[PATCH] altq_subr.c: Disable x86 specific code on RTEMS
Wed Jul 15 15:31:01 UTC 2015
OK but what about the patch itself technically?
It was only subtracting a blank line so once I fix that,
what else?
On 7/15/2015 2:59 AM, Sebastian Huber wrote:
> I tried to clarify the rules for FreeBSD code changes:
> https://git.rtems.org/rtems-libbsd/commit/?id=a57dfa0dedc1f25c4dfd6e0c786a1dbf72f44a03
> On 15/07/15 00:42, Joel Sherrill wrote:
>>    freebsd/sys/contrib/altq/altq/altq_subr.c |    7 ++++++-
>>    1 files changed, 6 insertions(+), 1 deletions(-)
>> diff --git a/freebsd/sys/contrib/altq/altq/altq_subr.c b/freebsd/sys/contrib/altq/altq/altq_subr.c
>> index 3ebd58d..55f0977 100644
>> --- a/freebsd/sys/contrib/altq/altq/altq_subr.c
>> +++ b/freebsd/sys/contrib/altq/altq/altq_subr.c
>> @@ -930,6 +930,9 @@ init_machclk_setup(void)
>>    #if defined(__NetBSD__) && defined(MULTIPROCESSOR)
>>    	machclk_usepcc = 0;
>>    #endif
>> +#if defined(__rtems__)
>> +		machclk_usepcc = 0;
>> +#else
>>    #if defined(__amd64__) || defined(__i386__)
>>    	/* check if TSC is available */
>>    #ifdef __FreeBSD__
>> @@ -940,6 +943,7 @@ init_machclk_setup(void)
>>    #endif
>>    		machclk_usepcc = 0;
>>    #endif
>> +#endif
>>    void
>> @@ -967,6 +971,7 @@ init_machclk(void)
>>    	 * if the clock frequency (of Pentium TSC or Alpha PCC) is
>>    	 * accessible, just use it.
>> +#ifndef __rtems__
>>    #ifdef __FreeBSD__
>>    	machclk_freq = atomic_load_acq_64(&tsc_freq);
>> @@ -976,7 +981,7 @@ init_machclk(void)
>>    	machclk_freq = pentium_mhz * 1000000;
>>    #endif
>>    #endif
>> +#endif
>>    	 * if we don't know the clock frequency, measure it.
