[PATCH 2/2] bsp/tms570 Use bitfields instead of hard-coded values
Fri Jul 17 16:44:57 UTC 2015
I am about to leave for a week. If these are OK, they need to
be committed to the master and 4.11 branch please.
On 7/17/2015 10:04 AM, Premysl Houdek wrote:
> Signed-off-by: Premysl Houdek <kom541000 at gmail.com>
>   c/src/lib/libbsp/arm/tms570/clock/clock.c          | 31 +++++++++++++++-----
>   .../lib/libbsp/arm/tms570/console/printk-support.c |  4 +--
>   c/src/lib/libbsp/arm/tms570/console/tms570-sci.c   | 34 ++++++++++++----------
>   c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c       | 15 +++++-----
>   4 files changed, 52 insertions(+), 32 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/tms570/clock/clock.c b/c/src/lib/libbsp/arm/tms570/clock/clock.c
> index 1d887af..45da093 100644
> --- a/c/src/lib/libbsp/arm/tms570/clock/clock.c
> +++ b/c/src/lib/libbsp/arm/tms570/clock/clock.c
> @@ -85,23 +85,39 @@ static void tms570_clock_driver_support_initialize_hardware( void )
>     /* Hardware specific initialize */
>     TMS570_RTI.GCTRL = 0;
>     TMS570_RTI.CNT[0].CPUCx = tc_prescaler - 1;
> -  TMS570_RTI.TBCTRL = 2;
> +  TMS570_RTI.TBCTRL = TMS570_RTI_TBCTRL_INC;
>     TMS570_RTI.CAPCTRL = 0;
>     TMS570_RTI.COMPCTRL = 0;
>     /* set counter to zero */
>     TMS570_RTI.CNT[0].UCx = 0;
>     TMS570_RTI.CNT[0].FRCx = 0;
>     /* clear interrupts*/
> -  TMS570_RTI.CLEARINTENA = 0x00070f0f;
> -  TMS570_RTI.INTFLAG = 0x0007000f;
> +  TMS570_RTI.CLEARINTENA = TMS570_RTI_CLEARINTENA_CLEAROVL1INT |
> +                           TMS570_RTI_CLEARINTENA_CLEAROVL0INT |
> +                           TMS570_RTI_CLEARINTENA_CLEARTBINT |
> +                           TMS570_RTI_CLEARINTENA_CLEARDMA3 |
> +                           TMS570_RTI_CLEARINTENA_CLEARDMA2 |
> +                           TMS570_RTI_CLEARINTENA_CLEARDMA1 |
> +                           TMS570_RTI_CLEARINTENA_CLEARDMA0 |
> +                           TMS570_RTI_CLEARINTENA_CLEARINT3 |
> +                           TMS570_RTI_CLEARINTENA_CLEARINT2 |
> +                           TMS570_RTI_CLEARINTENA_CLEARINT1 |
> +                           TMS570_RTI_CLEARINTENA_CLEARINT0;
> +  TMS570_RTI.INTFLAG = TMS570_RTI_INTFLAG_OVL1INT |
> +                       TMS570_RTI_INTFLAG_OVL0INT |
> +                       TMS570_RTI_INTFLAG_TBINT |
> +                       TMS570_RTI_INTFLAG_INT3 |
> +                       TMS570_RTI_INTFLAG_INT2 |
> +                       TMS570_RTI_INTFLAG_INT1 |
> +                       TMS570_RTI_INTFLAG_INT0;
>     /* set timer */
>     TMS570_RTI.CMP[0].COMPx = TMS570_RTI.CNT[0].FRCx + tc_increments_per_tick;
>     TMS570_RTI.COMP0CLR = TMS570_RTI.CMP[0].COMPx + tc_increments_per_tick / 2;
>     TMS570_RTI.CMP[0].UDCPx = tc_increments_per_tick;
>     /* enable interupt */
> -  TMS570_RTI.SETINTENA = 0x1;
> +  TMS570_RTI.SETINTENA = TMS570_RTI_SETINTENA_SETINT0;
>     /* enable timer */
> -  TMS570_RTI.GCTRL = 1;
> +  TMS570_RTI.GCTRL = TMS570_RTI_GCTRL_CNT0EN;
>     /* set timecounter */
>     tms570_rti_tc.tc_get_timecount = tms570_rti_get_timecount;
>     tms570_rti_tc.tc_counter_mask = 0xffffffff;
> @@ -117,7 +133,7 @@ static void tms570_clock_driver_support_initialize_hardware( void )
>   static void tms570_clock_driver_support_at_tick( void )
> -  TMS570_RTI.INTFLAG = 0x00000001;
> +  TMS570_RTI.INTFLAG = TMS570_RTI_INTFLAG_INT0;
> @@ -156,7 +172,8 @@ static void tms570_clock_driver_support_install_isr(
>   static void tms570_clock_driver_support_shutdown_hardware( void )
