[PATCH] Fix buiding for the i386.
Thu Jul 16 10:55:22 UTC 2015
 freebsd/sys/contrib/altq/altq/altq_subr.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/freebsd/sys/contrib/altq/altq/altq_subr.c b/freebsd/sys/contrib/altq/altq/altq_subr.c
index 3ebd58d..cfa5c7e 100644
--- a/freebsd/sys/contrib/altq/altq/altq_subr.c
+++ b/freebsd/sys/contrib/altq/altq/altq_subr.c
@@ -292,7 +292,7 @@ altq_disable(ifq)
 	ASSERT(ifq->ifq_len == 0);
 	ifq->altq_flags &= ~(ALTQF_ENABLED|ALTQF_CLASSIFY);
 	splx(s);
 	IFQ_UNLOCK(ifq);
 	return 0;
@@ -379,7 +379,7 @@ tbr_set(ifq, profile)
 	struct tb_profile *profile;
 	struct tb_regulator *tbr, *otbr;
 	if (tbr_dequeue_ptr == NULL)
 		tbr_dequeue_ptr = tbr_dequeue;
@@ -930,6 +930,7 @@ init_machclk_setup(void)
 #if defined(__NetBSD__) && defined(MULTIPROCESSOR)
 	machclk_usepcc = 0;
 #endif
+#if !defined(__rtems__)
 #if defined(__amd64__) || defined(__i386__)
 	/* check if TSC is available */
 #ifdef __FreeBSD__
@@ -938,6 +939,7 @@ init_machclk_setup(void)
 #else
 	if ((cpu_feature & CPUID_TSC) == 0)
 #endif
+#endif /* __rtems__ */
 		machclk_usepcc = 0;
 #endif
@@ -968,6 +970,7 @@ init_machclk(void)
 	 * accessible, just use it.
+#ifndef __rtems__
 #ifdef __FreeBSD__
 	machclk_freq = atomic_load_acq_64(&tsc_freq);
 #elif defined(__NetBSD__)
@@ -975,6 +978,7 @@ init_machclk(void)
 #elif defined(__OpenBSD__) && (defined(I586_CPU) || defined(I686_CPU))
 	machclk_freq = pentium_mhz * 1000000;
 #endif
+#endif /* __rtems */
 #endif
2.2.2
