Trouble building examples-v2 with waf. Was: Re: can't compile both_hello - POSIX API error
Sun Jan 4 21:09:16 UTC 2015
On 1/4/2015 2:47 PM, Dominik Taborsky wrote:
> On Sun, 04 Jan 2015 21:12:16 +0100, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On January 4, 2015 2:05:13 PM CST, Dominik Taborsky <bremby at seznam.cz>
>> wrote:
>>> On Sun, 04 Jan 2015 20:53:16 +0100, Joel Sherrill
>>>> On January 4, 2015 1:20:31 PM CST, "Dominik Táborský"
>>> <Bremby at seznam.cz>
>>>> wrote:
>>>>> Hello,
>>>>> I've configured RTEMS with --enable-posix, run make, make install.
>>>>> Everything went smoothly, didn't notice any error. But when I run
>>> make
>>>>> in the both_hello example, it errors:
>>>>> In file included from test.c:55:0:
>>>>> /opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h: At
>>>>> top level:
>>> /opt/rtems-4.11/sparc-rtems4.11/sis/lib/include/rtems/confdefs.h:2945:4:
>>>>> error: #error "CONFIGURATION ERROR: POSIX API support not
>>> configured!!"
>>>>>    #error "CONFIGURATION ERROR: POSIX API support not configured!!"
>>>>> All repos are up-to-date, ran make clean between configs and even
>>>>> manually deleted the installed RTEMS files to ensure new ones are
>>> being
>>>>> installed. Any ideas?
>>>> How did you configure RTEMS? If you has --disable-posix, then this is
>>>> expected.
>>> As I said in the beginning of the mail, I configured it with
>>> --enable-posix. Or would you like the whole command?
>> Sure. Since it worked for me, that's the next step.
> OK. I've completely rebuilt RTEMS from scratch and it works now. It looks
> like some old config was still in place.
> Now I have a different problem - waf has trouble building examples-v2 in
> root of the repo. GCC complains about bsp_specs trying to rename spec
> 'endfile' to already defined spec 'old_endfile'. It happens quite randomly
> among the files. I've never worked with these bsp specs before, so I'm at
> my wit's end.
> sparc-rtems4.11-gcc: fatal error:
> /opt/rtems-4.11//sparc-rtems4.11/sis/lib/bsp_specs: attempt to rename spec
> compilation terminated.
These tools are in /opt. Did you build them using the RTEMS Source
Builder (RSB)
or install RPMs?
This isn't a waf problem but looks like a tools issue.
> Any advice?
> Dominik