>     /* turn off the timer interrupts */
> -  TMS570_RTI.CLEARINTENA = 0x20000;
> +  TMS570_RTI.CLEARINTENA = TMS570_RTI_CLEARINTENA_CLEAROVL0INT |
>   #define Clock_driver_support_initialize_hardware \
> diff --git a/c/src/lib/libbsp/arm/tms570/console/printk-support.c b/c/src/lib/libbsp/arm/tms570/console/printk-support.c
> index ed33d98..77e4f1a 100644
> --- a/c/src/lib/libbsp/arm/tms570/console/printk-support.c
> +++ b/c/src/lib/libbsp/arm/tms570/console/printk-support.c
> @@ -41,7 +41,7 @@ static void tms570_putc(char ch)
>     rtems_interrupt_level level;
>     rtems_interrupt_disable(level);
> -  while ( ( driver_context_table[0].regs->FLR & 0x100 ) == 0) {
> +  while ( ( driver_context_table[0].regs->FLR & TMS570_SCI_FLR_TXRDY ) == 0) {
>       rtems_interrupt_flash(level);
>     driver_context_table[0].regs->TD = ch;
> @@ -74,7 +74,7 @@ static void tms570_uart_output(char c)
>   static int tms570_uart_input( void )
> -  if ( driver_context_table[0].regs->FLR & (1<<9) ) {
> +  if ( driver_context_table[0].regs->FLR & TMS570_SCI_FLR_RXRDY ) {
>         return driver_context_table[0].regs->RD;
>     } else {
>         return -1;
> diff --git a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
> index 44b53f5..54c1b69 100644
> --- a/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
> +++ b/c/src/lib/libbsp/arm/tms570/console/tms570-sci.c
> @@ -155,7 +155,7 @@ static int tms570_sci_read_received_chars(
>   static void tms570_sci_enable_interrupts(tms570_sci_context * ctx)
> -  ctx->regs->SETINT = (1<<9);
> +  ctx->regs->SETINT = TMS570_SCI_SETINT_SET_RX_INT;
> @@ -169,7 +169,7 @@ static void tms570_sci_enable_interrupts(tms570_sci_context * ctx)
>   static void tms570_sci_disable_interrupts(tms570_sci_context * ctx)
> -  ctx->regs->CLEARINT = (1<<9);
> +  ctx->regs->CLEARINT = TMS570_SCI_CLEARINT_CLR_RX_INT;
> @@ -216,29 +216,30 @@ static bool tms570_sci_set_attributes(
>     rtems_termios_device_lock_acquire(base, &lock_context);
> -  ctx->regs->GCR1 &= ~( (1<<7) | (1<<25) | (1<<24) );
> +  ctx->regs->GCR1 &= ~( TMS570_SCI_GCR1_SWnRST | TMS570_SCI_GCR1_TXENA |
> +                        TMS570_SCI_GCR1_RXENA );
> -  ctx->regs->GCR1 &= ~(1<<4);    /*one stop bit*/
> -  ctx->regs->FORMAT = 0x7;
> +  ctx->regs->GCR1 &= ~TMS570_SCI_GCR1_STOP;    /*one stop bit*/
> +  ctx->regs->FORMAT = TMS570_SCI_FORMAT_CHAR(0x7);
>     switch ( t->c_cflag & ( PARENB|PARODD ) ) {
>       case ( PARENB|PARODD ):
>         /* Odd parity */
> -      ctx->regs->GCR1 &= ~(1<<3);
> -      ctx->regs->GCR1 |= (1<<2);
> +      ctx->regs->GCR1 &= ~TMS570_SCI_GCR1_PARITY;
> +      ctx->regs->GCR1 |= TMS570_SCI_GCR1_PARITY_ENA;
>         break;
>       case PARENB:
>         /* Even parity */
> -      ctx->regs->GCR1 |= (1<<3);
> +      ctx->regs->GCR1 |= TMS570_SCI_GCR1_PARITY;
>         break;
>       default:
>       case 0:
>       case PARODD:
>         /* No Parity */
> -      ctx->regs->GCR1 &= ~(1<<2);
> +      ctx->regs->GCR1 &= ~TMS570_SCI_GCR1_PARITY_ENA;
>     /* Baud rate */
> @@ -247,7 +248,8 @@ static bool tms570_sci_set_attributes(
>     bauddiv = (BSP_PLL_OUT_CLOCK + baudrate / 2) / baudrate;
>     ctx->regs->BRS = bauddiv;
> -  ctx->regs->GCR1 |= (1<<7) | (1<<25) | (1<<24);
> +  ctx->regs->GCR1 |= TMS570_SCI_GCR1_SWnRST | TMS570_SCI_GCR1_TXENA |
> +                     TMS570_SCI_GCR1_RXENA;
>     rtems_termios_device_lock_release(base, &lock_context);
> @@ -274,7 +276,7 @@ static void tms570_sci_interrupt_handler(void * arg)
>      * Check if we have received something.
