dl01 Makefile was Re: Problem when running all tests
Fri Jan 16 21:50:42 UTC 2015
On 17/01/2015 8:20 am, Joel Sherrill wrote:
> On 1/16/2015 2:46 PM, Marcos Díaz wrote:
>> Hi, We were running all tests for the TMS570 and we could see that
>> these two tests:
>> /testsuites/libtests/dl01
>> /testsuites/libtests/dl02
>> failed to build.
>> We saw in theirs Makefile.am that have this line:
>> |rm dl01.pre.ralf|
>> |And there it fails. We could see that not all the bsp have as a postlink instruction to generate a .ralf file, so was our case and that's why it fails.|
> I don't know why I haven't seen this before but apparently if you
> do a second make, it works.
> I changed the subject. I think it needs to be rm -f in case it isn't there.
Yes adding a -f should do the trick. I suspect this is due to the
$(make-exe) macro not creating a .ralf file.
Marcos, would you like to create a patch ?
Thanks
