIX API error
Dominik Táborský
Bremby at seznam.cz
Sun Jan 4 19:20:31 UTC 2015
Hello,
I've configured RTEMS with --enable-posix, run make, make install. Everything went smoothly, didn't notice any error. But when I run make in the both_hello example, it errors:
In file included from test.c:55:0:
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h: At top level:
/opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h:2945:4: error: #error "CONFIGURATION ERROR: POSIX API support not configured!!"
All repos are up-to-date, ran make clean between configs and even manually deleted the installed RTEMS files to ensure new ones are being installed. Any ideas?
Thanks.
Dominik
