SMP support for Raspberry Pi 2
Gedare Bloom gedare at gwu.edu
Mon Jul 13 15:43:31 UTC 2015
Did you change configure, or configure.ac?
After you change configure.ac or Makefile.am files, you need to run
sb-bootstrap again.
On Sun, Jul 12, 2015 at 7:05 AM, Rohini Kulkarni <krohini1593 at gmail.com> wrote:
> Hi,
> I don't have #define RTEMS_SMP 1 in cpuopts.h.
> Have made changes only to libbsp/arm/raspberrypi/configure .
> On Sun, Jul 12, 2015 at 1:50 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> In the build tree, there are exactly two identical "cpuopts.h" files. In
>> this file you must find a:
>> /* if SMP is enabled */
>> #define RTEMS_SMP 1
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Rohini Kulkarni
> devel mailing list
> devel at rtems.org
