Code refactor for ARM bsp MMU initialization
Wed Jul 8 13:34:50 UTC 2015
On 08/07/15 15:10, Rohini Kulkarni wrote:
> On Wed, Jul 8, 2015 at 6:29 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello Rohini,
>     please use git format-patch to generate the patches.
> Actually,that is what I have used. I pasted the patch here from the
> resulting file.
Better use git send-email, or send the file as is since this will
preserve the commit message and author.
>     On 08/07/15 14:44, Rohini Kulkarni wrote:
>         +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstartmmu.c
>         @@ -0,0 +1,30 @@
>         +#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
>         +#include <bsp/start.h>
>         +#include <bsp/arm-cp15-start.h>
>         +#include <bsp/linker-symbols.h>
>         +#include <libcpu/arm-cp15.h>
>         +#include <bsp/mm.h>
>         +#include <bsp.h>
>         +uint32_t bsp_initial_mmu_ctrl_set;
>         +uint32_t bsp_initial_mmu_ctrl_clear;
>         +uint32_t domain_set;
>         +void raspberrypi_setup_mmu_and_cache(void)
>         +#if (BSP_IS_RPI2 == 1)
>         +  /* Enable SMP in auxiliary control */
>         +  uint32_t actlr = arm_cp15_get_auxiliary_control();
>         +  actlr |= ARM_CORTEX_A9_ACTL_SMP;
>         +  arm_cp15_set_auxiliary_control(actlr);
>         +  bsp_initial_mmu_ctrl_clear = ARM_CP15_CTRL_A;
>         +  bsp_initial_mmu_ctrl_set = ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z;
>         +#else
>         +  bsp_initial_mmu_ctrl_clear = 0;
>         ARM_CP15_CTRL_S | ARM_CP15_CTRL_XP;
>         +#endif
>         +  domain_set = ARM_MMU_DEFAULT_CLIENT_DOMAIN;
>         +  bsp_memory_management_initialize();
>     Is there a reason, why you use global variables instead of
>     function parameters?
> I have set them as extern in mm.h and are directly used in mminit.c
> instead of being passed to bsp_memory_management_initialize. They will
> be set by the bsp the source is being compiled for.
You should avoid global variables and functions in general. I don't see
a necessity for them here.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
