[PATCH] bsp/tms570: fix get time resolution after infrastructure change to timecounter.
Martin Galvan martin.galvan at tallertechnologies.com
Wed Jul 15 19:51:52 UTC 2015
On Wed, Jul 15, 2015 at 3:33 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
> Hello Martin,
> Try to help us when we try to do TMS570 RTEMS work based
> on my belief that it worth to be done for RTEMS but
> without any actual or directly foreseen project/funding
> backup. Try the code it would ease and shorten this
> discussion. Or found another issue. But is the way forwad
> instead of need to describe he problem third time.
Fair enough. I'll go ahead and update to the latest mainline, then
I'll test this patch. If you want to commit this in the meanwhile it's
fine for me if Joel thinks it's ok.
However (and forgive me for insisting on this so much), I'd still like
to know why we have to drop the HALCoGen formula. If we definitely
have to drop it, as a maintainer I'd appreciate a detailed comment
explaining why we did it.
Thanks a lot!
