RTEMS - sparc/leon3 BSP configure script error
Marcos Díaz marcos.diaz at tallertechnologies.com
Fri Jan 16 18:12:16 UTC 2015
Hi, have you tried to run ./bootstrap in the source code folder?
On Fri, Jan 16, 2015 at 9:57 AM, Francois ARSENAULT <
Francois.Arsenault at mdacorporation.com> wrote:
>  Hello,
> I am new to RTEMS and I want to build a RTEMS application for the
> sparc/leon3 BSP.
> For start, I just want to compile/build RTEMS as is without any
> modification.
> I have the following issue: when executed, the “configure” script
> generates this error:
> ../../configure --target=sparc-rtems
> --prefix=/cygdrive/c/COLKa/src/rtems-4.10.2
> ../../configure: line 1779: syntax error near unexpected token `.'
> ../../configure: line 1779: `RTEMS_TOP(.)'
> Here are the details of the host/target and build commands
> 1) The host is Windows7/Cygwin-32bits
> 2) The RTEMS version is rtems-4.10.2.tar.bz2 (downloaded from
> http://git.rtems.org/rtems/)
> 3) Build commands:
> tar xjvf rtems-4.10.2.tar.bz2
> cd rtems-4.10.2
> ln -s /bin/gcc.exe /bin/cc.exe
> export
> PATH=/cygdrive/c/opt/sparc-elf-4.4.2-mingw/bin:/cygdrive/c/opt/rtems-4.10-mingw/bin:${PATH}
> aclocal-1.11
> autoscan-2.69
> autoconf-2.69
> automake-1.11 --add-missing
> cd tools/build
> ../../configure -target=sparc-rtems
> THIS COMMAND GENERATES THE FOLLOWING ERRORS:
> It seems that “RTEMS_TOP” is not defined.
> I have also tried a RTEMS Gaisler distribution
> (rtems-4.8-1.1.2-src.tar.bz2) using  a Linux/Ubuntu host and I have the
> same error.
> I have also try different autoconf and automake versions and I have the
> same error.
> How can I fix this issue?
> Thanks,
> Francois Arsenault
> Software Engineer
> devel mailing list
> devel at rtems.org
<http://www.tallertechnologies.com>
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150116/952ab11c/attachment-0002.html>
