[PATCH] Code refactor: Changes to memory management initialization
Mon Jul 13 06:29:20 UTC 2015
On 12/07/15 18:58, Rohini Kulkarni wrote:
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstartmmu.c
> b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstartmmu.c
> new file mode 100644
> index 0000000..3741070
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstartmmu.c
> @@ -0,0 +1,34 @@
> +#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
> +#include <bsp/start.h>
> +#include <bsp/arm-cp15-start.h>
> +#include <bsp/linker-symbols.h>
> +#include <libcpu/arm-cp15.h>
> +#include <bsp/mm.h>
> +#include <bsp.h>
> +void raspberrypi_setup_mmu_and_cache(void)
> +  uint32_t bsp_initial_mmu_ctrl_set;
> +  uint32_t bsp_initial_mmu_ctrl_clear;
> +  uint32_t domain_set;
Why is this a global visible function?
Why do we need the domain_set parameter?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
