Trouble building examples-v2 with waf. Was: Re: can't compile both_hello - POSIX API error
Tue Jan 6 01:40:48 UTC 2015
On 6/01/2015 8:29 am, Dominik Taborsky wrote:
> Waf is configured (hopefully) fine. Otherwise it wouldn't even try to
> build. Has anyone had any similar problem?
> waf configure was run with these options: --rtems=/opt/rtems-4.11/
> --rtems-tools=$HOME/development/RTEMS-tools/4.11 --rtems-bsps=sparc/sis
What happens if you use --rtems=/opt/rtems-4.11 ?
