Patch: RaspberryPi clock driver
Jan Sommer soja-lists at aries.uberspace.de
Tue Jul 7 21:18:51 UTC 2015
Am Dienstag, 7. Juli 2015, 16:06:11 schrieb Joel Sherrill:
> Thanks!
> That applied perfectly and I just pushed it.
> Hopefully it corrected the anomalies you saw.
Forgot to mention it. I tested it with the example from earlier and the delays worked fine then.
> FWIW I just noticed the Pi clock driver does not have support
> for getting the nanoseconds since the last tick so timestamps
> will have the granularity of the clock tick.
Well, for me it's less about nanoseconds accuracy, it's just what the Ada runtimes seems to use.
> On 7/7/2015 3:52 PM, Jan Sommer wrote:
> > Hi,
> > I hope that's how this works. Here is a patch for the raspberrypi clock driver to use the correct value for the timer counter based on rtems_configuration_get_microseconds_per_tick() as discussed in the user-list.
> > Cheers,
> >     Jan