> -   if ( (ctx->regs->FLR & (1<<9) ) == (1<<9) ) {
> +   if ( (ctx->regs->FLR & TMS570_SCI_FLR_RXRDY ) == TMS570_SCI_FLR_RXRDY ) {
>         n = tms570_sci_read_received_chars(ctx, buf, TMS570_SCI_BUFFER_SIZE);
>         if ( n > 0 ) {
>           /* Hand the data over to the Termios infrastructure */
> @@ -284,7 +286,7 @@ static void tms570_sci_interrupt_handler(void * arg)
>      * Check if we have something transmitted.
> -  if ( (ctx->regs->FLR & (1<<8) ) == (1<<8) ) {
> +  if ( (ctx->regs->FLR & TMS570_SCI_FLR_TXRDY ) == TMS570_SCI_FLR_TXRDY ) {
>       n = tms570_sci_transmitted_chars(ctx);
>       if ( n > 0 ) {
> @@ -355,7 +357,7 @@ static void tms570_sci_poll_write(
>     /* Write */
>     for ( i = 0; i < n; ++i ) {
> -    while ( (ctx->regs->FLR & (1<<11) ) == 0) {
> +    while ( (ctx->regs->FLR & TMS570_SCI_FLR_TX_EMPTY ) == 0) {
>       ctx->regs->TD = buf[i];
> @@ -375,7 +377,7 @@ static int TMS570_sci_can_read_char(
> -  return ctx->regs->FLR & (1<<9);
> +  return ctx->regs->FLR & TMS570_SCI_FLR_RXRDY;
> @@ -530,7 +532,7 @@ static void tms570_sci_interrupt_last_close(
>     /* Flush device */
> -  while ( ( ctx->regs->FLR & (1<<11) ) > 0 ) {
> +  while ( ( ctx->regs->FLR & TMS570_SCI_FLR_TX_EMPTY ) > 0 ) {
>       ;/* Wait until all data has been sent */
> diff --git a/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c b/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
> index 6514368..749dd9d 100644
> --- a/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
> +++ b/c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c
> @@ -35,19 +35,20 @@ void tms570_pom_remap(void)
>     int i;
>     uint32_t vec_overlay_start = 0x08000000;
> +  uint32_t temp = 0;
>     memcpy((void*)vec_overlay_start, bsp_start_vector_table_begin, 64);
>     TMS570_POM.GLBCTRL = 0;
>     for ( i = 0; i < TMS570_POM_REGIONS; ++i ) {
> -    TMS570_POM.REG[i].REGSIZE = TMS570_POM_REGSIZE_DISABLED;
> +    TMS570_POM.REG[i].REGSIZE = TMS570_POM_REGSIZE_SIZE(TMS570_POM_REGSIZE_DISABLED);
> -  TMS570_POM.REG[0].PROGSTART = 0x0 & TMS570_POM_REGADDRMASK;
> -  TMS570_POM.REG[0].OVLSTART = vec_overlay_start & TMS570_POM_REGADDRMASK;
> -  TMS570_POM.REG[0].REGSIZE = TMS570_POM_REGSIZE_64B;
> -  TMS570_POM.GLBCTRL = TMS570_POM_GLBCTRL_ENABLE |
> -                       (vec_overlay_start & ~TMS570_POM_REGADDRMASK);
> +  TMS570_POM.REG[0].PROGSTART = TMS570_POM_PROGSTART_STARTADDRESS(0);
> +  TMS570_POM.REG[0].OVLSTART = TMS570_POM_OVLSTART_STARTADDRESS(vec_overlay_start);
> +  TMS570_POM.REG[0].REGSIZE = TMS570_POM_REGSIZE_SIZE(TMS570_POM_REGSIZE_64B);
> +  TMS570_POM.GLBCTRL = TMS570_POM_GLBCTRL_ON_OFF(0xa) |
> +                       TMS570_POM_GLBCTRL_ETO(0xa) |
> +                       (TMS570_POM_GLBCTRL_OTADDR(~0) & vec_overlay_start);
