SMP support for Raspberry Pi 2
Fri Jul 3 17:13:26 UTC 2015
On July 3, 2015 11:53:07 AM CDT, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
>Any help that I can with this?
>On 1 Jul 2015 16:59, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>Hi all,
>I wish to know where the maximum number of processors for a variant are
>configured. I took a look at some configure scripts. I could see the
>processor count defined for xilinx-zynq in its configuration file as
>ZYNQ_CPUS=2.
This looks to be BSP specific and could originate in configure.ac or a .h file.
It is likely that each BSP has an underlying hardware limit.
>rtems_configuration_get_maximum_processors() called in gets this
>configured number. But I don't know from where.
This is set initially based on the confdefs.h parameter CONFIGURE_SMP_MAXIMUM_PROCESSORS or something close to that (on phone).
Ultimately the maximum CPUs for an application is the lower of those available or RTEMS is configured for.
>Also where is RTEMS_SMP defined for a bsp?
A side-effect of building with --enable-smp.
>Thanks.
>Rohini Kulkarni
--joel
