dl01 Makefile was Re: Problem when running all tests
Marcos Díaz marcos.diaz at tallertechnologies.com
Mon Jan 19 13:02:33 UTC 2015
Hi, I didn't know how to submit it but I have it here:
On Fri, Jan 16, 2015 at 6:50 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/01/2015 8:20 am, Joel Sherrill wrote:
>> On 1/16/2015 2:46 PM, Marcos Díaz wrote:
>>> Hi, We were running all tests for the TMS570 and we could see that
>>> these two tests:
>>> /testsuites/libtests/dl01
>>> /testsuites/libtests/dl02
>>> failed to build.
>>> We saw in theirs Makefile.am that have this line:
>>> |rm dl01.pre.ralf|
>>> |And there it fails. We could see that not all the bsp have as a
>>> postlink instruction to generate a .ralf file, so was our case and that's
>>> why it fails.|
>> I don't know why I haven't seen this before but apparently if you
>> do a second make, it works.
>> I changed the subject. I think it needs to be rm -f in case it isn't
>> there.
> Yes adding a -f should do the trick. I suspect this is due to the
> $(make-exe) macro not creating a .ralf file.
> Marcos, would you like to create a patch ?
> Thanks
> Chris
______________________________
<http://www.tallertechnologies.com>
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150119/1ea0ab22/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150119/1ea0ab22/attachment-0002.bin>
