[PATCH] bsp/tms570: fix get time resolution after infrastructure change to timecounter.
Wed Jul 15 20:44:45 UTC 2015
On 7/15/2015 2:51 PM, Martin Galvan wrote:
> On Wed, Jul 15, 2015 at 3:33 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
>> Hello Martin,
>> Try to help us when we try to do TMS570 RTEMS work based
>> on my belief that it worth to be done for RTEMS but
>> without any actual or directly foreseen project/funding
>> backup. Try the code it would ease and shorten this
>> discussion. Or found another issue. But is the way forwad
>> instead of need to describe he problem third time.
> Fair enough. I'll go ahead and update to the latest mainline, then
> I'll test this patch. If you want to commit this in the meanwhile it's
> fine for me if Joel thinks it's ok.
I don't have this hardware but it looked benign and fixing a bug
caused by recent timecounter changesto me.
FWIW I will wait until the morning to branch but think this patch
is OK and would like me or someone else to commit it if that's the
general consensus.
> However (and forgive me for insisting on this so much), I'd still like
> to know why we have to drop the HALCoGen formula. If we definitely
> have to drop it, as a maintainer I'd appreciate a detailed comment
> explaining why we did it.
That's a reasonable question.
> Thanks a lot!
> devel mailing list
> devel at rtems.org
